Old 03-15-2017, 01:00 AM   #43
humfrz
My old 58 Ford with a 7 year old battery sat for a year and started on the first try. Three days of no start and a dead battery is inconceivable to me.
Maybe that's because the mud daubers had built a nest in the carburetor, holding in the gas fumes; the mice had built a nest in the air cleaner, keeping the engine warm; the rats had chewed through the belts, so no resistance there; the dome light was burnt out; the oil rings had segmented allowing lots of oil on the cylinder walls and the compression rings were shot, reducing the compression ratio to about 5:1.
humfrz
Old 03-15-2017, 01:00 AM   #44
Kaotic Lazagna
Drives: GR Corolla
I would suspect your battery is on it's last cell ...... I'd replace it.
humfrz
Could be possible. The battery does have 54,xxx miles on it now. I'll see where the level is at on the NoCo the next time I charge it.
Old 03-15-2017, 01:02 AM   #45
Kaotic Lazagna
Drives: GR Corolla
But see mine has never even hesitated. Left it for two weeks last winter, came home, jumped in turned key, started right up first crank. That is what baffles me that some have so many issues and others not a problem.
Wonder if those that have issues (like me), have the Smart Key system????
Old 03-15-2017, 01:15 AM   #46
humfrz
You may consider having it load tested.
Personally, I won't mess around with "weak" batteries. Once they stumble, I replace them.
Nothing is worse that being somewhere you're not supposed to be, at some time when you're supposed to be somewhere else, with someone you're not supposed to be there with ....... and your car won't start ......
Did you pick up on that little life hint, there @soulreapersteve ..... ??
humfrz
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Kaotic Lazagna (03-15-2017), soulreapersteve (03-15-2017), Ultramaroon (03-15-2017)
Old 03-15-2017, 02:01 AM   #47
Ultramaroon
not playing cards
Ultramaroon's Avatar
Just like that, from dead batteries to dead hookers.
Smooth.
Hoahao (03-15-2017)
Old 03-15-2017, 10:30 AM   #48
humfrz
First it was Pikachu now it is Steve that you seem to be inviting to a remote place. I am beginning to worry about you.
Old 03-15-2017, 10:31 AM   #49
humfrz
'58 300 two door wagon! I would take that in a heartbeat.
Old 03-15-2017, 11:12 AM   #50
humfrz
I don't know why ....... ??
I gotta go, drop the granddaughters off at their elementary school ....... then hang around the playground, to grab the kids to make sure they stop at the bottom of the slide safely .........
humfrz
Tcoat (03-15-2017), Ultramaroon (03-15-2017)
Old 03-15-2017, 11:12 AM   #51
stevesnj
stevesnj's Avatar
If that draw is real, I'd guess that one of the window motors is not shutting all the way down when the switch is OFF.
humfrz
Good point, I'll have to check that. I'll test it as soon as the weather is tolerable here. Thanks!
My 2016 Build thread
Old 03-15-2017, 11:16 AM   #52
stevesnj
stevesnj's Avatar
Maybe that's because the mud daubers had built a nest in the carburetor, holding in the gas fumes; the mice had built a nest in the air cleaner, keeping the engine warm; the rats had chewed through the belts, so no resistance there; the dome light was burnt out; the oil rings had segmented allowing lots of oil on the cylinder walls and the compression rings were shot, reducing the compression ratio to about 5:1.humfrz
Plus no computer to drain it.
The Following User Says Thank You to stevesnj For This Useful Post:
Old 03-15-2017, 11:16 AM   #53
humfrz
Well, we didn't used to have those problems ........
humfrz
stevesnj (03-15-2017), Ultramaroon (03-15-2017)
Old 03-15-2017, 11:21 AM   #54
stevesnj
stevesnj's Avatar
humfrz
I had a 79 Camaro RS, manual windows, loved that simplicity!
humfrz (03-15-2017)
Old 03-15-2017, 11:53 AM   #55
humfrz
You also got very good at putting windows back on the tracks with the old hand cranks!
Old 03-15-2017, 12:01 PM   #56
stevesnj
stevesnj's Avatar
Haha, jiggle, lift glass and roll up, done!
battery, oem, panasonic, rechargeable, stock
Specs of the STOCK battery?? stevo_12v Electronics | Audio | NAV | Infotainment 74 10-31-2017 04:45 AM
How long does stock battery last without engine on? jon2 Scion FR-S / Toyota 86 GT86 General Forum 15 03-15-2015 09:58 PM
Warning to Canadian owners about stock battery Suberman CANADA 46 03-02-2015 07:28 PM
Panasonic audio/nav switches itself off in the cold! Suberman Electronics | Audio | NAV | Infotainment 0 12-05-2013 08:01 PM
