Old 01-03-2016, 11:41 PM   #491
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
just added myself into google doc.
i am wondering how to charge battery?
I usually drive my car weekend and dont want to drain battery.
just connecting battery tender to Odyssey battery is going to charge 2 dump pack batteries as well? or i need to disassemble and charge them?
Old 01-03-2016, 11:47 PM   #492
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Don't worry about it for either
Installed Mods:
Old 01-04-2016, 12:32 AM   #493
KoolBRZ
KoolBRZ's Avatar
Just make sure to disconnect/switch off cable to OFT, because it will drain that little Odyssey battery overnight.
If I say yes, will that make you think I understand?
Old 01-04-2016, 01:09 AM   #494
zc06_kisstherain
Drives: SWP BRZ
i also have dash-cam so i occasionally turned it on for 4-6 hours per day so I dont want to have weak/dead battery
i disconnect OFT all time and also have switch off cable as well
Old 01-04-2016, 12:53 PM   #495
Lord09
Drives: 2015 BRZ
I've left my OFT plugged in for 2-3 days on the stock battery and never had an issue starting. Anything longer and I switch it off via a switched OBD cable.
That being said, does anyone know or have first hand experience on how long the ESC starter battery can go with the OFT plugged in before it's drained to a point it can no longer start the car?
Lord09 is offline   Reply With Quote
The Following User Says Thank You to Lord09 For This Useful Post:
zc06_kisstherain (01-04-2016)
Old 01-04-2016, 03:26 PM   #496
zc06_kisstherain
Drives: SWP BRZ
i usually charged my battery in winter since i drive like once per 2 weeks? also avoid on salty roads.
since i installed ESC, trying to avoid my battery dead.
just trying to see ok to charge battery with unit installed or i need to disassemble batteries to charge
Old 01-04-2016, 06:00 PM   #497
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
Anyone selling or knows someone who is selling a PROcede ESC Controller?
shaynek is offline   Reply With Quote
Old 01-04-2016, 07:22 PM   #498
Gums
Drives: SWP BRZ
Originally Posted by Lord09 View Post
does anyone know or have first hand experience on how long the ESC starter batteries can go with the OFT plugged in before it's drained to a point it can no longer start the car?
I'm using a battery tender for the starter if not driving for a week or more. Had no drain issues with the dump batteries when sitting idle for 6 weeks, so my 2 cents worth would be not to bother with a 24V tender for those.
Always unplug the Blackview when parked in the garage, though car has Cat3 rust/paint protection running 24/7.
Not a good idea to drain the starter too much as it can give the battery a memory where it won't fully recharge. Had this issue on another car, maybe the Oddessy doesn't have this issue?
Gums is offline   Reply With Quote
Old 01-04-2016, 09:09 PM   #499
zc06_kisstherain
Drives: SWP BRZ
did you connect your battery tender to starter battery (+) (-) directly?
i dont need to disconnect dump pack battery cable at all?
Old 01-05-2016, 08:38 PM   #500
Gums
Drives: SWP BRZ
Yes, battery tender came with a small plug setup which stays connected to both terminals, I just plug the tender in and leave it until I next drive.
It's totally seperate from the dump wiring so nothing is disconnected.
Old 01-05-2016, 09:00 PM   #501
zc06_kisstherain
Drives: SWP BRZ
great!
thanks.
i kinda wish we can charge dump pack batteries without disassemble as well
Old 01-06-2016, 08:02 AM   #502
WNDSRFR
Drives: FR-S,GTI
The battery tender should charge all the batteries shouldn't it? That's what the car's alternator does. And the charger is taking the place of the alternator right? I guess it charges the dump batteries (24V) through the charger/controller.
Old 01-06-2016, 11:08 AM   #503
zc06_kisstherain
Drives: SWP BRZ
That's what i first thought as well.
but wanted to make sure because i have no idea how this controller works.
I don't drive a lot in winter time so i just usually leave it charged with battery tender.
Old 01-06-2016, 04:39 PM   #504
keen as
keen as's Avatar
Drives: 86 GT MT
Do what Gums said. The dump pack is separate and does not get used or charged until the controller is on, when the car is on.
When my car is parked in my garage, I directly connect the starter battery (12v) to my charger to keep it fully charged. It does nothing to the dump pack (24v).
keen as is offline   Reply With Quote
The Following 2 Users Say Thank You to keen as For This Useful Post:
Gums (01-06-2016), zc06_kisstherain (01-06-2016)
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
