#4957 | |
Erected Member
Drives: frs
I thought the whole point of FFS is that it keeps the throttle plate open all the time while shifting to reduce lag for turbo systems.. but as for the ESC, I can see why you don't really need to FFS because the esc comes on instantly with a switch. the only benifit that I see to FFS with the ESC or without ESC is the speed between shifts, it might be minutiae but I really do prefer to FFS if I'm going to shift at redline.. with that said.. it wouldn't hurt the engine to FFS with the ESC would it?
#4958 | |
Time Traveller
#4959 | |
Drives: WR Blue BRZ, 240Z
1. Running the compressor while rapidly opening and closing the throttle plate creates pressure waves that could potentially damage the compressor shaft. There is no history of this on the ESC nor do I believe it has been tested. I wouldn't want to be the one to prove the theory. 2. It's a waste of battery & usable boost. Take launch control for example. You're sitting on the line and engage launch control. The ESC engages (and the throttle plate is slamming open/closed) while you wait to launch. Time to go...drop the clutch...wheels spin like mad...and by the time you hook-up - 2, 3, 4 or more seconds have gone by. You just wasted your best boost/battery on sitting still. A better launch is to hold 4500 rpm (or what ever works best for you) and as you drop the clutch and begin to gain traction, go WOT. Doing it this way you have maximum boost and maximum battery.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#4960 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
I was running e85 with my old supporting mods and an older tune version. Tempted to try again though...
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#4961 |
Erected Member
Drives: frs
Man, i dont know About you guys but I'm still having problem with cold start with e85, it always die on first try and then work just fine on 2nd crank, temp is over 50 also,,,, makes me worry that something is wrong with running e85
#4962 | |
Time Traveller
** This is for a NA tune. |
#4963 |
Drives: Raven Black
#4964 |
Time Traveller
#4965 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
It seems that the station by me has bumped up the ethanol content and when it is cold, it will crank, sound like it doesn't start, then fire right up. Very odd, but a bit concerning. I do have the unmodified cranking tables though since I didn't modify the most recent revisions that shiv made.
#4966 |
Erected Member
Drives: frs
I'll give that a shot, and i agree it seems like the summer blend is out
#4967 |
Looks like Im meeting up with a forum member this weekend to show off the Phantom. Its always fun to show people how great the kit is.
| The Following User Says Thank You to Sojhinn For This Useful Post: | raven1231 (05-03-2014) |
#4968 | |
Drives: 2013 FR-S Argento
#4969 |
That headunit though...
Drives: 2013 Subaru BRZ Limited SSM
Mine definitely stutters a little sub-40f, but I've always started first crank. We get a pretty good winter blend here and the switch to summer blends is usually fairly late in the year. Don't anticipate it for another month or so.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300 Eibach Pro-Kit + Michelin PSS (stock size) |
#4970 |
Village Idiot
Drives: '13 FR-S Ultramarine Manual
Is there anyone around the sgv/LA area that has one they would like to showoff? I am very interested in one of these haha
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
