go_a_way1
Old 05-04-2014, 04:55 PM   #5027
fenton
Originally Posted by Talus1 View Post
Is there anybody with the Phantom ESC in South Western Ontario or the GTA that would be willing to demonstrate it for an interested BRZ owner? My BRZ replaced a '11 WRX. I got the BRZ for the steering feel and handling but immediately missed the WRX's torque. I figure 40% more torque would give the BRZ approximately the same torque to loaded weight ratio as the WRX and that is just about what the ESC seems to do on 91 octane.
Thanks!
I don't think there is anyone in central Canada with one. I had a 2009 wrx 265 and a 2011 sti before my FRS so I know how you feel. As it stands my FRS is faster than my stage 1 wrx was and about the same as my stage 1 sti was.
fenton is offline   Reply With Quote
Old 05-04-2014, 05:13 PM   #5028
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by radroach View Post
This thing needs a larger heatsink if that's an issue!
Should just go straight to liquid cooling.
It's funny, but in the end you might actually find a use for those worthless little fans the trolls were posting pics of back in the beginning.
The Following User Says Thank You to mid_life_crisis For This Useful Post:
radroach (05-04-2014)
Old 05-04-2014, 05:24 PM   #5029
Talus1
Talus1's Avatar
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
Bummer. I'll have to think of an excuse to have work send me out west.
As it stands my FRS is faster than my stage 1 wrx was...
That would do the trick!
Talus1 is offline   Reply With Quote
Old 05-04-2014, 05:32 PM   #5030
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Bah. FYI for those with an frs without fog lamps the cooling mod is a lot easier and cleaner. When @nlowell has a chance he needs to post his design.
Installed Mods:
Old 05-04-2014, 07:53 PM   #5031
DC2R
Drives: 2014 Scion FR-S
Straight line performance? Really?
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 05-04-2014, 08:11 PM   #5032
fenton
My wrx stage 1 made 250 who but was 3250 pounds. My still stage 1 made about 265 who but was 3405 pounds.
My FRS is at about 210 but is only 2700 pounds.
The sti kicks in harder because it has a exponential torque curve at 4000 rpm when torque spikes.
I would say it feels very similar to the wrx for straight line performance because it is a nice gradual torque curve.
The Following 2 Users Say Thank You to fenton For This Useful Post:
DAEMANO (05-05-2014), DC2R (05-04-2014)
Old 05-05-2014, 12:03 AM   #5033
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Here's what I've done to keep the ESC controller cool.
I had to do this mod in under 20 minutes as I was in the middle of packing the family up to head out of town. Told the wife I was packing up the car and quickly got to work =)
Supplies Needed:
- Brake Duct Hose ([ame="http://www.amazon.com/gp/product/B006K8KBK0/ref=oh_details_o03_s00_i00?ie=UTF8&psc=1"]Amazon.com: Allstar ALL42150 Black 3" x 10' Brake Duct Hose: Automotive[/ame])
- Hose Clams ([ame="http://www.amazon.com/HPS-SSTC-76-84-76mm-Stainless-T-Bolt/dp/B0058W7X0A/ref=zg_bs_15710721_16"]Amazon.com: HPS (SSTC-76-84) 76mm - 84mm Stainless Steel T-Bolt Clamp for 2-3/4" Hose: Automotive[/ame])
- Duct Mounting Plate ([ame="http://www.amazon.com/gp/product/B000BPUTL4/ref=oh_details_o02_s00_i01?ie=UTF8&psc=1"]Amazon.com: Spectre Performance 8148 Air Duct Mounting Plate: Automotive[/ame])
- Zip ties
Tools Needed:
- Utility knife (to cut the fog cover)
- Side cutters (to cut the cooling duct.)
- Screwdriver (to tighten the hose clams)
Installation:
- Remove the fog light cover by carefully prying/pulling (for FRSs without fog lights installed)
- Open the hood and start by feeding the hose down to the fog light area
- Reach up from the fog light hole, grab the hose, and work it down until you have enough slack to reach the opening without it retracting back
- Attach the mounting plate using a clamp
- Tilt the mounting plate to fit it in the hole and zip tie it to the two fog light screw holes
- Use the utility knife to carefully cut out the backing of the fog cover
- Pop the fog light cover back on
I'm still working on some cleanup and the best way of securing the hose up top. Right now I have it zip-tied in place but it's not secure enough. As soon as I figure that out I'll update this post with directions and pictures up top.
nlowell is offline   Reply With Quote
The Following 5 Users Say Thank You to nlowell For This Useful Post:
DAEMANO (05-05-2014), FingR-S (05-05-2014), niceguy21 (05-06-2014), raven1231 (05-05-2014), Winjr (05-12-2014)
Old 05-05-2014, 12:05 AM   #5034
Sojhinn
Sojhinn's Avatar
Supplies Needed:
- Brake Duct Hose (Amazon.com: Allstar ALL42150 Black 3" x 10' Brake Duct Hose: Automotive)
- Hose Clams (Amazon.com: HPS (SSTC-76-84) 76mm - 84mm Stainless Steel T-Bolt Clamp for 2-3/4" Hose: Automotive)
- Duct Mounting Plate (http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1)
- Zip ties
Tools Needed:
Installation:
- Attach the mounting plate using the clamps
So jelly. But I like my fog-lamps.
Installed Mods:
Old 05-05-2014, 08:47 AM   #5035
shif7i7down
Erected Member
Drives: frs
Does anyone know the progress of the May batch? Is it going to be released on schedule?
shif7i7down is offline   Reply With Quote
Old 05-05-2014, 09:22 AM   #5036
Robftss
Drives: VW
Yes, couple weeks, tops.
Robftss is offline   Reply With Quote
The Following 2 Users Say Thank You to Robftss For This Useful Post:
enwave (05-05-2014), shif7i7down (05-05-2014)
Old 05-05-2014, 09:24 AM   #5037
shif7i7down
Erected Member
Drives: frs
Sweet, time to order my batteries then.
Old 05-05-2014, 12:12 PM   #5038
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
I have a second dump pack that I ordered by accident still in the shipping box - I'll give you a deal if you want 'em.
VR46 is offline   Reply With Quote
Old 05-05-2014, 12:30 PM   #5039
WRB5titch
Drives: WRBrz
I was able to get my second dump pack exchanged for the two batteries that the .5 dump conversion kit needs. Picked up four of these for myself and @DAEMANO, so I didn't end up with any store credit left after the exchange.
I made my purchase back in February. So it was rather nice of atbatt to agree to the exchange, since I was waaay past the 30 day return policy.
EBSC - dt.FF - MXP CompRS
WRB5titch is offline   Reply With Quote
The Following User Says Thank You to WRB5titch For This Useful Post:
Old 05-05-2014, 01:32 PM   #5040
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Promo Code:
CINCO
That will get you an extra 5% off at AtBatt through Friday, May 9th.
alexand3r is offline   Reply With Quote
The Following 2 Users Say Thank You to alexand3r For This Useful Post:
DAEMANO (05-05-2014), enwave (05-05-2014)
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
