Old 08-21-2016, 08:29 PM   #43
mmcelroy
Drives: FRS-ULTRA(lol)marine
Originally Posted by Kaotic Lazagna View Post
Injen intake. Didn't see any performance or fuel economy benefits, and made stop and go traffic driving horrible. Sold it after a week of giving it a shot.
aFe Takeda is similar... stop and go is OK, but agreed on the lack on benefits. sounds nice, but without a MAF tune, not going to see anything else.
mmcelroy is offline   Reply With Quote
Old 08-21-2016, 09:20 PM   #44
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Agree with Intake mod.
I have an aFe Takeda and there's nothing wrong with it, but for the price I should have just got a drop in filter. Especially seeing as I'm going to probably put the stock intake back on when I supercharge anyhow.
Wise is offline   Reply With Quote
Old 08-21-2016, 11:40 PM   #45
Chanpion
Drives: 13 FRS Satin
Red rally flaps with stock width wheels. Just looked weird proportion and colour wise. The winter benefits were amazing though so much mud, slush, snow, ice and salt block. Took them off after the winter season, back to stock splash guards. I just deal with the spray when I hit the gravel roads, which is quite a bit.
Chanpion is offline   Reply With Quote
Old 08-21-2016, 11:46 PM   #46
phantasticity
Ricer
Installing 1320 perf header, broke o2 sensor, had to buy new one of dealer, dealer gave me fcked sensor. Can't return. Fun time.
phantasticity is offline   Reply With Quote
Old 08-22-2016, 12:11 AM   #47
Wise
Circle Work Clerk
My 17x9 Enkei RPF1 wheels.
Don't get me wrong I like the way they look. But I miss the flowy light feeling that you don't get now with a 235 or 245 tyre.
When I get a chance I'm probably going to sell the Enkei's and pick up some OZ Ultraleggera 17x8s and run a 225 summer tyre.
The Following 8 Users Say Thank You to Wise For This Useful Post:
bhmax (08-22-2016), freerunner (11-04-2016), funwheeldrive (08-22-2016), kev60625 (08-22-2016), mixtape (08-22-2016), MJones_RB (08-22-2016), Mr.Impreza (08-23-2016), NLSP (08-22-2016)
Old 08-22-2016, 12:55 AM   #48
Kaotic Lazagna
Drives: GR Corolla
Originally Posted by weederr33 View Post
A high flow air filter was the best decision compared to an intake
Yeah, I went from a K&N drop in to that Injen, and back to the K&N drop in. Haha
Old 08-22-2016, 12:56 AM   #49
Kaotic Lazagna
Drives: GR Corolla
I didn't even really notice a sound change with the Injen, unlike the K&N Typhoon SRI I had on my Yaris.
Old 08-22-2016, 01:28 AM   #50
imaguitar
imaguitar's Avatar
Drives: Scion FRS - Hot Lava
Wait how did an intake make stop & go traffic driving horrible?
imaguitar is offline   Reply With Quote
Old 08-22-2016, 01:43 AM   #51
kev60625
Drives: 2013 WRB Subaru BRZ
I have 18x7.5s on 225's. Feeling is still nimble and light
The wheels weigh under 14lbs so that's also probably why, though.
kev60625 is offline   Reply With Quote
Old 08-22-2016, 02:33 AM   #52
Kaotic Lazagna
Drives: GR Corolla
Heat soak severely reduced throttle response and acceleration. My intake temp reading via my Scan Gauge II actually read much higher with the Injen intake. I can't remember the exact readings, but in stop and go traffic, I believe it was easily 20 to 30 degrees higher than the stock box with K&N drop in. I could floor it in 1st gear, and the engine will hesitate. RPM's would go up, and then the engine would act like it's about to stall, then repeat. Car doesn't move forward. So not only did it make stop and go horrible since the car would only move forward with only a slight throttle at most, I felt unsafe since I wouldn't be able to get out of the way in an emergency.
The Following 2 Users Say Thank You to Kaotic Lazagna For This Useful Post:
imaguitar (08-22-2016), lantsalot (08-22-2016)
Old 08-22-2016, 06:03 AM   #53
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Getting it undercoated
headlikeahole is offline   Reply With Quote
The Following User Says Thank You to headlikeahole For This Useful Post:
Old 08-22-2016, 06:22 AM   #54
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Lightweight crank pulley. Complete waste of money
This was puzzling me a bit for some time. There is a reputable company in Japan saying that a lightweight crank pulley kit works and there are users saying the same like you. That it is a complete waste of money.
I tried to model the weight reduction of a LWP and calculate the gains from the moment of inertia. Fact is that the gains are very small to be noticable. However, the claims of the Japanese company are not wrong.
Here is some conclusions:
- You need to change the pulleys with a stiff material. Original pulleys are made from cast iron and they deform slightly with rotation. You can imagine material deformation as an additional parameter in the moment of inertia law. Only the OEM crank pulley might deform much more, because of the included rubber structure. Companies are using for the LWP the cheap 6061 aluminum with a yield strength of 240 MPa. This material seems to not provide enough stiffness. There is a much harder aluminum with a yield strength of 500 MPa, but it is very expensive.
- You need a kit of at least 3 pulleys (crank, alternator, water) and not just a crank pulley. Companies are providing usually only the crank pulley because it is cheaper and easier to install.
- You need to under-drive the system. Usually, this can be done with under-driving the alternator.
My findings were that each of the above can provide small gains and all of them in combination could provide a sufficient gain which is noticeable. Fact is that very few manufacturers provide such solution.
The Following 2 Users Say Thank You to nikitopo For This Useful Post:
daiheadjai (08-22-2016), Omi Ham-Sandwich (12-27-2016)
Old 08-22-2016, 06:53 AM   #55
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Getting slightly curious and performing the exhaust pops and backfire mod:
http://www.ft86club.com/forums/showthread.php?t=61069
Finally the dream of sounding like a Huracan or F-type will come true...
Reverted the tune after 72 hours.
dhuang is offline   Reply With Quote
The Following User Says Thank You to dhuang For This Useful Post:
FLESH KILLA (08-29-2016)
Old 08-22-2016, 08:08 AM   #56
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Yea that bad?
-Josh
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
dhuang (08-22-2016)
What is the worst looking FRS/BRZ ever? TRD-X Scion FR-S / Toyota 86 GT86 General Forum 438 02-03-2015 08:58 PM
Worst Comparison Ever... RockTown07 Scion FR-S / Toyota 86 GT86 General Forum 26 05-06-2014 02:31 PM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
The worst looking wheels ever? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 10-08-2012 05:52 PM
Top 10 worst car deals, really? drifter BRZ First-Gen (2012+) — General Topics 20 08-23-2012 06:53 PM
