Old 05-28-2020, 06:35 AM   #43
Contender
Drives: 2017 Toyota 86
Hmmm makes me feel pretty good about my stock gutted header and frontpipe and tune seeing that I am at 205whp not bad for 30 bucks in gaskets and my time.
Contender is offline   Reply With Quote
Old 05-28-2020, 10:56 AM   #44
PulsarBeeerz
Drives: JRSC BRZ SOLD
Eh all dyno's read differently and the same one with different correction factors..
PulsarBeeerz is offline   Reply With Quote
Old 05-28-2020, 01:26 PM   #45
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by churchx View Post
solidONE: imho fuel economy is not worth splitting hairs about. Technically similar energy should be spent to get upto speed, be it done slower with granny shifting (but for longer period), or faster (but for shorter period and then driving longer with more efficient higher gear). Of course less pumping and drivetrain frictional losses at higher gears at lesser engine rpms may save a bit .. but also will reduce acceleration rate/wheel torque due gearing. Simpler to just not think of fuel economy and have fun driving instead of sedate ecomiling. People pay for comfort, why not pay slight premium for fun. Same reason why i fill with 98 petrol even while manual states that cheaper 95 is ok, and why often from traffic lights shift 1-2-5 or 1-2-6 .
I get it rolling in 1st then quickly slap in second, shift to 3rd then 4th, clutch out. I skip 1st and 3rd depending if it's uphill or downhill grade.
When you've adjusted the calibration of drivability and power related tables and run out of goals to tune for. Fuel economy is important too. I also think any tune with more than 3% LTFT besides idling is unacceptable. I've already all the power I want from the setup, why not dial in the fuel economy? If for nothing else, shits and giggles.
Intent > Content
Old 05-28-2020, 01:50 PM   #46
That's not how you dial in fuel economy...
Old 05-28-2020, 03:24 PM   #47
churchx
churchx's Avatar
Drives: 2014 GT86
If daily driving fuel economy matters, i'd think of working on it in tune in low to mid rpms, like 1.7-3.5K rpms, below dip. This part of powerband is not used on track anyway, where everybody tries to keep in real powerband, 4K till redline. Load also is less, so maybe less safe timings or leaner AFR may work?
Old 05-28-2020, 07:01 PM   #48
Neither actually. You optimizing cylinder fill to get maximum efficiency. Lean burns are really beyond the scope of aftermarket tuning, and you can't go past knock limit.
Old 05-28-2020, 11:24 PM   #49
solidONE
solidONE's Avatar
LMAO I got way too many better things to do.
Intent > Content
Old 05-29-2020, 03:24 AM   #50
86MLR
86MLR's Avatar
I laugh in the face of fuel economy, and then kick it in the balls, with a camed LS1.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 05-29-2020, 02:03 PM   #51
solidONE
solidONE's Avatar
"NO LS does NOT belong in a na 86.
1. Because I insist
2. Because Trololollolol (I know everything)
3. BBK and sway bar dont improve performance. Oh you want brake pads, let me upsell some $3K BBKs to you in private I suggest you get some sway bar too
4. I think I'm Michael Schumacher reincarnated. Cause I'm the best according to myself
5. I'm NOT delusional at ALL"
You wont be when gas prices shoot back up to $4 a gallon. But, lets laugh at fuel economy together. Ready? "TROLOLOLOLOLOLOLOLOLO" again "TROLOLOLOLOLOL". Last rep, "TROLOLOLOLOL" and breeath~
Intent > Content
Old 05-29-2020, 05:35 PM   #52
solidONE
solidONE's Avatar
“Are you ready for the CRG Christmas special?”
Not really...
“Cause Trala lalala lala, lala~”
:lmao:
Intent > Content
Old 05-29-2020, 05:41 PM   #53
86MLR
86MLR's Avatar
Not really...
:lmao:
Ummmmm, Ok....not ready
Old 05-29-2020, 05:49 PM   #54
solidONE
solidONE's Avatar
My goodness? Did I just manifest this shit? I thought I made the CRG Christmas off the top of the dome.. lol maybe not
Intent > Content
Old 05-30-2020, 12:06 PM   #55
EvolutionRevolution
Drives: SCION FRS 2016
Originally Posted by airrick View Post
Finally, the car feels good around the annoying torque dip range. 3k-4.5kish. look at the graph, my butt dyno says it matches the graph below =D.
VS the gruppe-s?
Looks like that header eliminated the torque dip as well according to your other dyno?
EvolutionRevolution is offline   Reply With Quote
Old 05-30-2020, 04:25 PM   #56
solidONE
solidONE's Avatar
Originally Posted by EvolutionRevolution View Post
VS the gruppe-s?
"NO everything you say is NO!" lmao Y'all should have seen the deleted posts. "Trololol"
The 4-2-1's, some of them at least, actually add a bump of torque where the dip is whereas the UEL seem to flatten them out.
For instance, my Long tube 4-2-1 pipe actually peaks right after where the dip used to be (165 ft lbs on E85 vs Stocks 120ish ft lbs. on 91) It's like driving a different car. Vetack like.
Intent > Content
Dyno Results - OFT Stage 2 UEL + Openflash Header + Full Exhaust pinski Software Tuning 8 11-21-2016 11:07 AM
My Nameless header dyno results (results to follow) Simply_the_best Engine, Exhaust, Transmission 39 06-28-2016 04:09 PM
Ace Header 4-2-1 CS400 Custom BRZEdit Tune Dyno Results JDM-dono Engine, Exhaust, Transmission 24 05-05-2016 04:54 PM
Australian Dyno Dyno Results Shiv@Openflash Software Tuning 11 07-22-2015 04:57 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
