Old 10-30-2012, 01:22 AM   #43
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
For those of you looking for a "dimmer" light output, wire one of THESE in line to the LED strip. Its basically a dimmer that cuts power totally when turned all the way off so it doesn't drain your battery.
Trashed675 is offline   Reply With Quote
Old 10-30-2012, 02:55 AM   #44
psk
Drives: scion fr-s
is there a DIY for this? anyone do a very faint/light white light? my IS 250 had some and i sure miss how they looked.
psk is offline   Reply With Quote
Old 10-30-2012, 03:00 AM   #45
zex
zex's Avatar
Drives: Subaru WRB BRZ Limited
+1 for DIY please
zex is offline   Reply With Quote
Old 10-30-2012, 04:56 AM   #46
rhysmcinerney
Drives: GT86 Auto
In terms of DIY.
Anyone know more specifically how this would connect up to power and provide a frame work as to what materials would be needed?
Does this void your warranty if you hook it up to the fuse or tap into wiring so that the footwell lighting turns on when you turn your headlights on?
rhysmcinerney is offline   Reply With Quote
Old 10-30-2012, 09:51 AM   #47
xcelir8brz
Drives: 2013 BRZ Limited
Originally Posted by NemeGuero View Post
^what he said. What LED's did you buy and what did you mount them to?
Here: http://www.superbrightleds.com/morei...edge-base/206/ (RED)
xcelir8brz is offline   Reply With Quote
Old 10-30-2012, 10:03 AM   #48
xcelir8brz
Originally Posted by rhysmcinerney View Post
In terms of DIY.
Simple.
  1. Total cost of entire project (not including labor): ~under $75.00
  2. Buy wire.
  3. Buy 2 wedge sockets.
  4. Buy some plastic.
  5. Tape the center console lighter socket for power.
  6. Build a 'Y' harness of cable. Drill twist the cable. Solder connections. Wrap in Electrical tape. Enough to go from the center console to the left drivers footwell and enough to go from the center console to the right passenger footwell.
  7. Next, use my template (see below) and cut some plastic for bendable brackets. and insert wedge sockets and then bulbs into that.
  8. Mount the brackets in locations as I show below.
Faint white:
Old 10-30-2012, 10:53 PM   #49
sofrsnsokleen
GEARS!!???
sofrsnsokleen's Avatar
Drives: raven black 2013 scion fr-s
Location: the southeast side of san antonio, where the players play!
Originally Posted by xcelir8brz View Post
Simple.
  2. Buy wire.
Faint white:
could you say the part again, where you said the stuff about the things??
um, the things.....?
Man i'm completely lost on all of this, LOL. You might as well told me how to build a flux capacitor. Hand me the dunce cap please. This is why I need to find someone locally to do it for me.
sofrsnsokleen is offline   Reply With Quote
Old 10-30-2012, 11:00 PM   #50
i_4got
i_4got's Avatar
Drives: Whiteout FR-S
LOL! Same here! I was so happy when I saw the DIY, then I realized that I don't understand any of it.
i_4got is offline   Reply With Quote
Old 10-30-2012, 11:17 PM   #51
gmookher
You buy plastic, cut it bend it and use it to mount the LEDs
gmookher is offline   Reply With Quote
Old 10-30-2012, 11:18 PM   #52
sofrsnsokleen
GEARS!!???
lol, and the lights magically light up??? I get lost in the wiring of the lights etc. No experience with any of this.
Old 10-30-2012, 11:26 PM   #53
koteman
koteman's Avatar
Drives: Scion frs
Get a fuse tap in the fuse block and wire the pos to a switch then the switch to all the positives on LEDs in parallel and all the grounds can go to a bolt that grounds to the frame of the car
koteman is offline   Reply With Quote
Old 10-30-2012, 11:30 PM   #54
i_4got
i_4got's Avatar
I don't mean to be annoying, but I had no idea what any of that meant. LOL
I'm such a noob, but I also don't want to pay some excessive charge for a shop to do this. Sadly, I doubt anyone would be willing to do a video DIY of this. =(
Old 10-30-2012, 11:43 PM   #55
koteman
koteman's Avatar
Drives: Scion frs
It's really easy don't pay someone. This was the first mid I ever did to a car in my life on my old car. Check out the tech section on the oznium forums they have explanations. It's where I learned
Old 10-30-2012, 11:46 PM   #56
koteman
koteman's Avatar
Drives: Scion frs
I plan on doing all my lights in like a month I'll do a DIY then but idk if u want to wait that long
Differences In Types of Headlights/Lighting Asphalt Cosmetic Modification (Interior/Exterior/Lighting) 7 02-21-2013 07:49 AM
HID_Powerhouse offers HID kits and LED lighting for your FR-S/BRZ KI_ZN6 CANADA 2 07-27-2012 05:13 PM
interior lighting? fistpoint Scion FR-S / Toyota 86 GT86 General Forum 2 05-09-2012 01:52 AM
Stupid girl 2 foot driving GenkiElite Off-Topic Lounge [WARNING: NO POLITICS] 31 07-23-2011 08:33 PM
How much do you like heel-toeing or left foot braking? USMCMike Other Vehicles & General Automotive Discussions 20 01-15-2010 04:20 PM
