Old 01-10-2012, 06:53 PM   #477
NorCalRider
Drives: 2009 Toytoa Tacoma 4x4 Dbl Cab LB
60k? Holy crap man! Congrats on wiping that out.. I bet that wasn't easy. The worst I ever was (and this is including a new car loan and student loans) was about 23k and that was rough enough.
It was hell paying it off. Taught me a lot about interest and how it adds up. I learned the hard way so thought I would give him my 2¢ on it. Now if I cant pay cash for it or be able to pay it off in less then a year, I don't have to have it. I have some friends that are leveraged to the hilt, because they have to have latest toy or gadget and basicly just make interest payments. I could never live that way. OP sorry for going ot.
2013 SWP BRZ Limited(on order)
2012 Vw Jetta Sportwagen TDI 6mt Navi and Pano
2009 Toyota Tacoma 4x4 Double Cab Long Bed
1994 Honda Civic HB TurboCharged Track Car
NorCalRider is offline   Reply With Quote
Old 01-10-2012, 07:21 PM   #478
Longhorn248
Hook 'em
Longhorn248's Avatar
As long as debt is manageable and you're not underwater on any of your loans (whether it's a house or a car) then you should be fine and it helps build your credit. Being so far in debt that you can only afford to pay the interest payments means you're already in big trouble.
Longhorn248 is offline   Reply With Quote
Old 01-10-2012, 10:53 PM   #479
Mike
Handling junkie
Mike's Avatar
Originally Posted by Mr.Jay View Post
In a straigth line yes but I highly doubt so on the track or under any kind of spirited driving that involes curves and corners. The weight will feel obvious and the need for low end tq will make sense.
Why? Properly driven, you shouldn't ever be out of your powerband.
Mike is offline   Reply With Quote
Old 01-11-2012, 01:43 AM   #480
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Agreed but I still think give both cars to a skilled driver and around a track the SI will take it. The Camry regardless of power is a creation of new age Toyota soulless, comfortable and senoir friendly. I can't say for sure but given that the Si was design for boy racers in mind and the Camry being a family car the focus points are completely different.
The engine can keep up but can the chasis?
Tho once again this is all theory I don't own a new Camry and the last one I was in was a 1994 four banger
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 01-11-2012, 03:42 AM   #481
Mike
Handling junkie
Mike's Avatar
Would be an interesting comparison, if the tires were equalized and both cars had race pads on, and otherwise stock. I honestly don't know which car I'd put my money on.
To get back on topic, the 370z stock for stock will eat a FRS/BRZ. Again, if you equalize the tires, the FRS may have a chance on an EXTREMELY tight track, but nothing I can think of in SoCal besides HTM. Even at SoWS, the power advantage of the Z is too much to overcome. Until the Z overheats that is
Old 01-11-2012, 03:57 AM   #482
Ak1m0to
G20 Guru
Ak1m0to's Avatar
Drives: Infiniti G20 / FRS
Send a message via AIM to Ak1m0to
The power in the VQ I think will be too hard to overcome.
Maybe a TRD or STI version, would be a closer comparison.
Slowmatic Drfiterz, from P to D in a heartbeat.
Ak1m0to is offline   Reply With Quote
Old 01-23-2012, 06:49 PM   #483
dreamspeed
Drives: 350z
if i was looking into buying a 370z i would not be cross shopping a FRS and vice versa....unless i am looking into a USED 370z...then it would be more of a question of if i wanted a new or used car.
dreamspeed is offline   Reply With Quote
Old 01-25-2012, 08:00 PM   #484
duffman13
Auto-Xer
Drives: 2004 Acura RSX Type-S
In my bolt-on/tune/suspension RSX-S at summit point I was keeping up with a 350Z and stock Evo X on all but the main straight of the main course. Both drivers had more track days than me, and I would pull on the Z in through corners, and not lose any ground to the Evo. Summit Point is not exactly a handling track either, with 3 triple digit sections, and only one real low speed technical section
Granted on a RSX, bolt-ons and a tune push you to 200WHP, but it wasn't like they dusted me on the main straight. When I did a session and started 1 car ahead of the 350, he never caught up soon enough on the main straight to necessitate a pass either.
For comparison sake, we all had Hankook RS-3/Kumho-XS level tires on the cars, and brake pads good enough to handle 4x30 minute HPDE sessions.
duffman13 is offline   Reply With Quote
Old 01-25-2012, 08:24 PM   #485
Mike
Handling junkie
Mike's Avatar
I would suspect that you're a better driver, as a RSX-S shouldn't be competitive with a newer 350z/Evo-X The older Z's are... slow.
An EVO has zero excuse for cornering slower than a RSX-S; you may apex faster, but he'll be powering out of the turn like no other, esp with equalized tires. I'd suspect the Evo and Z probably had fatter tires too. EVO-X turns disgustingly well for how heavy it is.
Old 01-26-2012, 09:09 AM   #486
duffman13
Auto-Xer
That's more than likely. While it was one of my first track days, I'd been auto-Xing for 4 years prior and have a good idea of how my car handles. Once I learned the line, my exit speeds were higher than them and due to my car's weight compared to theirs, I was braking later into the corners too.
For comparison, this guy drives a Honda Challenge S2k with hoosiers and is apparently pretty good.
http://robrobinette.com/S2000SummitPointLap.htm
Specifically based on turn 10, because that is the only point coming onto the main straight that I can really check my speedo, I was averaging 93mph exit speed, hitting as high as 95 but not consistently, which is only 4-6mph off him. My turn 1 entry speed is similar as well
I probably would have beat a 370Z, but that's because he would have had to pit after 5 laps so his engine didn't get blowed up
Old 01-26-2012, 12:42 PM   #487
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
a brand new 370z in canada will set you back around 50K after all said and done.
I think overall the 370z is a much more capable car, but it's priced on another level (would definetly get it over a Porsche or something)
Old 02-01-2012, 01:26 PM   #488
red6spd
Drives: Red 6mt 370 sport
Originally Posted by iff2mastamatt View Post
Plus I haven't seen many mods that make the 370z drastically faster than the stock version. The Stillen mods have made it go 0-60 in 4.5 (5.1 stock), but that's not worth the money it takes for the Z to achieve that. IMO, a FR-S worth $35,000 (with $8,000-9,000 in mods) > $35,000 Z w/ sport package.
My 370z makes 339whp with just tune and boltons. Good for low 12s no problem
red6spd is offline   Reply With Quote
Old 02-01-2012, 02:42 PM   #489
jonnyozero3
Drives: 4 wheels & some metal bits
Wow, what was your base/stock dyno before you started with the mods? That VQ is usually around 270-290whp stock, isn't it?
jonnyozero3 is offline   Reply With Quote
Old 02-01-2012, 09:17 PM   #490
fatoni
what makes the scion not susceptible to the same kind of price hikes in canada?
fanboi, lame
Nissan 370Z thread S2KtoFT86 Other Vehicles & General Automotive Discussions 116 04-07-2017 10:40 PM
FT 86 & 370Z similarities blur FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 10-05-2010 12:39 AM
