Old 04-11-2016, 06:00 PM   #519
SteveGT86
Drives: Toyota GT86
Tactrix emailed and support request created on their support manager. Fingers crossed for a reply since my previous query was acknowledged by the software but no followup. I know they're small so maybe on holiday etc.
Looking forward to checking IAM and MAF scaling once the logger works - will use your helpful links !!!!
Rgds
Steve
SteveGT86 is offline   Reply With Quote
Old 04-11-2016, 06:05 PM   #520
freerunner
freerunner's Avatar
Drives: GT86
Originally Posted by SteveGT86 View Post
I too am having logging problems using same firmware revision as freerunner.
At least I'm not the only one. I've begun to doubt me.
looks like a bug in tactrix firmware.
Please contact the Tactrix support guys at www.tactrix.com
If both of you guys contact tactrix it should get sorted pretty quick, they are usually very good considering their is only two guys in the company ;-)
Email sent. I'll keep you up to date if any news pop up.
Thank you anyway, Steve.
freerunner is offline   Reply With Quote
Old 04-12-2016, 02:12 PM   #521
freerunner
freerunner's Avatar
Drives: GT86
Quick update:
the Tactrix guys have isolated an issue in the current firmware and are working on a fix.
The Following 3 Users Say Thank You to freerunner For This Useful Post:
EAGLE5 (04-12-2016), phrosty (04-18-2016), steve99 (04-12-2016)
Old 05-03-2016, 06:03 PM   #522
SirSpectre
Drives: 2013 Hot Lava FRS
I am trying to use ecu flash to remove a brzedit tune on my ECU, so i can flash ecutek. I am using ZA1JF40C bin file, and have all the definition XML and 32bitbase files in the right place, but i still get an unknown definition error when opening the rom.
Any ideas?
SirSpectre is offline   Reply With Quote
Old 05-03-2016, 06:46 PM   #523
steve99
Drives: FT86
Any ideas?
BrzEdit like Ecutek locks the ecu by changing the seed keys so other tuning platforms cannot read or write to ecu.
ecutek cannot read\write to brz edit and vice versa.
Both can be unlocked by using the current tune platform to write back a stock rom to ecu.
Ie use brzedit to write back a stock rom to car to unlock it.
you need to find a brzedit tuner to do this or buy a copy of brzedit to do it yourself, its about $100 for a single licience version and uses tactrix to write, talk to the brzedit guys for exact proceedure that will need to provide you with a stock brzedit format rom to write to ecu as their roms are encrypted you cannot use the standard roms
Old 05-03-2016, 11:09 PM   #524
SirSpectre
I understand that. But what you are saying is I can't flash one of these roms without brzedit? My new tuner said brzedit needs to be 100% gone to flash ecutek. The roms listed won't help me?
I have a tactrix, and my brzedit tuner is quite a ways away, and right now I can't get the car to him due too turbo installation without a proper tune.
Old 05-04-2016, 02:31 AM   #525
steve99
Drives: FT86
Correct as per previous post brz edit lock the ecu so only brz edit can read or write to ecu.
you need brz edit to unlock the ecu, so you either get your original brz edit tuner to flash back a stock rom with brzedit or you buy a copy of brzedit yourself and flash back axstock rom supplied by brz edit. once you do that the ecu seed keys are returned to standard and other flashing platforms can access ecu.
i think ecutek guys in uk can unscramble it but you might have to send ecu to them.
it sucks but that the way it is.
the standard stock roms and ecuflash are no use to you untill you get rid of the brzedit locks
same deal with ecutek once flashed you locked to ecutek till you flash back a stock rom with ecutek
also your 2013 car wont be F40C rom thats for 2016 cars if your manual 2013 it likely B01C, flashing an incorrect rom will cause you other problems, but will not solve your current problem due locked ecu
SirSpectre (05-04-2016)
Old 05-04-2016, 02:20 PM   #526
SirSpectre
Well that really sucks. Also, the ROM that @DeliciousTuning sent me was F40C, Should I contact them and get B10C?
Old 05-04-2016, 07:45 PM   #527
steve99
Drives: FT86
Yes i think you should, if your car is 2013 then its stock rom was likely B01C, so definitely confirm with them that they sent you correct rom as F40C is for MY 2016 cars and may not be compatable with your car if its 2013
Old 05-16-2016, 11:06 AM   #528
freerunner
freerunner's Avatar
Drives: GT86
Rgds
Steve
Have you received any response from Tactrix yet? My issue is rotting in their bug tracker for over a month at this point of time.
edit: I wonder if they assigned the same issue number as mine to your request.
Old 05-16-2016, 11:55 AM   #529
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
I just got the same issue, it's bullshit...
It automatically updated the firmware without asking and now won't create any log files at all. It was driving me insane. It gives me a logcfg.out, but no CSV's...ARRRGGHHH...
Jaden
p.s. I mean at the least they should release an older firmware version with a newer date and code so we can at least be up and running again...
Ok I submitted a support request. Personally I'd prefer they just get live logging working...and then not have to worry about the stinking stand alone logging.
Jaden is offline   Reply With Quote
Old 05-16-2016, 06:26 PM   #530
steve99
Drives: FT86
did you get yours working with the older ecuflash version ?
Old 05-16-2016, 06:37 PM   #531
freerunner
freerunner's Avatar
Drives: GT86
Unfortunately not. Firmware upgrade is forward-only.
Maybe it's possible to circumvent the version check with a hex-edited firmware blob? On another thought I don't want to brick my device.
Old 05-16-2016, 06:58 PM   #532
steve99
Drives: FT86
yeah thought that would be the case, luckly mines still running the older version and working
would be nice if they just put out a quick fix though
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
