#505 | |
Drives: SWP BRZ
#506 |
Drives: Brz limited
well, no sooner do you guys post up this issue, and I left my dome light on for a day and a half.......
Odyssey completely dead..... won't hold a recharge... ordering a new one now...... |
#507 |
Drives: DGM BRZ 6MT
This is unrelated, but just came back from a 3 week vacation and my odyssey started my car up strongly within the first crank. Should've trashed my old battery a long time ago.
#508 |
Drives: SWP BRZ
#509 |
Drives: 2015 FR-S RS 1.0
Before you do that try this.
| The Following User Says Thank You to Sunrise161 For This Useful Post: | WNDSRFR (01-08-2016) |
#510 |
Drives: FR-S,GTI
Outstanding article!
I killed my OEM battery by letting it sit unused in the garage for a year and a half. It wouldn't take a charge with a normal charger. I connected it to a trickle charger and after about 4 days it came back to life! Don't give up on your Odyssey until you try this. |
#511 |
Drives: Brz limited
Thats awesome! I'll give it a try. Had to go pickup a new odyssey anyways (found it in Compton for $90 (4wheelparts).
I had a couple friends in town that I had to show off the supercharger to..... success though as the went from ![]() to ![]() I don't have a trickle charger... looking at this one from the homey's. http://www.homedepot.com/p/Battery-T...0192/204841738 $39 or $22 online. what do you guys think? |
#512 | |
http://www.costco.com/Battery-Tender...100241973.html |
#513 |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Just to let you know odyssey batteries have two batteries. Trickle chargers sometimes won't charge them properly.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#514 |
Drives: BRZ Limited; GR86
Hey guys so I have the newest procede controller and i have a version 1 esc. My esc switch (no partial boost) is a straight wire brown/black (no aux) which goes to the phantom controller. Does anyone know which wire (brown or black) i need to cut and attach to the Procede? I'm guessing brown wire since black is most likely ground
#515 | |
Drives: DGM BRZ 6MT
You have to use a multimeter to test which wire is ground and which has 5v of current. I don't remember having two wires to the WOT switch. I do remember there being one shielded wire and then copper surroundings. One is ground and one is positive, but you need to test them, as there is not a standard of which is which, since it was before the procede's time. For me, the copper wires was what I needed to tap to the procede. For another member, the single shielded wire was what he needed to tap. Sent from my iPhone using Tapatalk
| The Following User Says Thank You to TM For This Useful Post: | shaynek (01-12-2016) |
#516 |
Knocking problem with Procede and OFT ESC tune
@shaynek contacted me about fixing a knock problem that was dropping his IAM when he boosted at low rpms. The first thing I thought was "Try my tune instead of the OFT tune", but it knocked just as bad as the OFT tune. Well, in theory, I should be able to plant my foot at any rpm without getting engine knock, if the tune is right...
So I started with Timing compensation and looked at the MAP comp table. It looked like the more pressure it got, the more it changes the timing. That should do it, right? But, in the description in RR it says in parenthesis, "(clutch depressed)", see pic below. Well that isn't going to work on an AT, and sure enough, it didn't. So I looked in the Timing Advance section and saw the Knock Correction Advance Max A table, and thought "Let's give this a try." I rescaled it to go to an Engine Load of 4.0, since that was as high as I saw in my logging, and lowered the cells where I saw the most knocking. This is only my first try at modding this table, but it did virtually eliminate knock. 3 out of 5 logs had no knock whatsoever, and the 2 that did had only momentary knock, not long enough to drop the IAM. See the logs here, http://datazap.me/u/koolbrz/log-1453...ata=1-2-8-9-10 If you're getting knock between 2000 and 3000 rpms when boosting heavy, (I saw Engine Loads as high as 3.82, and boost as high as 4 psi) you'll need to change this table to eliminate knock. If anyone has a dyno, they can optimize this map to get the most out of it. Just start with a table full of 3's, then log the knocks and pull timing from those cells, bump the other cells to 3.5, log and pull timing, bump up to 4, log and pull etc...
If I say yes, will that make you think I understand?
#517 | |
Hey kool nice job spotting that. Were you getting knock on your system as well? Sent from my iPhone using Tapatalk
#518 | |
Yes, I was getting it too
![]() Last edited by KoolBRZ; 01-20-2016 at 12:25 PM. |
| The Following User Says Thank You to KoolBRZ For This Useful Post: | shaynek (01-20-2016) |
| Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6041 | 11-28-2025 08:08 AM |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 06:42 PM |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 01:12 PM |
| phantom supercharger restrictions? | Shinigunz | Forced Induction | 12 | 05-13-2014 03:28 AM |
| Drift-Office : Phantom Supercharger - Tuned! | Drift-Office | Forced Induction | 67 | 10-25-2013 09:51 AM |
