Old 04-03-2020, 04:06 PM   #43
JIM THEO
Drives: BRZ 2018
Originally Posted by 86TOYO2k17 View Post
i wonder why some people have issues with subframe rubbing, and most people like myself have zero issues with subframe rubbing on both stock engine mounts and then later sti mounts. is it the 4-2 header or 2-1 overpipe causing the rubbing?
just realized you are in Greece, are you guys RHD or LFD? if you are RHD then it is known and state that the 350 has fitment issues. "GT86/FRS/BRZ 4-2-1 MERGE HEADER, 350 COLLECTOR, LHD" I hope the RHD people aren't the ones buying the 350 and complaining about fitment.
LHD in Greece as you, in my case the overpipe rubs against the subframe when I start from a stop, on hard acceleration and left corners.
As handmade product every header is different as every BRZ/FRS is different, I think the rest of the exhaust plays a role and adds to the rubbing issue, although the only exhaust part I added is a Berk frontpipe.
JIM THEO is offline   Reply With Quote
Old 04-03-2020, 04:11 PM   #44
86TOYO2k17
Drives: 2017 toyota 86
forgot they are all handmade but i have type B so slightly less "handmade"
I have read some people having issues with certain frontpipes if they are either heavier, angled lower then stock, or installed lower, causing the overpipe to "droop" lower and hit. possibly something to look into. or see if you can reinstall frontpipe and bolt it to FP mount to have it higher and pushing overpipe up more. maybe pull catback in closer to "wedge" the FP up more.
Old 04-04-2020, 04:54 AM   #45
gpvecchi
gpvecchi's Avatar
It's made in Taiwan, I don't expect so much quality...
gpvecchi is offline   Reply With Quote
Old 04-04-2020, 04:59 AM   #46
JIM THEO
Drives: BRZ 2018
They are quality products regarding welding and material but they have to adjust better distances and curves of each header to minimize rubbing issues and use better bolts/nuts, Tomei/Gruppe-s headers are made in Taiwan also and they are perfect quality imho!
Old 04-04-2020, 11:23 AM   #47
Infinity
Drives: 2016 Scion FR-S
also my ace 250 header was 1350$ brand new shipped from a vendor (no discount/sale price), and 350 type As are about 1700$, back when more vendors stocked them you could get them for 1500$ when they had their annual sales. So not really close to 2000$
The header is $1700 without shipping or tax. Motor mounts are like $250-300. And you really need a ceramic coating, too. It is easily over $2000 to get this header properly installed on your car.
Infinity is offline   Reply With Quote
Old 04-04-2020, 11:50 AM   #48
gpvecchi
gpvecchi's Avatar
Meh, just my two cents, during years I saw many different brands of exhausts, many of them of reputable brands, but when I saw Supersprint I was amused. But they are absurdly priced, and not so good for our cars...
Old 04-04-2020, 12:28 PM   #49
86TOYO2k17
Free shipping, no tax, I don’t have a ceramic coating and over 2 years in PNW still looks brand new, zero heating issues. And myself and many others had zero issues with stock mounts. Also consider this includes over pipe thats at least another 250$ value over other options.
It also used to be stocked by more vendors (now looks like only ace and csg) when other vendors had it they all have 10%+ off sales several times a year. If i waited 3 months i could have gotten mine to my door for 1215$. But I didn’t want to wait.
But to be fair if the 1700$ ace was all that was available i would have got a EL JDL
Old 04-04-2020, 01:22 PM   #50
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
LOL. That was pretty ignorant. Quality has little to do with where it is made and more to do with accepted tolerances from whomever is commissioning the work.
A header is a pretty complex part to build. Something as simple as removing it from it's fixture before it has cooled enough can distort it.
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post:
CSG Mike (04-08-2020), Irace86.2.0 (05-01-2020), mistople (04-04-2020), PulsarBeeerz (04-04-2020), Tatsu333 (07-19-2022)
Old 04-06-2020, 10:45 AM   #51
B T
I figure the welding fixture and jigs must've been moved around a bit and warped during production. Even on the stock motor mounts, the header was hitting the underbody panel, coming too close to the passenger side sway bar bushing(melted it several times) and the bolt holes at the engine don't line up properly. I always end up having to push apart the header flanges to get it over the head studs. Luckily it hasn't ruined the head stud threads.
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
phm14 (05-11-2020)
Old 04-06-2020, 11:16 AM   #52
JIM THEO
Drives: BRZ 2018
Quick question, how much of noise difference an OEM frontpipe has with and without/gutted frontpipe?
I want to gut the OEM frontpipe but due to ACE headers I believe it will be quite noisy although I have OEM catback, I like it close to factory noise levels!
Old 04-06-2020, 12:30 PM   #53
gpvecchi
gpvecchi's Avatar
Sorry, I don't agree... We're not talking of a CNC made product, these can be made everywhere with extreme quality. We're talking of manifacture...
I'm used to italian manifacture, sorry.
Old 04-06-2020, 12:45 PM   #54
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Your experience must not have much to do with welded product.
With the Nameless header on my car I have issues. Flanges are "sprung" and won't slide onto the studs without being persuaded. Also an expensive header, and US made.
Old 04-06-2020, 01:21 PM   #55
Infinity
Are these kind of fitment issues typical with hand made headers? I assume the ACE and Nameless are hand welded?
I wonder if the JDL 4-2-1 has similar fitment issues.
Old 04-06-2020, 01:31 PM   #56
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It depends on so many factors. I'd say most of the common headers out there are going to be pretty dialed. The more complex, the more chance for distortion.
My turbo manifold also had issues but it was a handmade 1 of 6 so the jig could have been off. I really don't hear of too many complaints across the board on any header but I am sure there are more out there then get posted.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Infinity (04-06-2020)
Automatic Transmission issue- dealer is not recognizing the issue, please help! Arrex Issues | Warranty | Recalls / TSB 36 06-03-2019 05:15 AM
Paid $800+ for wheel speed sensor issue, but the issue came back. What should I do? darkbluemn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-05-2018 09:49 PM
Injen SES Headers/ Agency Power headers Choong86 Engine, Exhaust, Transmission 10 12-27-2013 10:51 PM
Headers: Has the CEL "issue" been solved? boredom.is.me Engine, Exhaust, Transmission 9 10-20-2013 10:35 PM
Do all headers for the BRZ cause the CEL issue? Oburn Engine, Exhaust, Transmission 19 05-16-2013 03:18 PM
