#519 |
Drives: Toyota GT86
Tactrix emailed and support request created on their support manager. Fingers crossed for a reply since my previous query was acknowledged by the software but no followup. I know they're small so maybe on holiday etc.
Looking forward to checking IAM and MAF scaling once the logger works - will use your helpful links !!!! Rgds Steve |
#520 | ||
Drives: GT86
Thank you anyway, Steve. |
#521 |
Drives: GT86
Quick update:
the Tactrix guys have isolated an issue in the current firmware and are working on a fix. |
#522 |
Drives: 2013 Hot Lava FRS
I am trying to use ecu flash to remove a brzedit tune on my ECU, so i can flash ecutek. I am using ZA1JF40C bin file, and have all the definition XML and 32bitbase files in the right place, but i still get an unknown definition error when opening the rom.
Any ideas? |
#523 | |
ecutek cannot read\write to brz edit and vice versa. Both can be unlocked by using the current tune platform to write back a stock rom to ecu. Ie use brzedit to write back a stock rom to car to unlock it. you need to find a brzedit tuner to do this or buy a copy of brzedit to do it yourself, its about $100 for a single licience version and uses tactrix to write, talk to the brzedit guys for exact proceedure that will need to provide you with a stock brzedit format rom to write to ecu as their roms are encrypted you cannot use the standard roms |
#524 | |
I have a tactrix, and my brzedit tuner is quite a ways away, and right now I can't get the car to him due too turbo installation without a proper tune. |
#525 | |
you need brz edit to unlock the ecu, so you either get your original brz edit tuner to flash back a stock rom with brzedit or you buy a copy of brzedit yourself and flash back axstock rom supplied by brz edit. once you do that the ecu seed keys are returned to standard and other flashing platforms can access ecu. i think ecutek guys in uk can unscramble it but you might have to send ecu to them. it sucks but that the way it is. the standard stock roms and ecuflash are no use to you untill you get rid of the brzedit locks same deal with ecutek once flashed you locked to ecutek till you flash back a stock rom with ecutek also your 2013 car wont be F40C rom thats for 2016 cars if your manual 2013 it likely B01C, flashing an incorrect rom will cause you other problems, but will not solve your current problem due locked ecu |
| The Following User Says Thank You to steve99 For This Useful Post: | SirSpectre (05-04-2016) |
#526 |
Well that really sucks. Also, the ROM that @DeliciousTuning sent me was F40C, Should I contact them and get B10C?
#527 | |
#528 | |
Drives: GT86
edit: I wonder if they assigned the same issue number as mine to your request. |
#529 | |
Road-hole
Drives: 2013 Whiteout FR-S
I just got the same issue, it's bullshit...
Jaden p.s. I mean at the least they should release an older firmware version with a newer date and code so we can at least be up and running again... Ok I submitted a support request. Personally I'd prefer they just get live logging working...and then not have to worry about the stinking stand alone logging. Last edited by Jaden; 05-16-2016 at 12:12 PM. |
#530 |
did you get yours working with the older ecuflash version ?
#531 |
Drives: GT86
Unfortunately not. Firmware upgrade is forward-only.
Maybe it's possible to circumvent the version check with a hex-edited firmware blob? On another thought I don't want to brick my device. |
#532 | |
would be nice if they just put out a quick fix though |
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 12:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 08:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 10:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 07:27 AM |
