Old 11-07-2017, 12:58 PM   #449
Kodename47
Kodename47's Avatar
Drives: UK GT86
I can't remember the input the FF tune uses but you could use a switch to toggle between 0v/5v and therefore hard switch between 2 maps.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-09-2017, 03:02 AM   #450
CFutGwai
Drives: VA2 STI
Originally Posted by Kodename47 View Post
I'm sure it's been said that it's for both. Probably pulls a little timing on 91 and runs fine on 93.
Thanks,
I as got an email back from Shiv in regards to this. He said its good for 91.
That's all that matters.
CFutGwai is offline   Reply With Quote
Old 11-09-2017, 06:05 AM   #451
Kimviklund
Drives: 2017 Brz
Anyone have a stage 1 map for 2017 EU model? K00G..
Kimviklund is offline   Reply With Quote
Old 11-09-2017, 05:13 PM   #452
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Yep
Old 11-17-2017, 05:49 PM   #453
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
When will those of us with aftermarket intakes be able to try these tunes? I guess this question is for @Shiv@Openflash
Old 11-17-2017, 07:05 PM   #454
Somerandom18
Drives: 2017 manual BRZ
As long as the intake is designed to keep the same AFR you'll be fine. It's also easy enough to scale the maf on your own with some data logs and that tool you can download.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 11-17-2017, 07:45 PM   #455
guybo
Huge E85 fan!
guybo's Avatar
My LTFT at idle and 2500 RPM are well within -5, my Injen intake does pretty well
Old 12-05-2017, 10:19 PM   #456
Joeyb860
Joeyb860's Avatar
Drives: 2017 860 SPRINTEK
Oft
Originally Posted by Somerandom18 View Post
Here you go
Do you have the tune for uel headers I have a 2017 86 mt and haven't heard from shiev it's been 2 days.
Joeyb860 is offline   Reply With Quote
Old 12-09-2017, 10:39 AM   #457
Joeyb860
Joeyb860's Avatar
I'm getting a CEL p2096. Is this going to be on going I thought with the OFT it disabled this code anyone have this problem? Thanks.
Old 12-09-2017, 04:11 PM   #458
steve99
P2096 is a code that indicates the ecu THINKS you car is running too lean.
P0420 is the code disavled for catless header related to cat performance.
P2096 indicates you have a real problem, if you just fitted header its likely you have exhaust leak or cracked header or the 02 sensors are damaged. If you have fitted intake as well it could be intake leak or the intake has upset the maf scaling and hence fueling to your engine
Old 12-10-2017, 10:03 PM   #459
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
when are these maps available for download.
i have UEL JDL Catted + Catted UQFP + ARK catback, and have been modifying stage 1 maps, since stage 2 before was for Catless
soooo
really looking forward to real CATTED UEL header maps
neilvosko is offline   Reply With Quote
Old 12-12-2017, 11:00 PM   #460
neilvosko
neilvosko's Avatar
i got 2 files all 91 octane, i read in earlier pages that the 3.0 maps are for 91 and 93 ? is that true ?
Old 12-12-2017, 11:09 PM   #461
Teseo
Drives: frs
Yes, im waiting for "public" launch, dyno graphs comparing old vs v3 (uel/el, 91 vs 93) etc.
Old 12-14-2017, 04:07 PM   #462
Kodename47
Kodename47's Avatar
Drives: UK GT86
2019 will be along shortly along with (possibly) your answer.
.: Stealth 86 :.
Kodename 47 DJ:
OpenFlash Tablet: Multiple Data Log files! Shiv@Openflash Software Tuning 95 11-09-2017 08:40 AM
OpenFlash Tablet: OTS v2.0 Beta (132 new maps, 12 new XMLs) Available for Download Shiv@Openflash Software Tuning 1062 08-13-2017 04:13 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet v1.55b: BIN files added! Shiv@Openflash Software Tuning 525 04-09-2014 09:42 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
