Old 01-20-2016, 01:36 PM   #519
PantsDants
Drives: Scion FR-S A/T, Whiteout
To my understanding, Knock Correction Advance Max A is the amount of timing the ECU is allowed to pull in response to knock for a given load/RPM cell. Setting it to zero may actually prevent the ECU from responding to knock at all, even though the events are still occurring. Remember, the parameters that we log, FBKC and FLKC, aren't the knock events themselves; they're the ECU's response to what it thinks is a knock event (FLKC is a bit different, but the logic still applies). Just because you don't see those parameters logged anymore doesn't necessarily mean knock isn't still occurring.
Said another way, the total ignition timing is the sum of Knock Correction Advance Max A and Base Timing A/B (B is what's normally used; I think A is for limp-home or post-start, not sure which). There are probably some other compensations applied as well. You can achieve the same effect you're going for by rescaling the load axis on Base Timing B and removing timing from there. Since it looks like you're pulling 6 degrees total, I'd go ahead and pull 3 from Base Timing B and 3 from Knock Correction Advance Max A in the affected cells. That way, you still have some headroom in Knock Correction Advance Max A for the ECU to pull timing in response to knock. It may actually reveal that it's still knocking in that range.
PantsDants is offline   Reply With Quote
Old 01-21-2016, 12:57 PM   #520
KoolBRZ
KoolBRZ's Avatar
OK, someone had to do it!
Here is my prototype rescaled Base Timing B table. It goes up to 4.0 Engine Load because I've logged up to 3.82 Engine Load. Now timing can be pulled from wherever knock is coming from. Load columns 1.4 through 4.0 are all the same, so far. That is where I'll be making most of my changes. I'm also trying a rescaled BTB table with a smoother transition. That's the 2nd pic.
If I say yes, will that make you think I understand?
Old 01-22-2016, 07:36 PM   #521
KoolBRZ
KoolBRZ's Avatar
BTB table Update
Here's my current Base Timing B table compared to the table, above, that I started with. You can see how much timing I've pulled from it so far. It's quite a lot. More than I expected anyway.
Old 01-24-2016, 04:37 PM   #522
stevo585
Drives: White 2014 BRZ
The load only goes to 1.7 or so. No need to go past 2.0. I have 1.3, 1.4, 1.5, 1.6, etc on my Ecutek tune for better resolution. I suggest this.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 01-24-2016, 05:03 PM   #523
KoolBRZ
KoolBRZ's Avatar
No
I have pulled timing because of engine knock that only occurs above 2.0 Engine Load. Look at my post above. I've logged up to 3.82 Engine Load, so I rescaled to 4.0. Both BTB, and KCA tables should be rescaled up to 4.0, so the ECU can compensate accordingly.
Old 01-24-2016, 07:29 PM   #524
stevo585
Well I'm pretty sure it's maf voltage I'm referring to. Maybe I'm wrong not sure. Anyways a reputable tuner told me the Fa20 does not like high load deltas. As in they will knock badly. Be careful.
Either way your resolution is terrible maybe your limited by Rom Raider idk.
Old 01-24-2016, 07:35 PM   #525
stevo585
On another topic what kind of pcv and catch can systems do you guys run. Right now I have nothing...
Old 01-24-2016, 07:41 PM   #526
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
I'm running the mishimoto catch can. As for the check valve.... I can't remember the company and it wasn't cheap for a check valve.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
stevo585 (01-25-2016)
Old 01-27-2016, 12:33 PM   #527
KoolBRZ
KoolBRZ's Avatar
KNOCKLESS
Here are my latest rescaled KCA and BTB tables. Knockless, so far, so they probably need more timing advance.
Old 01-27-2016, 12:34 PM   #528
Lord09
Drives: 2015 BRZ
My ESC for sale: http://www.ft86club.com/forums/showthread.php?t=100623
Lord09 is offline   Reply With Quote
Old 01-27-2016, 10:16 PM   #529
stevo585
I'm able to run 22.x degrees at redline, 28 through the midrange with afr around 11.8 if that helps. On 93 octane. This was my knock wall.
Old 01-28-2016, 01:37 AM   #530
KoolBRZ
KoolBRZ's Avatar
Can you post a pic of your BTB table?
Old 01-28-2016, 01:52 AM   #531
DAEMANO
Time Traveller
Also running the Mishimoto catch can. The check valve is from a company called Boomba
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
Sojhinn (01-28-2016), stevo585 (01-29-2016)
Old 01-29-2016, 01:40 PM   #532
stevo585
If I could data log I would. When I do eventually get my own ecutek cable I will.
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
