#43 |
Drives: 2016 Oceanic, "base" model
#44 |
Drives: ̶1̶0̶ ̶S̶
#45 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Does look rice because you can see it. If it were black but when turned on bright lights then itd be cool. Incognito.
Incog-nah-ee-toe Subtetly
#46 |
Drives: 2013 Frs
#47 |
Drives: '15 BRZ
I agree with the previous posts. Ricey if it's visible, though you are doing it for functional reasons. Cdamzero's setup looks pretty good.
#48 |
Drives: 2013 Frs
#49 |
Drives: none =[[
#50 |
Drives: '13 FR-S
#51 |
Drives: 2013 Frs
Outside lights off
#52 |
Drives: stx class lava frs
#53 |
#54 |
Drives: 2013 Frs
Not of the road ahead. They are bright enough to drive without lights at all though. There are 66 high intensity LED's and 66 270k ohm resistors hand soldiered and 66 individual holes I drilled in the front plastic grille with LED holders in each hole. The LED sets of 3 go to a main wire buss which is connected to a relay with a simple on/off switch inside. I put release connectors on the main buss wires in case I need to remove the bumper. I will try to post some pictures of what you requested soon.
#55 | |
I can tell you that the one I have is INCREDIBLY bright. even with the headlights off it is far brighter than the factory high beams. with everything lit up it feels like you can see forever. the lights on the end of the bar are floodlights as well, that do a pretty good lighting up the shoulder of the road.
We don't really get deer here in So Cal, but it would be ideal for anyone who lives in the midwest where they are more of a problem. Quote:
#56 |
Drives: 2013 Frs
The deer here in Ky, let's just say 95% of any car that hits one is totaled. Also made a custom 5th brake light, but not for the deer.
| ABS + Traction Light After Fog Install | Wyattkb | Issues | Warranty | Recalls / TSB | 1 | 03-22-2015 05:47 PM |
| eBay fog light install? | irocz0r | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 07-18-2014 09:12 PM |
| Spyder fog light install help | ghost86 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 02-09-2014 06:07 PM |
| Airbag light on after mod install | SurfAndSand | Engine, Exhaust, Transmission | 1 | 10-23-2013 10:50 AM |
| OEM Fog Light install! ON and working! | 86design | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 38 | 07-04-2012 07:11 PM |
