Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
05-26-2022, 10:55 AM | #43 |
Drives: 2013 FRS
07-22-2022, 10:26 PM | #45 |
Drives: 2018 BRZ
Is the repair kit needed if you're ordering the calipers new or is it just for maintenance?
08-09-2022, 01:56 PM | #46 |
Drives: 2018 BRZ Sport-tech RS
Chiming in here to say I've recently had the following installed on my 2018 BRZ w/ Brembo:
EBC BSD1056 (front rotors) EBC DP51210NDX (front pads) EBC DP51537NDX (rear pads) EBC does not currently make any rear rotors that will fit the car (verified by EBC themselves). I tried the BSD1057, and although the diameter, thickness, bolt pattern are correct, the "height" of the hat is such that the inside face of the rotor interferes with parts with the dust shield. |
The Following User Says Thank You to pkennethv For This Useful Post: | timurrrr (08-09-2022) |
09-09-2022, 05:22 AM | #47 |
Drives: BRZ (in near future)
I saw this Brembo on sale, but noticed that the piston size is different, AFAIK the PP Brembo use the same size 40mm piston?
09-09-2022, 09:59 AM | #48 | |
That said, FWIW, a lot of aftermarket Brembo kits for these cars are using 38mm & 40mm stagger, with some shops claiming this is even more ideal. Whether it's truly more ideal or not, I'm not qualified to say, but it would seem that even if it isn't more ideal, it shouldn't be much worse than the factory setup. |
09-09-2022, 04:18 PM | #49 |
Brembo and AP Racing aftermarket BBK use staggered pistons to prevent pad tapering.
11-15-2022, 10:52 AM | #50 |
Drives: 2017 Brz
Thanks for all the great info.
I’m wondering if anyone has an idea of when the original rotors should be replaced, at what thickness? Have to do my pads and wonder if rotors need service too. Thx. Sent from my iPhone using Tapatalk |
11-15-2022, 11:22 AM | #51 | |
I forgot the specific number…28mm is what I wanna say off the top of my head but don’t quote me on that…I will check later today |
11-15-2022, 11:57 AM | #52 | |
Drives: 2022 GR86
It's 28 mm for the fronts and 18 mm for the rear if I recall correctly.
Follow the build thread for my GR86!
The Following User Says Thank You to timurrrr For This Useful Post: | Drafter (11-15-2022) |
11-15-2022, 12:10 PM | #53 |
Drives: 2017 Brz
You guys are amazing. Thx!
And no one roasted me. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to Drafter For This Useful Post: | timurrrr (11-15-2022) |
11-21-2022, 09:41 AM | #54 | |
Drives: 2018 GT86
Sent from my LM-G900 using Tapatalk |
01-21-2023, 03:22 PM | #55 |
Drives: None
Has anyone measured a rear PP piston? Subaru/Toyota part numbers seem to indicate that maybe the front and rear pistons are the exact same part?
01-21-2023, 07:17 PM | #56 | |
Drives: 2022 GR86
I believe the pistons are indeed the same exact part.
Similar Threads | ||||
STi Brembos | Do Boy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 315 | 05-01-2016 06:04 PM |
STI Brembos. | xkalelx | Brakes, Suspension, Chassis | 24 | 08-31-2015 12:28 PM |
Brembos | biggy69 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 05-15-2014 09:23 PM |
will the sti brembos fit fr-s/brz? | driver01 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 51 | 04-12-2014 02:25 PM |
F/S NY 06 STI BREMBOS | subyboy | NY / NJ / CT / PA | 17 | 08-21-2013 07:28 PM |
