Old 10-29-2015, 11:43 PM   #449
Agrael
Drives: BRZ-ZA1JA01N
Smile
@Td-d should be able to help it requires ecu code disassembly.
he will usually respond here or you can try the www.romraider.com forum if you join you can email him same username
thx, ecu code disassembly is a bin file or hex file(ZA1JA01N.hex)?or something else?
Agrael is offline   Reply With Quote
Old 10-30-2015, 12:10 AM   #450
steve99
The romraider guys look at the instruction set for the processor in this case a Renasis SH72531 micro-controller.
Then using that instruction set and lots of software and scripts they have developed reverse engineer the ecu instructions, highly complex and time consuming task
Old 10-30-2015, 01:05 AM   #451
Agrael
Feeling good complex, TD-D directly seek help, first with up ~ Thank you!
Old 11-01-2015, 04:56 AM   #452
steve99
Added ZA1JF20P 2015 Manual mystery rom found in Australia ?? and Taiwan supposed to be Japan low final drive. Appears identical to ZA1JF10G rom (note I incorrectly named the ZA1GF10G as F01G now corrected.)
The F10G and F20P definitions are same.
@Td-d I think their is some errors in the Cranking IPW tables for the F10G rom
Old 11-06-2015, 07:04 AM   #453
thambu19
Drives: Scion FRS
I am not sure if this has been asked before. Sorry if it is a repeat. Can one use OFT def files along with OFT rom files and still flash it in using Tactrix?
thambu19 is offline   Reply With Quote
Old 11-06-2015, 07:24 AM   #454
thambu19
Drives: Scion FRS
I think I got my answer here: http://www.ft86club.com/forums/showthread.php?t=78529
Thanks
Old 12-02-2015, 02:17 PM   #455
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Hey guys. Does anyone have the "ChecksumFix" scaling available? I've searched through all my ROM's with no luck. I'm trying to convert all the SD tables from RomRaider over to ECUFlash. Thanks.
D-VO is offline   Reply With Quote
Old 12-03-2015, 07:59 AM   #456
steve99
Im not 100% on what your actually asking for but here is a utility to convert RR defs to ecuflash defs.
you will generally need to correct a couple of things
flash method
mem model
and other initial header values
as per below in the ecuflash def after running the conversion utility
<rom> <romid> <xmlid>ZA1JF00C</xmlid>
<internalidaddress>8000</internalidaddress>
<internalidstring>ZA1JF00C</internalidstring>
<ecuid>A929703007</ecuid>
<year>2016</year>
<market>USDM</market>
<make>Subaru</make>
<model>BRZ</model>
<submodel>FA20</submodel>
<transmission>MT</transmission>
<memmodel>SH72531</memmodel>
<flashmethod>subarubrz</flashmethod>
<checksummodule>subarudbw</checksummodule>
9. How to Convert any RomRaider Editor def to a EcuFlash def
  1. Use the RR2EcuFlash.exe to convert any RR def to an EcuFlash def.
  2. Conversion of 16 bit ECU defs may require some manual updates to make them 100% usable.
  3. Copy the file created by the converter to your EcuFlash rommetadata directory and startup EcuFlash, then open the ROM for editing.
Application: RR2EcuFlash.exe
its a command line utility so you will need to run it from a DOS or command window
The full page on romraider here
http://www.romraider.com/forum/viewtopic.php?t=8449
Old 12-03-2015, 02:00 PM   #457
D-VO
I've been doing conversions manually this whole time. Thanks.
Remember the checksum fix we had when ECUFlash was first supporting the FRS/BRZ platform? Everything in RR was defined so I would load my ROM into RR to make the changes, then load it back into ECUFlash to do my reflash, but we had to manually change the checksum value for it to all work properly. That scaling is what I need to make an on/off switch to turn SD on and off for testing.
Anyway, let me see if I can figure this program out. Thanks!
Old 12-03-2015, 02:09 PM   #458
steve99
I read about that, but by the time i was flashing it was all sorted and you did not have to do it anymore. i think ztan was accross that, maybe PM him ?
Old 12-14-2015, 02:41 AM   #459
Agrael
Chinese version seems a distant dream ~
Old 12-15-2015, 06:49 PM   #460
thambu19
Drives: Scion FRS
A buddy of mine bought the Tactrix clone and it failed in the middle of a write and bricked his ECU. I had warned him not to do so and he did it despite that so I guess it serves him well... Tried to save 100 bucks on cable and now spent another 300 on ECU
Old 12-15-2015, 08:26 PM   #461
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
The actual Tactrix is cheap for what you get. The OFT too.
Old 12-19-2015, 04:09 PM   #462
Rossi
Drives: Toyota 86
Would it be possible to flash using a ELM 327 cable or a obd2 cable that can read data? Or do you have to have the tactrix cable?
Rossi is offline   Reply With Quote
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
