05-29-2015, 12:52 PM | #519 |
Shadetree Project Ratchet
Drives: series.Blue
If I wasn't at work, I'd be posting the 'O' face gif right now.
The Shadetree Project: I turn wrenches
05-29-2015, 02:38 PM | #520 | |
Drives: '14 981CS, '99 NB1
The Following User Says Thank You to johan For This Useful Post: | civicdrivr (05-29-2015) |
05-29-2015, 02:41 PM | #521 | |
The Following User Says Thank You to wparsons For This Useful Post: | civicdrivr (05-29-2015) |
05-29-2015, 02:44 PM | #522 | |
Drives: 2018 Golf R
Sent from my XT1095
Parting out HERE
05-29-2015, 03:42 PM | #524 | |
Drives: '13 Raven FR-S, MT
. ck |
05-29-2015, 03:45 PM | #525 |
Off Topic
I would expect that the velocity of the air inside the manifold pretty much negates any potential for heat soak. The air isn't in contact with the manifold long enough to transfer a significant amount of heat from the metal.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post: | civicdrivr (05-29-2015), phobos512 (05-29-2015) |
05-29-2015, 04:07 PM | #526 |
Also, aluminum doesn't "soak" up heat.. it dissipates it effectively, hence why heat sinks are made out of aluminum, to get rid of the heat quickly. Steel would soak it up and hold onto it.
The Following 4 Users Say Thank You to fika84 For This Useful Post: |
05-29-2015, 04:11 PM | #527 | |
. ck |
05-29-2015, 05:35 PM | #528 |
Drives: 2014 GT86
Problem with metals is that they all are very good heat conductors relative to plastics. Hence if heat soak was issue, i guess that both steel or aluminium won't fix issue much. "Dissipates heat well" can as well work other direction, "absorbs/soaks heat well", depending on temperature gradient. So no, while steel might be a bit worse conductor, it won't be worse in only one direction unless magic is involved. And as due it's strength and weight it most probably will be thinner, that might offset it's worse heat conducting per same material thickness. Most often aluminium is used only because of material price, weight and cheaper tooling to work on. Once rads on cars were mostly made of copper, even better heat conductor (from normal metals 2nd best after silver). It changed to alu in more recent cars mostly because copper spiked in price, not because it weighted more. Price difference of 2-3 times is a lot in eyes of corporate beancounters looking where to make some savings on car that is passed to them by engineers.
The Following User Says Thank You to churchx For This Useful Post: | Hyper4mance2k (05-30-2015) |
05-29-2015, 05:35 PM | #529 |
That Guy
Drives: 2013 asphalt FRS MT
It would be more accurate to say aluminum conducts heat more efficiently. Which means it would transfer more heat to the incoming air than would steel. Not that anyone wants a boat anchor steel intake manifold. And as was mentioned the heat transfer is likely negligible even with aluminum.
05-29-2015, 08:50 PM | #530 |
Drives: '22 BRZ
Having tuned my GTI with & without a metal intake tube housing my IAT, there's very good reasons to not use metal for an intake... Properly reinforced plastic would likely be prohibitively expensive for this relatively small volume piece though.
05-29-2015, 09:35 PM | #531 | |
Drives: BRZ, STI, GT350R, Supra, 987.2
These are headed my way to test. Using logs and virtual dyno I should be able to deduct which set is best for NA and go to the dyno with that set. Please be patient as we are all dying to know how it does as well . |
The Following 6 Users Say Thank You to VerusEric For This Useful Post: | Captain Snooze (05-29-2015), civicdrivr (05-29-2015), D_Thissen (07-04-2015), fika84 (05-30-2015), Hyper4mance2k (05-30-2015), solidONE (05-29-2015) |
05-29-2015, 10:02 PM | #532 |
Drives: 2014 Subaru BRZ Ltd.
Those ridges look intentional. Do they serve a purpose?
*question everything*learn something*answer nothing*
Similar Threads | ||||
FT-86 SpeedFactory LCA by Verus - Lightest LCA for the Twins - Development Thread | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 236 | 06-20-2019 01:42 PM |
Intake Manifold | Bu-Tang | Engine, Exhaust, Transmission | 29 | 12-06-2014 01:43 PM |
Intake manifold | viking | Engine, Exhaust, Transmission | 6 | 09-23-2014 11:08 PM |
Oil on/around Intake Manifold | Wepeel | Issues | Warranty | Recalls / TSB | 2 | 05-12-2014 11:40 PM |
WTB: intake manifold | carlitosway6891 | Engine, Exhaust, Bolt-Ons | 0 | 06-22-2013 02:24 PM |
