| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#43 |
Drives: Brz with wudebody. Hopefully boost
#44 | |
Site Moderator
Drives: Stuff
If that's on the PDL circuit then that's just more reason to check that fuse
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#45 | |
Drives: Q5 + BRZ + M796
https://www.ft86club.com/forums/showthread.php?t=125232
#46 | |
What fuse is? It didn’t come with the diagram fuse box cover |
#47 |
Site Moderator
Drives: Stuff
-Dave
| The Following User Says Thank You to Dave-ROR For This Useful Post: | Irace86.2.0 (05-26-2020) |
#48 |
Drives: 2020 GMC Canyon Denali Diesel
What year car is this problem occurring on? Does anything else not work? Has the Airbag module been replaced/reset? How hard was the car hit, was the under hood fuse box, or wiring, damaged?
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
#49 |
There should not be a fuse installed in the circled spot in the under the hood fuse box, if there is that puts the car in transportation/delivery mode and kills the power door locks, radio and a few other things to preserve battery life during new car transport.
If this doesn't fix it you should give the car to me & Dave-ROR...
#50 | |
It’s a 2018. Airbag module was not reset. Lights r still on Had a decent hit. I had to replace hood passenger fender radiator support, radiator, bumper and headlight No damage to fuse box wiring And ty for the diagram |
#51 | |
Part out. Lol |
| The Following User Says Thank You to Yitzb For This Useful Post: | Opie (05-26-2020) |
#52 | |
I checked the fuse and replaced it with a new one didn’t work so I replaced again still didn’t work |
| The Following User Says Thank You to Yitzb For This Useful Post: | p1l0t (05-29-2020) |
#53 |
Dis you check or change the 20 amp fuse labeled D/L for Door Locks? It is a small fuse in the engine bay fuse box.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | p1l0t (05-29-2020) |
#54 |
#55 |
Remove the door cards and check for power going to the door lock controls using a multimeter. Work your way back to the battery.
Get a Techstream to check the chassis codes.
#56 |
| Adding doors auto-lock and oil t° display to your FRS / BRZ / 86 | T0rt0r0 | DIY (Do-It-Yourself) Guides | 82 | 05-14-2019 01:46 AM |
| Doors won't lock. | mynameis940 | Issues | Warranty | Recalls / TSB | 9 | 03-15-2018 03:05 PM |
| Trunk won't open and doors won't lock/unlock | Mazikowski | Electronics | Audio | NAV | Infotainment | 13 | 03-05-2018 11:50 AM |
| Auto Lock (Doors) | pinoyplaya | BRZ First-Gen (2012+) — General Topics | 67 | 11-13-2017 11:47 AM |
| Doors won't automatically lock | adan | Issues | Warranty | Recalls / TSB | 18 | 03-01-2014 11:02 AM |
