#449 |
I Love custom Turbo kits
Drives: Limited BRZ
Honestly don't know the duty cycle, but do know 500 cc injectors are good enough for 15 psi being extremely conservative. The DI helps them a lot.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | killerkid08 (05-12-2013) |
#450 |
Drives: Limited BRZ
That would be the case if we didn't have DI, but since we do, the ceiling is much higher.
#451 |
Drives: 2023 WRB BRZ (MT)
#452 |
Drives: Limited BRZ
Thats considering the DI system? The tuner can modify each system independently as much as he likes.
#453 |
that im not sure about. i cant find any info of the 2 in conjunction. i'd rather have my injectors b a lil higher then needed to b safe like a clutch. doesnt seem wise to b right on the limits
#454 |
Cool Stuff
Drives: Cool Car
I'm torn between the two but J-V says things are looking good at 8+ on stocks, but I wanna reach the 10+, and probably go 14-16. I know it wants more because every time it gets into the 9-10 range it turns into an animal, then my over boost feature kicks in and WHAM! the fun ends.
#455 |
Drives: Limited BRZ
Definitely, my point is again, the DI system gives us a lot of breathing room, and the 500 cc injectors coupled with the DI system, are good for much more than 280 crank, more like 400 whp at close to 90% duty cycle.
#456 | |
Drives: Limited BRZ
I think you will be alright with either or. Ask him directly for his recommendation between the two.
#457 | ||
#458 | |
Cool Stuff
Drives: Cool Car
Anyone know if DW has the PnP harnesses or if they are still pigtails? |
#459 | |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Even at 80% duty cycle you're safe... Me personally I use 85% IDC's to give me the heads up to keep a tune conservative until I get another set of injectors. But +1 on port and DI having parameters changed seperately
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
| The Following User Says Thank You to OmarGC For This Useful Post: | Sportsguy83 (05-12-2013) |
#460 |
#461 |
Drives: Limited BRZ
You mean the fuel pump or injectors? The fuel pump does. The injectors, why not go with Visconti ones?
#462 |
Cool Stuff
Drives: Cool Car
Ive heard anything below 80% is good, and above that is pushing it. Its just interesting trying to find a way to interpolate that percentage off of the ecutek log.
| Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! | Speed Element | Wheels and Tires | 151 | 09-26-2013 05:56 PM |
| Dream Mod For FR-S/BRZ | JPxM0Dz | Other Vehicles & General Automotive Discussions | 22 | 03-08-2013 11:35 PM |
| Have You Had A Dream About Your Car? | chanomatik | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 01-29-2013 03:38 AM |
| Sonic Blue 86, Galaxy Blue deleted? | 450hp/tonne | AUSTRALIA | 14 | 09-01-2012 08:10 PM |
| I had a dream... | ashtray | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 03-13-2012 12:35 AM |
