Old 11-21-2019, 02:31 PM   #43
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
Based on everything you've said and done it sounds like you're going to need to be underneath with a stethoscope to figure it out. As others have mentioned, once the vehicle is off the ground it makes diagnosis of wheel bearings more difficult using just your ears. There's no load on any of the spinny bits so noise is much more quite if audible at all.
Either bring to shop for diag or return vehicle to service and wait for noise to get louder so it's easier to tell where it's coming from.
That's all I've got. Good Luck.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
Old 12-31-2019, 09:31 PM   #44
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
So, finally an update! Since the last time I posted, the sound had gotten a little louder. I was pretty confident it was a wheel bearing, but still not 100% sure it was the left front one (probably 75% sure). I was able to order a pair of slightly used OEM ones (13k miles on them) cheaper than a single aftermarket one, so I did. Well, fast forward to today. I finally had the chance to work on my car so I swapped out both hubs. Took the car for a drive and the sound is gone! The left hub was making a slight grinding noise, so that was the culprit. Needless to say I’m now happy again. Next up, E85 kit��
kmbkk is offline   Reply With Quote
The Following User Says Thank You to kmbkk For This Useful Post:
humfrz (12-31-2019)
Old 01-01-2020, 06:35 PM   #45
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Thought it was them bro, glad they fixed !!
mswbrz is offline   Reply With Quote
The Following User Says Thank You to mswbrz For This Useful Post:
kmbkk (01-01-2020)
Fan static/humming noise Zhangy Issues | Warranty | Recalls / TSB 8 08-26-2017 09:47 PM
Strange humming(ish?) sound coming from near rear wheels when car is off redwing634 Issues | Warranty | Recalls / TSB 2 04-02-2017 06:42 PM
AC Humming/Whining ericmpena Issues | Warranty | Recalls / TSB 2 06-08-2015 12:32 PM
Humming from front dphee79 Issues | Warranty | Recalls / TSB 3 04-24-2015 01:51 PM
Buzzing/Humming sound at high idle DGM.BRZ Issues | Warranty | Recalls / TSB 5 04-08-2015 08:04 PM
