#5223 | |
Drives: Fiat Abarth
Phantom Supercharged BRZ | 205WHP / 185WTQ Nameless FP/OP Combo |
#5224 | |
Drives: DGM BRZ 6MT
For example, if a track has 3 straights (two short ones and a long one), but the controller will overheat after one or two laps, I might want to only activate the ESC through the long straight to prevent it from overheating so I can go through all ~10 laps still using the drag reduction feature and ESC-on-command before the session ends. Sent from my iPad using Tapatalk
| The Following User Says Thank You to TM For This Useful Post: | clintavo (05-14-2014) |
#5225 | |
There is no problem hitting the WOT switch by hand when already WOT. The thing that is bad for the system is to "arm" the device when the WOT switch is already engaged. Remember this system isn't really meant for heavy track duty, yes it can work with moderation but that is the key. |
| The Following User Says Thank You to fenton For This Useful Post: | TM (05-14-2014) |
#5226 | |
Drives: DGM BRZ 6MT
Yup. The way I see it, I really enjoy learning and pushing the car on the track with its stock characteristics. But if I already have the ESC installed, nothing wrong with taking advantage of the drag reduction and also the occasional boost while on the straight. Just waiting for @shiv@vishnu to reply and let me know if a twin on the ESC tune while not using ESC really makes less power than on the stage 1 tune.
#5227 | |
When drag reduction is available it manages to stay mostly above the stage 1 power level but it does in pulses. Refer to post 5 of the first page to see the difference between stock, ESC off and drag reduction |
#5228 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Hey Tm, I have seen improvements with my cooling mod. The ultimate test will be this Saturday when nlowell tracks his car. But for the cost of the tube and how easy it is to route the cool air to the esc... Just do it. In my humble opinion it helps.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
| The Following User Says Thank You to Sojhinn For This Useful Post: | TM (05-14-2014) |
#5229 | |
Drives: DGM BRZ 6MT
![]() Run 002: Stock tune Run 046: ESC tune & armed with DR Run 047: ESC tune & unarmed ^ is my labeling correct? So the dyno was of DR all the way to redline without activating the throttle switch?
#5230 |
#5231 |
Drives: WR Blue BRZ, 240Z
TM,
Ask Rob to ship your ESC with Super Pursuit Mode. This allows you to operate @ WOT with just DR engaged.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#5232 |
Ok seriously. San Diego county is fricking on fire. Sorry off topic.
#5233 | ||
Drives: DGM BRZ 6MT
Damn, I just saw the news. Stay safe out there. Sent from my iPad using Tapatalk
| The Following User Says Thank You to TM For This Useful Post: | Sojhinn (05-14-2014) |
#5234 |
Drives: Raven FR-S
#5235 |
Yeah no doubt about that. Shall I do some tests on how the esc handles soot and ash?
#5236 | |
Drives: DGM BRZ 6MT
To truly test that, you'll need to remove your air filter. Sent from my iPad using Tapatalk
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
