Old 05-26-2022, 10:55 AM   #43
SpeBud07
Drives: 2013 FRS
Originally Posted by clio View Post
Tie bar is Subaru part number 26261FE000 (2 required, left and right are identical)
I used Goodridge brake lines specific to Brembo models, which is Goodridge part number 28007
Thanks, any other tips I should know prior? What about rear backing plates?
SpeBud07 is offline   Reply With Quote
Old 05-26-2022, 06:58 PM   #44
clio
Drives: 2013 Subaru BRZ
I'm in the process of doing the swap myself.
If you look at the video here (about 20 min mark) the rear plate can be manipulated to accommodate the Brembo caliper. Otherwise source new.
clio is offline   Reply With Quote
The Following User Says Thank You to clio For This Useful Post:
SpeBud07 (05-26-2022)
Old 07-22-2022, 10:26 PM   #45
warhawk03
Drives: 2018 BRZ
Is the repair kit needed if you're ordering the calipers new or is it just for maintenance?
warhawk03 is offline   Reply With Quote
Old 08-09-2022, 01:56 PM   #46
pkennethv
Drives: 2018 BRZ Sport-tech RS
Chiming in here to say I've recently had the following installed on my 2018 BRZ w/ Brembo:
EBC BSD1056 (front rotors)
EBC DP51210NDX (front pads)
EBC DP51537NDX (rear pads)
EBC does not currently make any rear rotors that will fit the car (verified by EBC themselves). I tried the BSD1057, and although the diameter, thickness, bolt pattern are correct, the "height" of the hat is such that the inside face of the rotor interferes with parts with the dust shield.
pkennethv is offline   Reply With Quote
The Following User Says Thank You to pkennethv For This Useful Post:
timurrrr (08-09-2022)
Old 09-09-2022, 05:22 AM   #47
teppey
teppey's Avatar
Drives: BRZ (in near future)
I saw this Brembo on sale, but noticed that the piston size is different, AFAIK the PP Brembo use the same size 40mm piston?
teppey is offline   Reply With Quote
Old 09-09-2022, 09:59 AM   #48
pkennethv
Yes, the factory Brembos for the twins are 40mm for all pistons on the front calliper.
That said, FWIW, a lot of aftermarket Brembo kits for these cars are using 38mm & 40mm stagger, with some shops claiming this is even more ideal. Whether it's truly more ideal or not, I'm not qualified to say, but it would seem that even if it isn't more ideal, it shouldn't be much worse than the factory setup.
Old 09-09-2022, 04:18 PM   #49
teppey
teppey's Avatar
Brembo and AP Racing aftermarket BBK use staggered pistons to prevent pad tapering.
Old 11-15-2022, 10:52 AM   #50
Drafter
Drives: 2017 Brz
Thanks for all the great info.
I’m wondering if anyone has an idea of when the original rotors should be replaced, at what thickness?
Have to do my pads and wonder if rotors need service too.
Thx.
Drafter is offline   Reply With Quote
Old 11-15-2022, 11:22 AM   #51
pkennethv
Thx.
I just remember it’s 1mm thickness difference between when it’s officially recommended to replace the rotors vs new.
I forgot the specific number…28mm is what I wanna say off the top of my head but don’t quote me on that…I will check later today
Old 11-15-2022, 11:57 AM   #52
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
They have it written on the hats
It's 28 mm for the fronts and 18 mm for the rear if I recall correctly.
Follow the build thread for my GR86!
The Following User Says Thank You to timurrrr For This Useful Post:
Drafter (11-15-2022)
Old 11-15-2022, 12:10 PM   #53
Drafter
Drives: 2017 Brz
You guys are amazing. Thx!
And no one roasted me.
The Following User Says Thank You to Drafter For This Useful Post:
timurrrr (11-15-2022)
Old 11-21-2022, 09:41 AM   #54
Wilhelm_Hertzog
Drives: 2018 GT86
I bought BSD rotors (1056 for the front and 1057 for the back) for my 2018 GT86 (with Brembo brakes) recently, and can unfortunately confirm that the rears rub against the dust cover when installed. Pretty disappointing.
Sent from my LM-G900 using Tapatalk
Wilhelm_Hertzog is offline   Reply With Quote
Old 01-21-2023, 03:22 PM   #55
RedReplicant
Drives: None
Has anyone measured a rear PP piston? Subaru/Toyota part numbers seem to indicate that maybe the front and rear pistons are the exact same part?
RedReplicant is offline   Reply With Quote
Old 01-21-2023, 07:17 PM   #56
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Definitely same OD, as the seals are identical.
I believe the pistons are indeed the same exact part.
STi Brembos Do Boy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 315 05-01-2016 06:04 PM
STI Brembos. xkalelx Brakes, Suspension, Chassis 24 08-31-2015 12:28 PM
Brembos biggy69 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 05-15-2014 09:23 PM
will the sti brembos fit fr-s/brz? driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-12-2014 02:25 PM
F/S NY 06 STI BREMBOS subyboy NY / NJ / CT / PA 17 08-21-2013 07:28 PM
