Old 05-14-2014, 08:47 PM   #5223
Jac
Drives: Fiat Abarth
Originally Posted by TM View Post
4. If I reroute the WOT switch to some place where I can activate by hand, @fenton, do you know if there are any potential negative effects from clicking on the switch while I'm already WOT? (another way to think of it - activating super pursuit mode to activate the WOT switch while I'm already WOT)
Why would you ever want to activate the WOT switch by hand when your foot can do it when you go WOT?
Phantom Supercharged BRZ | 205WHP / 185WTQ
Nameless FP/OP Combo
Jac is offline   Reply With Quote
Old 05-14-2014, 08:51 PM   #5224
TM
TM's Avatar
Drives: DGM BRZ 6MT
For example, if a track has 3 straights (two short ones and a long one), but the controller will overheat after one or two laps, I might want to only activate the ESC through the long straight to prevent it from overheating so I can go through all ~10 laps still using the drag reduction feature and ESC-on-command before the session ends.
TM is offline   Reply With Quote
Old 05-14-2014, 08:54 PM   #5225
fenton
Think he is trying to control how much he uses it.
There is no problem hitting the WOT switch by hand when already WOT. The thing that is bad for the system is to "arm" the device when the WOT switch is already engaged.
Remember this system isn't really meant for heavy track duty, yes it can work with moderation but that is the key.
fenton is offline   Reply With Quote
Old 05-14-2014, 09:02 PM   #5226
TM
TM's Avatar
Drives: DGM BRZ 6MT
Thanks for the clarification. That's what I thought; just wanted to be sure it was the arming while WOT that was bad.
Yup. The way I see it, I really enjoy learning and pushing the car on the track with its stock characteristics. But if I already have the ESC installed, nothing wrong with taking advantage of the drag reduction and also the occasional boost while on the straight.
Just waiting for @shiv@vishnu to reply and let me know if a twin on the ESC tune while not using ESC really makes less power than on the stage 1 tune.
Old 05-14-2014, 09:13 PM   #5227
fenton
without boost it will make less, completely disarmed.
When drag reduction is available it manages to stay mostly above the stage 1 power level but it does in pulses. Refer to post 5 of the first page to see the difference between stock, ESC off and drag reduction
Old 05-14-2014, 09:16 PM   #5228
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
I'll be on vacation for about 3 weeks next month, but when I come back, I will be taking my car to the track. Here are a [lot] of questions
1. Back to the cooling mods, @Sojhinn @nlowell how well are your air ducts doing keeping the controller cool?
2. What seems the be the biggest cause of the controller overheating? Usage of the ESC itself, hot air trapped in the engine bay, something else?
3. Would directing air onto the controller be enough to keep it cool?
I want to figure a way to prolong the controller from overheating as much as possible. Extend the limits of the ESC per say.
5. @shiv@vishnu How does the tune on the ECU know when the ESC is activated and producing boost. Would it be smart enough to tell that I'm WOT without boost vs. WOT with boost (scenario on question 4)?
6. I think I remember you saying the performance of the OTS ESC tune is not as optimal as a stage 1 tune when I'm not using boost, is that correct?
Hey Tm,
I have seen improvements with my cooling mod. The ultimate test will be this Saturday when nlowell tracks his car.
But for the cost of the tube and how easy it is to route the cool air to the esc... Just do it. In my humble opinion it helps.
Installed Mods:
Old 05-14-2014, 09:35 PM   #5229
TM
TM's Avatar
Drives: DGM BRZ 6MT
I think this is the dyno you're referring to:
Run 002: Stock tune
Run 046: ESC tune & armed with DR
Run 047: ESC tune & unarmed
^ is my labeling correct?
So the dyno was of DR all the way to redline without activating the throttle switch?
Old 05-14-2014, 09:36 PM   #5230
fenton
Run 002: Stock tune
That is correct
Old 05-14-2014, 10:07 PM   #5231
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
TM,
Ask Rob to ship your ESC with Super Pursuit Mode. This allows you to operate @ WOT with just DR engaged.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 05-14-2014, 10:07 PM   #5232
Sojhinn
Sojhinn's Avatar
Ok seriously. San Diego county is fricking on fire. Sorry off topic.
Installed Mods:
Old 05-14-2014, 10:13 PM   #5233
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by Gary in NJ View Post
TM,
I already have the ESC, but I will ask Rob for instructions on doing it myself. I'm thinking about buying the auto version of the center console switches and wire this "super pursuit mode" to either the extra sport or snow switch for a cleaner look.
Damn, I just saw the news. Stay safe out there.
Old 05-14-2014, 10:21 PM   #5234
Thatruth2001
Drives: Raven FR-S
You need some water and less sunshine!
Thatruth2001 is offline   Reply With Quote
Old 05-14-2014, 10:22 PM   #5235
Sojhinn
Sojhinn's Avatar
Yeah no doubt about that. Shall I do some tests on how the esc handles soot and ash?
Installed Mods:
Old 05-14-2014, 10:24 PM   #5236
TM
TM's Avatar
Drives: DGM BRZ 6MT
To truly test that, you'll need to remove your air filter.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
