Old 07-24-2013, 03:39 PM   #43
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
I am adding your install information to the front page of this topic so others can use it. Thanks!!!
Makes life a LOT easier, right?
Old 07-24-2013, 03:53 PM   #44
ML
ML's Avatar
Drives: 13 White MT FR-S
So would you just put a switch between ground if you wanted to add one?
Old 07-24-2013, 04:41 PM   #45
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Good thread. I actually have a couple of the timed relays that Darren used laying around from another project, tied to throttle switch and opened,closed electric cutouts at WOT when the circuit was active.
The newer relay looks like a much cleaner solution though.
FRSFirestorm is offline   Reply With Quote
Old 07-24-2013, 05:16 PM   #46
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Yes you would wire it inline on the ground to the ebrake connection.
2superblus is offline   Reply With Quote
Old 07-24-2013, 05:37 PM   #47
mtimney
mtimney's Avatar
Drives: 2013 BRZ Limited
Would it be possible to for the author to edit this thread so that the instructions are not spread out--talking about what didn't work and what had to be changed later-- and all put into one set of directions?
Perhaps I'm a little dense, but I'm confused now about what parts are really needed and exactly how this is done.
I think this is a great idea for people who Auto-X, as it's all too easy to forget to do the 'pedal dance'!
mtimney is offline   Reply With Quote
Old 07-24-2013, 11:01 PM   #48
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Use post #42 for the new simple switch and the post on page one for pictures.
Old 07-24-2013, 11:35 PM   #49
Suberman
Drives: Subaru BRZ Sport Tech Satin White
It would be preferred if the traction control switch default was "off" like the winter setting for the automatic. However, even Ferrari uses the default "on" for its manettino. But I think Ferrari allows you to switch off with the manettino at any position.
Still, for daily driving it can be safer to default to stability control on. I have experienced its nanny action in a positive way on occasion.
Suberman is offline   Reply With Quote
Old 07-27-2013, 05:55 PM   #50
DarrenDriven
NW Region Moderator
I made @2superblus's link VERY prominent at the beginning of my DIY now.
As for my DIY, there is nothing extra in there, all steps are required.
Old 08-15-2013, 04:22 PM   #51
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
I hope more folks give this a go as it has become my favorite DIY installs
Old 08-15-2013, 04:39 PM   #52
xjohnx
Grip>Slip
xjohnx's Avatar
Unless I misunderstand this post, this doesn't simulate the pedal dance for you, it only simulates the 3-5 second traction control disable push. I'm pretty sure the pedal dance goes one step further at disabling things.
Old 08-15-2013, 04:42 PM   #53
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
You are correct. however the pedal dance does incur other oddities once enabled when driving at the limits and not braking in a straight line.
Old 08-15-2013, 04:45 PM   #54
qoncept
qoncept's Avatar
What?
qoncept is offline   Reply With Quote
Old 08-15-2013, 05:34 PM   #55
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
The pedal dance just put's it in a testing mode.
Yes, other odd things have happened with the braking system when the pedal dance has been done/enabled. Feedback has been given from guys using the
car for track days and autocross. More people have run into what could be referred to as a Ice mode when the pedal dance has been done.
http://www.ft86club.com/forums/showt...t=25494&page=7
Old 08-15-2013, 07:29 PM   #56
DarrenDriven
NW Region Moderator
Link to pedal dance?
brake override DOES NOT diminish heel & toe 4agze Scion FR-S / Toyota 86 GT86 General Forum 31 09-17-2012 05:43 AM
Permanent Optimum opti-coat 2.0 ?? Ericfrs Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 09-04-2012 03:11 AM
LF: rear fog switch picture Silverdub Scion FR-S / Toyota 86 GT86 General Forum 6 06-28-2012 09:34 AM
Anyone going to switch badges? DougieFresh Scion FR-S / Toyota 86 GT86 General Forum 60 09-28-2011 03:56 AM
Brake override system in the FT-86? mrKiKaZ Scion FR-S / Toyota 86 GT86 General Forum 10 02-22-2010 12:33 PM
