Old 04-20-2017, 02:14 PM   #43
allowe
allowe's Avatar
Originally Posted by Detroiter View Post
Wait are you telling me that every gas station in canada doesn't have those? I have never once pumped gas here in Detroit without using one.
Apart from shell, there isn't any other gas station in Canada that has those. Rumours Say they're illegal. Sometimes I wedge my phone between the handle and pump and when it clicks, my phone drops (I got an otter box defender)
allowe is offline   Reply With Quote
Old 04-20-2017, 02:32 PM   #44
Chronology
Drives: 13' Satin White Pearl BRZ
Originally Posted by allowe View Post
Crap I don't want to replace the op :/. Where did you buy your bolts and what size were they if u don't mind me asking
You shouldn't need to replace the actual Overpipe. You will need to drill OUT the bolt that is in place (due to heat). As for bolts, 14mm, I do remember going to the local hardware store to grab replacements. I think I was able to pull one out with adding WD40 and an impact gun, the 2nd bolt was being a PIA so we drilled it out.
Make sure to replace all gaskets with quality ones. I got the Grimmspeed pack.
http://www.grimmspeed.com/grimmspeed...st-gasket-set/
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
The Following User Says Thank You to Chronology For This Useful Post:
allowe (04-21-2017)
Old 04-20-2017, 02:34 PM   #45
Icecreamtruk
Drives: Track preped NA FRS
It is indeed deemed dangerous (not necessarly illegal, but recommended agaisnt). More info here.
Have you seen those videos where people trigger fires while filling up with static shocks and then they proceed to pull the nuzzle out and spread gas + fire everywhere? Well, without locks that will never happen. Initial fire could still happen because of static, but most likely you will either let go of the nuzzle, or pull it from the car and let go of it, in both cases, the gas stops pumping, no more fuel for the fire, so all you get is a slightly burn gas cap.
The Following User Says Thank You to Icecreamtruk For This Useful Post:
allowe (04-21-2017)
Old 04-20-2017, 04:38 PM   #46
allowe
allowe's Avatar
I got oem gaskets brand new they're super cheap. Would the bolts withstand the heat though?
Old 04-20-2017, 06:34 PM   #47
allowe
allowe's Avatar
Got them off easily actually by soaking them with pb blaster, driving around for an hour then soaking them again and waiting for 15 minutes, they came off with no strength but I'm still worried about this
Old 04-20-2017, 06:57 PM   #48
allowe
allowe's Avatar
And this happened to one of the bolts but I'm Guna put thread Locker on it and hope it does the job lol
Old 04-21-2017, 12:38 AM   #49
Chronology
I haven't seen any issues so far, 5 track days and DD the car, I'm normally working on my car twice a month and I do a visual inspection each time.
allowe (04-21-2017)
Old 04-21-2017, 12:42 AM   #50
reeves
Congrats on the new header!
I found alot of that "white" dried liquid stuff on my headers too. Not sure how long its been there or where it dripped from, but I didn't see any leaks from the engine/coolant.
Still trying to figure out what it is. I thought it might just be water condensation, but mine's is literally a long line of drip like something was poured down the side of the engine and dried on the headers.
reeves is offline   Reply With Quote
The Following User Says Thank You to reeves For This Useful Post:
allowe (04-21-2017)
Old 04-21-2017, 12:51 AM   #51
allowe
allowe's Avatar
It's on the bottom of the engine though it kinda looks like oil.
Old 04-21-2017, 01:01 AM   #52
allowe
allowe's Avatar
Thank you all for your help. Taking out the old header was a beeyyach! It wouldn't split between the overpipe and the header. So I gave up trying to pry the 2 out and took off the front pipe off the back back and slid it back. After that everything was a breeze.
The header sounds amazing! That burble is beautiful! It's a bit loud especially at cold start but it sounds so good. I do think I got a leak at the overpipe it sounds like air rushing. I put the ofh2 tune from the website that's made for those headers. It feels more free. It does smell a bit though.
Tune + Headers +e85 Worth it? or wait for FI? brzfl Engine, Exhaust, Transmission 39 08-29-2016 09:55 AM
WTT: Tomei uel headers for EL headers 86Tony Canada Classifieds 6 07-27-2015 10:42 PM
FI worth it? Gt86_nick Forced Induction 62 01-28-2014 01:55 AM
Injen SES Headers/ Agency Power headers Choong86 Engine, Exhaust, Transmission 10 12-27-2013 10:51 PM
Is the FR-S worth getting? DIM Scion FR-S / Toyota 86 GT86 General Forum 60 10-29-2012 12:43 AM
