Old 09-18-2020, 11:31 PM   #43
jflogerzi
jflogerzi's Avatar
Originally Posted by Tokay444 View Post
You fucked it up.
I hate to say it but yes.. Most likely O2 sensor damaged, car was on E85 and ran lean and boom goes the engine. Its sad to say the least.
2013 Series 10 FRS #553
Old 09-20-2020, 10:44 AM   #44
mrg666
pessimistic skeptic
mrg666's Avatar
Old O2 sensors were hard to take off without damage when I was replacing the header. I agree (and picture shows) that they were probably damaged.
I know OFT tune disables the CEL for O2 sensor after the cat. But it should have given a CEL at least for the pre-cat sensor instead of mixing a bad AFR.
This thread should be sticky to show how a bad mod ends.
Old 09-20-2020, 10:47 AM   #45
jflogerzi
jflogerzi's Avatar
At least as a warning. If your not willing to do your homework don't mod your car. Engines are not cheap and the labor will be worse.
Old 09-25-2020, 10:42 AM   #46
Slade
Slade's Avatar
Drives: 14 Limited BRZ
Car was not on E85 actually
Slade is offline   Reply With Quote
Old 09-25-2020, 10:42 AM   #47
Slade
Slade's Avatar
Had a shop install the headers for me. I guess they messed up the O2 sensor
Old 09-25-2020, 09:13 PM   #48
Tokay444
Anti stance.
Tokay444's Avatar
Or put too many headers on.
Old 01-10-2021, 11:24 AM   #49
Slade
Slade's Avatar
Hey I'm back. Had to budget and save but I got a new motor put in. BRZ is running awesome. Got a used motor with 40k miles, and got a proper ECUTEK tune done. Car drives great. Very expensive lesson, but I am glad I decided not to sell my car and fix it instead. Thanks to everyone who took the time to help me try and fix this problem, and thanks to everyone who had smart comments and jokes. I'm still embarrassed about this. But thats it regarding mods now. Just gonna focus on maintenance.
Old 01-10-2021, 12:42 PM   #50
wbradley
Sarcastic SOB
wbradley's Avatar
Happy you got through your ordeal. Hopefully you are better for the experience, and you can put it behind you.
Old 01-10-2021, 03:48 PM   #51
dasting
Drives: 2013 BRZ Limited
Yeah, good work on figuring out next steps. Curious - how did you locate a motor and how much was it? I've seen prices a bit all over the place, from $2k ish to $4k.
2013 BRZ Limited, NASA Instructor, ex-spec miata racer
dasting is offline   Reply With Quote
After installing UEL PSR headers Armin93 Engine, Exhaust, Transmission 7 04-18-2017 02:44 PM
P2096 CEL Code week after installing header Inspir3dk Engine, Exhaust, Transmission 15 02-07-2017 11:07 AM
First week off to a bad start, and a bunch on non-starts BCUZ BXR Issues | Warranty | Recalls / TSB 46 08-15-2013 07:04 PM
I start at Quirk Subaru this week! Turbowned New England 22 10-23-2012 10:54 AM
Toyotapartsoutlet.com is going to get answers from Toyota this week. Start posting TPO Issues | Warranty | Recalls / TSB 71 08-22-2012 02:15 PM
