Old 04-15-2017, 05:38 PM   #43
Tokay444
The drawing says a* is the alignment mark and is 25 degrees counter-clockwise from horizizontal. Is that where you put it?
Old 04-15-2017, 07:34 PM   #44
Kris86
Kris86's Avatar
Drives: RHD Gt86
Originally Posted by Ragin Gti View Post
With the front cover off and the crank in the proper position do the triangle arrows on the cam sprockets line up perfectly?
Yes I verified with the mechanic and aftwr doing the process that they indeed point directly to eachother before performing work on the right head
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 04-15-2017, 08:36 PM   #45
Kris86
Kris86's Avatar
Drives: RHD Gt86
Just found this pic I took of the timing before we installed the engine
After timing the right head I notice the marks on the left head do not align any more, is this correct? I pointed red arrows at them
Then You can see the marks on the right head are pointing straight at eachother tho
Old 04-15-2017, 08:56 PM   #46
Tokay444
You have the service manual. Did you read it?
Old 04-15-2017, 09:18 PM   #47
Kris86
Kris86's Avatar
Drives: RHD Gt86
I have been going through it
I'm not the mechanic, just trying to back check everything one by one WITH my mechanic
My apologies but from what I gathered, when he has installed everything all the marks align perfectly. It is when he spins the crank to cycle the engine is then when the marks go off on the left head
Old 04-15-2017, 09:24 PM   #48
Izzyboost1
Drives: 93 supra turbo auto 13 frs turbo 6
I had the same issue during my forged build . Was off one tooth except on bank 1 intake. I'm very meticulous and not sure how. When I removed timing cover it was like a slap in the face it was so obvious. U my friend are off one tooth. Put back correctly and she popped off and idled perfectly. No damage. Though before I found it I was getting a p0011. Make sure crank position is correct before releasing bank 2 tensioner though. There was a tech tip for timing set up released by toyota on tis if u can find it. If not I could email it to u. Good luck.
Sent from my SM-G900V using Tapatalk
Izzyboost1 is offline   Reply With Quote
The Following User Says Thank You to Izzyboost1 For This Useful Post:
Kris86 (04-15-2017)
Old 04-15-2017, 10:57 PM   #49
Kris86
Kris86's Avatar
Drives: RHD Gt86
Thank you, just sent my mechanic this message
Old 04-15-2017, 11:08 PM   #50
Izzyboost1
Tech tip for chain installation
Old 04-15-2017, 11:17 PM   #51
Izzyboost1
6 and 7
Kris86 (04-16-2017)
Old 04-15-2017, 11:22 PM   #52
Izzyboost1
Tech tip pages 8, 9, and 10
Kris86 (04-16-2017)
Old 04-15-2017, 11:25 PM   #53
Izzyboost1
Tech tip pages 11 -13
Kris86 (04-16-2017)
Old 04-15-2017, 11:27 PM   #54
Izzyboost1
Tech tip page 14
Kris86 (04-16-2017)
Old 04-15-2017, 11:32 PM   #55
Izzyboost1
Hope this helps. If u can't read anything just ask. Tech tip was no longer on tis, so I had to take crude pics of printed version . Enjoy.
Kris86 (04-16-2017)
Old 04-16-2017, 03:06 PM   #56
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Balls.... well kris your going to be a pro at the engine pulling procedure.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
Kris86 (04-16-2017)
AVCS - Intake and Exhaust Timing Kodename47 Software Tuning 274 02-28-2021 12:39 PM
AVCS Explained Rennmeister Engine, Exhaust, Transmission 3 03-15-2016 04:12 AM
AVCS tuning Turdinator Software Tuning 9 11-24-2015 02:31 PM
P000A AVCS check engline light? cookiesowns Issues | Warranty | Recalls / TSB 4 10-24-2015 02:48 AM
AVCS failures? hmong337 Forced Induction 26 02-12-2015 04:01 PM
