Old 05-29-2015, 07:20 AM   #505
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
"D" is for Do it!
"Y" you know you want to
"N" No, don't be shy
"O" is the expression when we see the charts
Captain Snooze is offline
The Following 3 Users Say Thank You to Captain Snooze For This Useful Post:
2much (05-29-2015), civicdrivr (05-29-2015), HUNTERANGEL121 (05-29-2015)
Old 05-29-2015, 12:52 PM   #506
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
"D" is for Do it!
If I wasn't at work, I'd be posting the 'O' face gif right now.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline
Old 05-29-2015, 02:38 PM   #507
johan
Drives: '14 981CS, '99 NB1
Originally Posted by boredom.is.me View Post
They can machine from a translucent plastic and have the LEDs inside! Delrin/Acetal may be up to the task.
That actually gave me a decent thought. Is there any particular reason for going with whatever material you chose? You could probably knock a little weight off with an appropriate plastic.
If it were plastic, I would not buy it. Half my motivation for getting an aftermarket IM is to get the ugly ass plastic abomination out of my engine bay.
johan is offline
The Following User Says Thank You to johan For This Useful Post:
Old 05-29-2015, 02:41 PM   #508
wparsons
wparsons's Avatar
Plastic + lots of boost isn't friendly, regardless of what plastic you use. For N/A you're fine.
flickr
wparsons is offline
Old 05-29-2015, 02:44 PM   #509
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
This. While plastic may not hold the heat the way an aluminum manifold does, I'd rather have the comfort of knowing it can withstand the additional pressure.
Sent from my XT1095
Parting out HERE
civicdrivr is offline
Old 05-29-2015, 03:34 PM   #510
IBill4You
Drives: 2015 Subaru BRZ
Can I buy this yet? Full polished and I'll plastidip it I I decide I want color
IBill4You is offline
Old 05-29-2015, 03:42 PM   #511
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Sent from my XT1095
Couldnt the aluminum potentially soak up a lot of heat from the engine though?
. ck
|| My Build Thread ||
ck-GT86 is offline
Old 05-29-2015, 03:45 PM   #512
gramicci101
Off Topic
I would expect that the velocity of the air inside the manifold pretty much negates any potential for heat soak. The air isn't in contact with the manifold long enough to transfer a significant amount of heat from the metal.
gramicci101 is offline
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
civicdrivr (05-29-2015), phobos512 (05-29-2015)
Old 05-29-2015, 04:07 PM   #513
fika84
fika84's Avatar
Also, aluminum doesn't "soak" up heat.. it dissipates it effectively, hence why heat sinks are made out of aluminum, to get rid of the heat quickly. Steel would soak it up and hold onto it.
fika84 is offline
The Following 4 Users Say Thank You to fika84 For This Useful Post:
civicdrivr (05-29-2015), ck-GT86 (05-29-2015), Hyper4mance2k (05-30-2015), Porcupint (05-29-2015)
Old 05-29-2015, 04:11 PM   #514
ck-GT86
ck-GT86's Avatar
Ah, thanks for explanation. Disregard my comment then.
. ck
|| My Build Thread ||
ck-GT86 is offline
Old 05-29-2015, 05:35 PM   #515
churchx
churchx's Avatar
Drives: 2014 GT86
Problem with metals is that they all are very good heat conductors relative to plastics. Hence if heat soak was issue, i guess that both steel or aluminium won't fix issue much. "Dissipates heat well" can as well work other direction, "absorbs/soaks heat well", depending on temperature gradient. So no, while steel might be a bit worse conductor, it won't be worse in only one direction unless magic is involved. And as due it's strength and weight it most probably will be thinner, that might offset it's worse heat conducting per same material thickness. Most often aluminium is used only because of material price, weight and cheaper tooling to work on. Once rads on cars were mostly made of copper, even better heat conductor (from normal metals 2nd best after silver). It changed to alu in more recent cars mostly because copper spiked in price, not because it weighted more. Price difference of 2-3 times is a lot in eyes of corporate beancounters looking where to make some savings on car that is passed to them by engineers.
churchx is offline
Old 05-29-2015, 05:35 PM   #516
Calum
That Guy
Drives: 2013 asphalt FRS MT
It would be more accurate to say aluminum conducts heat more efficiently. Which means it would transfer more heat to the incoming air than would steel. Not that anyone wants a boat anchor steel intake manifold. And as was mentioned the heat transfer is likely negligible even with aluminum.
Calum is offline
The Following 3 Users Say Thank You to Calum For This Useful Post:
fika84 (05-30-2015), nelsmar (05-30-2015), s2d4 (06-01-2015)
Old 05-29-2015, 08:50 PM   #517
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Having tuned my GTI with & without a metal intake tube housing my IAT, there's very good reasons to not use metal for an intake... Properly reinforced plastic would likely be prohibitively expensive for this relatively small volume piece though.
DocWalt is offline
Old 05-29-2015, 09:35 PM   #518
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
You intake temps probably sky rocketed at cruising/idle speeds but at WOT I would be willing to bet they were close to what they were before. I could be very wrong though. Properly designed plastic pieces are extremely expensive like you said. Most of that cost is in tooling though.
These are headed my way to test. Using logs and virtual dyno I should be able to deduct which set is best for NA and go to the dyno with that set. Please be patient as we are all dying to know how it does as well .
VerusEric is offline
The Following 6 Users Say Thank You to VerusEric For This Useful Post:
Captain Snooze (05-29-2015), civicdrivr (05-29-2015), D_Thissen (07-04-2015), fika84 (05-30-2015), Hyper4mance2k (05-30-2015), solidONE (05-29-2015)
FT-86 SpeedFactory LCA by Verus - Lightest LCA for the Twins - Development Thread FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 236 06-20-2019 01:42 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Intake manifold viking Engine, Exhaust, Transmission 6 09-23-2014 11:08 PM
Oil on/around Intake Manifold Wepeel Issues | Warranty | Recalls / TSB 2 05-12-2014 11:40 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
