go_a_way1
Old 05-03-2014, 04:55 PM   #4999
shif7i7down
Erected Member
Drives: frs
Originally Posted by fenton View Post
Well the compressor always needs to brake. Maybe his wasn't set strong enough for some reason.
If its not strong enough it can cause the engine to stall from continuing to force air into the engine. Normally it isn't a problem but if you go WOT and then clutch in right after and the brake isn't fast enough it can cause a stall.
Sounds like a Legitimate reason to install a bov.
shif7i7down is offline   Reply With Quote
Old 05-03-2014, 04:56 PM   #5000
raven1231
Originally Posted by shif7i7down View Post
Wanna share the procedure? Just in case we may need it in the future.👊💦
Sure it's simple:
Per Rob,
Procedure:
With car not running.
1) press WOT switch and hold.
2) Turn on 'arm' slide switch, count to 5 mississipi's, then release WOT switch.
3)Wait 5 seconds, then press WOT switch for 1-2 seconds to confirm compressor is spooling.
The Following 3 Users Say Thank You to raven1231 For This Useful Post:
DAEMANO (05-03-2014), shif7i7down (05-03-2014), Sojhinn (05-03-2014)
Old 05-03-2014, 05:01 PM   #5001
fenton
You need more tuning for bovs to work properly and then it still always seems there is driveability issues.
When the brake works there is no need for one at the levels of boost we are running.
The only reason that ravens brake wasn't working was because it accidentally got reprogrammed which can't happen with the new controllers
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
Old 05-03-2014, 05:07 PM   #5002
shif7i7down
Erected Member
Drives: frs
So the May batch has different controller from the ones from the 1st batch?
I wonder what else is different.
Edit; nvm, Rob answered it 4 post back
Old 05-03-2014, 05:30 PM   #5003
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Also guys jpits car is running dual dumps but his starter is in the the trunk. We won't know what's wrong with his car until the dealer clears it up.
Installed Mods:
The Following 2 Users Say Thank You to Sojhinn For This Useful Post:
DAEMANO (05-03-2014), raven1231 (05-03-2014)
Old 05-03-2014, 07:10 PM   #5004
TM
TM's Avatar
Drives: DGM BRZ 6MT
I datalogged a 30 minute drive on the backroads going home from work. Mostly cruising, with the occasional WOT ESC pulls.
It shows there was knock correction once. Does that mean a knock event occurred? If so, is the tune too aggressive?
I read somewhere that we want the fuel trim to be within 5%. The st fuel trim went above that threshold several times. Is that okay?
Can someone take a look at the logs to see if anything else is wrong?
http://datazap.me/u/tm/ots-esc
TM is offline   Reply With Quote
Old 05-03-2014, 07:14 PM   #5005
fenton
I believe the long term fuel trim is best between 5 and 0. ST can fluctuate quite a bit and it depends on the fuel used and atmospheric conditions.
1 knock correction is okay...the stock tune knocks on 91 Oct all the time. Where did the knock correction happen ? Is your IAM still at 1....that is the best indication that all is well. Your car will learn over time how much timing to use to not get any knock correction.
Old 05-03-2014, 07:30 PM   #5006
TM
TM's Avatar
Drives: DGM BRZ 6MT
I'm currently running on 93 octane. My long term fuel trim is between -5.47 and 3.91. Is that bad? Short term fuel trim fluctuated to -22.66 and 22.66 at the extremes.
I just looked at the logs in excel and it seems like there were two times a knock correction happened. Around the 422-second mark and the 828-second mark. Both times were during initial WOT and boost. Here's the specific section where the 2 knock corrections occurred: http://datazap.me/u/tm/ots-esc?log=0...zoom=3976-8974
Old 05-03-2014, 07:35 PM   #5007
fenton
Ya i just looked at it. The first time was at 1800 rpm, in my opinion that is to low of a RPM to go WOT at, its to hard on a small engine like this. You should target about 2500rpm or so before you go WOT so to not bog the engine.
The second knock event just looks like tip in knock. It happened as soon as you went WOT and was only a -.69 event. If you look you arent even making boost yet.
Other than that you log looks great, getting really good boost numbers
Old 05-03-2014, 07:37 PM   #5008
shif7i7down
Erected Member
Drives: frs
In a perfect world you would want ltft at -1% and stft to fluctuate +/- 2to5% during normal driving. If that -/+20% stft happens after deceleration then it's fine, it's just the system running lean to get all the unburnt fuel out, arf should spike to 20 for a bit also.
As for the knock if it happens during open loop in wot then once your ltft stabilized and your ecu had enough learned data, you shouldnt knock when you go wot and into closed loop since ltft is used in ooen loop.
Hopefully someone smarter could chime in and give a better/more in-depth explanation.:��
The Following User Says Thank You to shif7i7down For This Useful Post:
Old 05-03-2014, 08:45 PM   #5009
Sojhinn
Sojhinn's Avatar
Just finished showing off the phantom to @jflogerzi. Unfortunately the weather in the inland empire is about 100 degrees Fahrenheit right now and the low boost mode kicked on after about 4-5 pulls. We waited about 10 minutes and were able to get about 2-3 pulls. Not sure if I impressed him as much as I wanted but I did my best!
Nice meeting you Jeff can't wait to see what you do with your car.
Installed Mods:
DAEMANO (05-03-2014), gonzo (05-04-2014)
Old 05-03-2014, 08:48 PM   #5010
fenton
You should ask Rob if he has another aux charger. With the two rechargers it should distribute the load when WOT between the controllers and you will be less likely to hit the thermal.
Take it you haven't done the cooling mods yet?
Old 05-03-2014, 09:11 PM   #5011
jflogerzi
jflogerzi's Avatar
@Sojhinn I really want to thank you for taking the time to meet me today. He asked for me to give my honest opinion so here it goes. First off great job Rob. You have created a product that no one really can touch as far as price, ease of installation and value. For me I have already driven a OFT STG 2 E85 Tune with an aftermarket Borla UEL header. Having already experienced this setup, it left me a bit underwhelmed. Now someone who is looking for a good shot of low end power who has a stock car, Phantom ESC, OFT, and your choice of axleback would really offer a great combo. For my goals I can see this product will not meet them. I want more power than what this kit will offer even after improvements have been made. Another issue is this setup in its current form is not useable at the track. I hope Rob continues to develop the product and refine it. I will still pop my head into this thread from time to time and check its progress.
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
fenton (05-03-2014), Pistol (05-04-2014)
Old 05-03-2014, 09:15 PM   #5012
Sojhinn
Sojhinn's Avatar
Hah. I'm always a willing tester.
I got my final piece for the cooling mod, but I haven't installed it. Was going to wait until Monday so I can use the schools lift but I want to start today. We will see.
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
