Old 06-14-2018, 05:18 PM   #43
JIM THEO
Drives: BRZ 2018
Regarding O2 sensor position, heat wrap well the headers as to keep their high temp and kinetic energy (that helps scavenging exhaust from cylinders) and place the primary O2 at the end of where secondaries mate close to the overpipe.
According to the wideband I had in previous Subarus w/aftermarket headers this place gives the most accurate measurements!
JIM THEO is offline   Reply With Quote
Old 06-14-2018, 05:59 PM   #44
steve99
I think everyone has good points and there is no perfect solution, unless you had one o2 sensor in each runner for each cylinder.
Its best to put it close to exhaust ports
You probably get a more accurate reading by measuring jist one cylimder, but then your ignoring tge other three.
If you measure a mix of all four your likely getting an average reading, or depending on the placement near collector you may srill get a bias toward one or two cylimders as the sensor tip looks very close to collector so gasses likeY not mixed from all cylinders.
If one cylinder was rich\lean you woulnt know which one anyway and if it all moxed in it would need to be way rich or lean before you would notice. Think thier good and bad in each and its not perfect either way, but stock header its after the secong megge collectpr
tomm.brz (06-14-2018)
Old 06-14-2018, 10:31 PM   #45
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
I would be more concerned with trying to extend the sensor wiring. If it reaches with the factory wiring and you aren't pinching the wiring anywhere, then put it wherever you want.
Old 06-15-2018, 01:12 AM   #46
tomm.brz
Drives: brz 2017 hksv2
I think i have problem understanding your answers Wayno
If I put the front sensor on the collector near the overpipe the plug doesnt reach the other plug and that s why hks gave me an extension
What do you mean by "put wherever I want'?
Old 06-15-2018, 01:25 AM   #47
churchx
churchx's Avatar
Drives: 2014 GT86
He wrote "If it reaches". It doesn't, so move on
Old 06-15-2018, 04:27 AM   #48
Kodename47
Kodename47's Avatar
Drives: UK GT86
There is no perfect solution, unless you had one o2 sensor in each runner for each cylinder.
Correct
You probably get a more accurate reading by measuring just one cylinder
Definitely not!!! What if that one cylinder is way richer than every other cylinder, injector goes faulty. Sir, my logs look good but 3 pistons are melted.... Alternatively if that's the lean cylinder then you're running too rich in the rest. Measuring one cylinder alone and using as primary fueling enrichment is a no no and bad advice.
If you measure a mix of all four your likely getting an average reading, or depending on the placement near collector you may srill get a bias toward one or two cylinders as the sensor tip looks very close to collector so gasses likely not mixed from all cylinders.
And that average still helps give an overall picture. You may still have one lean and one rich but it's a better average than doubling up that issue. Think about the math.... 2 cylinders one at 14.0 and one at 15.0 and target at 14.5. At the merge you get 14.5 average reading assuming both reach the sensor at similar times and no correction. However if read on a single cylinder you would get +4.5% fueling correction, causing the rich cylinder to now hit 13.5 or -3.5% meaning you get an AFR 15.5 in the lean cylinder. Rule of thumb, you want as many cylinders merged together for a better picture. Reduce those combined if you add sensors. Really one sensor per pair of cylinders would have been the right balance IMO as we know that there are variances in cylinder fueling from factory.
Yes for the above reason. Measuring all 4 is preferable, 2 is OK but a single runner alone is stupid.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-15-2018, 04:35 AM   #49
tomm.brz
So Those header one guy posted a picture of some post ago, with an integrated spacer in the hole Near the collector.. And i guess the other hole is on a single runner.. Are just bad design header? It forces you to measure only one cilynder
Old 06-15-2018, 04:43 AM   #50
tomm.brz
But actually also the Open Flash Header forces you to put the front sensor in the single runner. Is Shiv giving people bad design header that could potentially break cars?
Old 06-15-2018, 04:50 AM   #51
Kodename47
Kodename47's Avatar
Drives: UK GT86
I personally wouldn't. Each to their own. It's interesting that after having a look about that many UELs are this design, but HKS go out of their way to make you move the sensor. It's not the cheap or simple option.....
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-15-2018, 04:57 AM   #52
tomm.brz
Yes i paid my hks uel More than 1050 euro, almost 1200 dollars I guess. But as far as i know they are the only one doing that.. A bit too bad they arent so great for performance and i think the runners are a bit smaller compared to other aftermarket headers
Do you think I could drill out totally the little cat inside them to hope. For. More performance? This cat is useless anyway, i smell super toxic fumes also when car is totally warmed up
Old 06-15-2018, 06:01 AM   #53
killy
Drives: BRZ Limited
Do you or anyone else here think that a possible solution to this problem is to use the secondary hole with the primary sensor (in THE UEL like the one posted in the photo or OFH)?
To do so you will have to:
1 - grind the height of the spacer in the secondary to match the height of the primary
2 - tapping
3 - make sure that the sensor reaches the hole
not talking about IF it is possible to do the 3 points above, let's assume it is possible.
Would it work? Would the sensor read the flow of all the 4 cylinders merged correctly? does the inclination of the secondary spacer impact on the reading?
killy is offline   Reply With Quote
Old 06-15-2018, 11:12 AM   #54
steve99
2 - tapping
In theory you could do that, you would need extension to the front 02 sensor wiring
you would also want to remove the inclination.
Id also suggest that even if you did all that because the merge collector is so close to 02 bung in most header no matter where you put the sensor its not going to read the average of all cylinders its likely going to sit in the flow of one or two cylinders predominately. might be a bit different if you moved it further downstream of merge like the ft86 speed factory photo
tomm.brz (06-15-2018)
Old 06-15-2018, 11:33 AM   #55
tomm.brz
So actually even in my hks uel the front sensor doesn t sense all 4 cylinders
It looks like only senses one on a shorter runner, did they make me move it with an extension to sense it on a shorter one instead on the longer?
At least in the OFH if one shortens out the spacer, it could possibly move the tip of the sensor more in the middle To try sense all 4 together
Old 06-15-2018, 11:57 AM   #56
Kodename47
Kodename47's Avatar
Drives: UK GT86
So actually even in my hks uel the front sensor doesn't sense all 4 cylinders
It does, the exhaust gasses from the other 2 cylinders won't bypass it and remember the sensor is picking up the oxygen content in the system. It might weight it towards those cylinders, but it's going to be better than just monitoring after the primary collector in a 4-2-1 for example.
[ame=https://www.youtube.com/watch?v=lyv0wh3fsLM]Youtube[/ame]
.: Stealth 86 :.
Kodename 47 DJ:
My Review of Ace A/350 Header & Delicious Tuning Flex Fuel Kit + Tune tomaszjanczak Engine, Exhaust, Transmission 15 09-25-2016 11:06 PM
How much fuel consumption difference: 1 person vs. 2 people djmm Scion FR-S / Toyota 86 GT86 General Forum 19 04-30-2014 04:33 PM
Fuel consumption figures too PuGZoR AUSTRALIA 25 02-16-2014 05:36 PM
Tyre Pressures/Fuel Consumption Vic_RSA AFRICA 11 12-11-2012 01:20 PM
Weight, fuel consumption and 0-100. Loki556 AUSTRALIA 15 07-16-2012 09:06 PM
