Old 05-25-2020, 09:02 PM   #43
Yitzb
Yitzb's Avatar
Drives: Brz with wudebody. Hopefully boost
Does your trunk open with the electronic button or fob?
Nope. And also doesn’t open with the button by the steering wheel. And I already check the lock in the trunk
Yitzb is offline   Reply With Quote
Old 05-25-2020, 09:04 PM   #44
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I haven't traced that system to see if it's connected to the PDL circuit (Maybe IRace has though) but also check that stupid button in the trunk for that. If that button is "open" (or unplugged) none of the electronic trunk releases will work.
If that's on the PDL circuit then that's just more reason to check that fuse
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-25-2020, 09:05 PM   #45
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
This guy had the same problem. It was the fuse:
https://www.ft86club.com/forums/showthread.php?t=125232
Old 05-25-2020, 09:07 PM   #46
Yitzb
Yitzb's Avatar
What fuse is? It didn’t come with the diagram fuse box cover
Old 05-25-2020, 09:09 PM   #47
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
https://lmgtfy.com/?q=brz+fuse+box+diagram
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Irace86.2.0 (05-25-2020)
Old 05-26-2020, 09:26 AM   #48
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
What year car is this problem occurring on? Does anything else not work? Has the Airbag module been replaced/reset? How hard was the car hit, was the under hood fuse box, or wiring, damaged?
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 05-26-2020, 09:38 AM   #49
Opie
Opie's Avatar
There should not be a fuse installed in the circled spot in the under the hood fuse box, if there is that puts the car in transportation/delivery mode and kills the power door locks, radio and a few other things to preserve battery life during new car transport.
If this doesn't fix it you should give the car to me & Dave-ROR...
Old 05-26-2020, 09:39 AM   #50
Yitzb
Yitzb's Avatar
It’s a 2018.
Airbag module was not reset. Lights r still on
Had a decent hit. I had to replace hood passenger fender radiator support, radiator, bumper and headlight
No damage to fuse box wiring
And ty for the diagram
Old 05-26-2020, 09:52 AM   #51
Yitzb
Yitzb's Avatar
Part out. Lol
The Following User Says Thank You to Yitzb For This Useful Post:
Opie (05-26-2020)
Old 05-28-2020, 02:42 PM   #52
Yitzb
Yitzb's Avatar
I checked the fuse and replaced it with a new one didn’t work so I replaced again still didn’t work
p1l0t (05-29-2020)
Old 05-28-2020, 04:33 PM   #53
Irace86.2.0
Dis you check or change the 20 amp fuse labeled D/L for Door Locks? It is a small fuse in the engine bay fuse box.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
p1l0t (05-29-2020)
Old 05-30-2020, 11:20 PM   #54
Yitzb
Yitzb's Avatar
I changed the fuse
Old 05-30-2020, 11:46 PM   #55
Irace86.2.0
I changed the fuse
Remove the door cards and check for power going to the door lock controls using a multimeter. Work your way back to the battery.
Get a Techstream to check the chassis codes.
Old 05-30-2020, 11:53 PM   #56
Yitzb
Yitzb's Avatar
Gonna do it tomorrow will update u
Adding doors auto-lock and oil t° display to your FRS / BRZ / 86 T0rt0r0 DIY (Do-It-Yourself) Guides 82 05-14-2019 12:46 AM
Doors won't lock. mynameis940 Issues | Warranty | Recalls / TSB 9 03-15-2018 02:05 PM
Trunk won't open and doors won't lock/unlock Mazikowski Electronics | Audio | NAV | Infotainment 13 03-05-2018 10:50 AM
Auto Lock (Doors) pinoyplaya BRZ First-Gen (2012+) — General Topics 67 11-13-2017 10:47 AM
Doors won't automatically lock adan Issues | Warranty | Recalls / TSB 18 03-01-2014 10:02 AM
