alpine, ATL BRZ, ftc~brz, jamesm, King Tut, OrbitalEllipses, sklimo, SmsAlSuwaidi, Sportsguy83, whitefrs
Old 05-12-2013, 01:15 AM   #449
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by killerkid08 View Post
how are your injectors handling your current boost setting ? % wise ?
trying to decide on going 550 or 700.
Honestly don't know the duty cycle, but do know 500 cc injectors are good enough for 15 psi being extremely conservative. The DI helps them a lot.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
killerkid08 (05-12-2013)
Old 05-12-2013, 01:16 AM   #450
Sportsguy83
Drives: Limited BRZ
Originally Posted by lbroskee View Post
550 should b good for about 280 HP (at the crank, not wheels i believe) so if u want more then about 250 WHP id go higher
That would be the case if we didn't have DI, but since we do, the ceiling is much higher.
Old 05-12-2013, 01:17 AM   #451
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
everything i see says it should b about 80%
lbroskee is offline   Reply With Quote
Old 05-12-2013, 01:44 AM   #452
Sportsguy83
Drives: Limited BRZ
Thats considering the DI system? The tuner can modify each system independently as much as he likes.
Old 05-12-2013, 01:48 AM   #453
lbroskee
lbroskee's Avatar
that im not sure about. i cant find any info of the 2 in conjunction. i'd rather have my injectors b a lil higher then needed to b safe like a clutch. doesnt seem wise to b right on the limits
Old 05-12-2013, 01:52 AM   #454
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
I'm torn between the two but J-V says things are looking good at 8+ on stocks, but I wanna reach the 10+, and probably go 14-16. I know it wants more because every time it gets into the 9-10 range it turns into an animal, then my over boost feature kicks in and WHAM! the fun ends.
killerkid08 is offline   Reply With Quote
Old 05-12-2013, 01:53 AM   #455
Sportsguy83
Drives: Limited BRZ
Definitely, my point is again, the DI system gives us a lot of breathing room, and the 500 cc injectors coupled with the DI system, are good for much more than 280 crank, more like 400 whp at close to 90% duty cycle.
Old 05-12-2013, 01:54 AM   #456
Sportsguy83
Drives: Limited BRZ
I got my 500 CC with a limit of 15 psi in my mind. Its also not good going too big on them, as the duty cycle too low is also a bad thing.
I think you will be alright with either or.
Ask him directly for his recommendation between the two.
Old 05-12-2013, 01:55 AM   #457
lbroskee
lbroskee's Avatar
curious on the boost they can handle driving hard on the street then, my dam lead food late at night
take ur current goal and go 1 up. that way when u get bored u can add more without new ones
Old 05-12-2013, 01:57 AM   #458
killerkid08
Cool Stuff
Drives: Cool Car
Sounds good. We need more bleeding edge people to test things out.
Anyone know if DW has the PnP harnesses or if they are still pigtails?
Old 05-12-2013, 01:58 AM   #459
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Even at 80% duty cycle you're safe... Me personally I use 85% IDC's to give me the heads up to keep a tune conservative until I get another set of injectors.
But +1 on port and DI having parameters changed seperately
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following User Says Thank You to OmarGC For This Useful Post:
Sportsguy83 (05-12-2013)
Old 05-12-2013, 02:00 AM   #460
lbroskee
lbroskee's Avatar
Anyone know if DW has thr PnP harnesses or if they are still pigtails?
not sure. if i had the money i would def b getting lots of tests done on a turbo kit (stupid bills)
Old 05-12-2013, 02:00 AM   #461
Sportsguy83
Drives: Limited BRZ
You mean the fuel pump or injectors? The fuel pump does. The injectors, why not go with Visconti ones?
Old 05-12-2013, 02:01 AM   #462
killerkid08
Cool Stuff
Drives: Cool Car
Ive heard anything below 80% is good, and above that is pushing it. Its just interesting trying to find a way to interpolate that percentage off of the ecutek log.
alpinewuzhere, better than sti, custom turbo kit ftw, epic brz build, ftc~brz, gtx30 goodness, its certainly a car, king tut, nocornnocare, sportsguy83, superior orbital fellow, thewheelsonthebusgo
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 05:56 PM
Dream Mod For FR-S/BRZ JPxM0Dz Other Vehicles & General Automotive Discussions 22 03-08-2013 11:35 PM
Have You Had A Dream About Your Car? chanomatik Scion FR-S / Toyota 86 GT86 General Forum 7 01-29-2013 03:38 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 08:10 PM
I had a dream... ashtray Off-Topic Lounge [WARNING: NO POLITICS] 1 03-13-2012 12:35 AM
