Old 08-20-2012, 01:04 AM   #43
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
lol. well...that is back on topic.
And to go back off topic from your previous comment, KW's (or other quality dampers) aren't just for people who want to track their car. They are for people who want good ride quality as well.
If you don't care about ride quality as much as you do the look and just want to lower your car, then these D2/Ksport/whatever else they are branded as, will be fine.
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below.
http://fecompetition.wordpress.com/
https://www.facebook.com/FECompetition
Matt Andrews is offline   Reply With Quote
Old 08-20-2012, 03:14 AM   #44
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
The D2s are definitely stiff... you will be sacrificing a plush ride with these bad boys, but I have had a long line of lowered cars and have no back problems so I am fine with it.
Old 08-20-2012, 01:13 PM   #45
DarrenDriven
NW Region Moderator
Originally Posted by DarrenDriven View Post
DRIVING EXPERIENCE AT ~200 MILES:
All is still well. With 7.4kg/mm rates at the front and 5.0kg/mm at the rear (vs 2.3kg/mm and 3.8kg/mm for the stock springs) you can definitely feel every nuance of the road for better or for worse. Combined with a 40-series front tire, I can tell you if I drove over a penny! This doesn't bother me and it was totally expected based on the specs of the coilover and my previous experience driving lowered cars. Because the car was so low I ran it with the adjustable compression settings at maximum stiffness in order to avoid bottoming the bumper (or lower cross-member) on speed bumps and potholes. I will run at maximum stiffness for another 100 miles or so until I get used to the feel and then move to maximum "softness" in order to feel the other extreme setting, before deciding where in the spectrum I would like to keep it for daily driving. Changing the compression rate is as easy as popping the hood and inserting one of the four included custom allen wrenches.
I have been driving with the front end lowered 2 1/4" until I raised it 1/2" yesterday to avoid chewing up my bottom bumper on driveways. Raising the car was a simple affair. I removed the two front wheels, loosened the lowest locking collar and then used the included wrench to turn the entire spring/strut assembly. It took me about five minutes for each side and when I was done I could actually make it out of my driveway without leaving an Asphalt-colored stripe.
I will be driving the car 700 miles on a road trip in the next week, so expect my 1000 miles entry to come along fairly soon.
Updated.
Old 09-13-2012, 12:18 AM   #46
garf
Great Member
garf's Avatar
Drives: raven, baught 8-29-12, manual
how was the road trip? still riding ok? iv been ghosting this thread for a while and was wondering if the D2s/ksports are still in your favor? and how is it in the corners? have you tried getting it sideways with these on?
garf is offline   Reply With Quote
Old 09-14-2012, 02:13 PM   #47
DarrenDriven
NW Region Moderator
I'm very happy with the value of these coilovers. I still have no issues at all with them, other than the fact that the ride is very stiff. Of course, I've got the car pretty low so a stiff ride is a must so I'm not dipping my bumper into the street every 30 seconds.
I've definitely gotten sideways with these and I have no complaints. I have the front pair on full soft for a little better ride, but I still have the rears set at full stiff. I'm going to adjust the rears to full soft for a few days to see if they feel much different, then I'll set both of them somewhere in the middle, probably.
The real test will be how these fare after winter. Will they be rusted? Will I still be able to adjust them easily? We'll see.
Old 09-15-2012, 03:43 AM   #48
garf
Great Member
garf's Avatar
sounds good man, let us know how the full soft rides, i loved ksports on my 08 civic si just not sure how they will handle on an fr car. keep the updates coming!!
Old 09-15-2012, 05:42 AM   #49
epson1
Drives: 2013 BRZ Limited
Just to chime in here, I also have the Ksports. I am taking my car in for an alignment tomorrow and hope to have Max camber(also Maxs caster) and slight toe out in front and shooting for-1* of camber in the back but I am more worried about the rear toe with my Cusco lower control arms. Shooting for zero toe.
I will be driving the car to Chicago and driving a drift event there and driving back. So we will see how I like the car after another 1500 miles
epson1 is offline   Reply With Quote
Old 09-23-2012, 01:57 AM   #50
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
i trust d2's ive had em on my civic for years daily drivin and now road raced. never gave me a problem.use to have a 9k f 5k r and switched it to 9k 9k and it holds the track even better. id get them for the frs
IG-Joey_Soul
Old 09-23-2012, 03:36 PM   #51
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Whats the specs on the tires? Rears look nice and beefy.
Tansey86 is offline   Reply With Quote
The Following User Says Thank You to Tansey86 For This Useful Post:
mwjcyber (07-13-2013)
Old 09-24-2012, 05:09 PM   #52
DarrenDriven
NW Region Moderator
Are you talking about my car? Check the link in my sig.
Old 01-26-2013, 04:05 PM   #53
NON-VTEC
Drives: acura integra..brother owns FRS
I have d2 RS coilovers on my Acura integra had them for about two years I avoid big potholes but occasionally you hit a big one...they have held up beautifully, I know you will be happy with them they are awesome, we also just ought a set of their track coilovers for my brothers mk3 supra and stiff is an understatement....and I have driven mine a couple times in the snow all though I don't like to, no rust had them for two years so I think you'll be happy
NON-VTEC is offline   Reply With Quote
Old 08-17-2013, 12:41 AM   #54
trdfrs
Drives: 13' asphalt 6mt, 91' Beams Mr2
Any updates please? I can pick some up for $600 a guy in town sold his car
trdfrs is offline   Reply With Quote
Old 08-18-2013, 05:55 PM   #55
DarrenDriven
NW Region Moderator
Still completely happy with my set. 10,000 miles on them and not a single issue. I haven't yet changed the ride height, but plan to do so soon. Will update again once I have done that.
The Following User Says Thank You to DarrenDriven For This Useful Post:
sdlynx (05-14-2014)
Old 08-26-2013, 12:02 AM   #56
akahenry
akahenry's Avatar
Drives: '18 STi
Darren, I'm dying to wait for an update!
akahenry is offline   Reply With Quote
DG-5 Coilover harajukukei Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-27-2014 04:42 PM
Coilover suspension oxygen Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-27-2012 05:04 PM
NW Coilover Shootout DarrenDriven Northwest 14 07-24-2012 03:12 AM
KSport Kontrol Pro for FR-S/BRZ *PRE-ORDER* from Jordan Innovations! Jordan Innovations Brakes, Suspension, Chassis 4 07-11-2012 07:43 PM
KSport Kontrol Pro!!- Deft Motion StarsGarrador Brakes, Suspension, Chassis 0 07-06-2012 07:42 PM
