Old 04-25-2014, 12:41 PM   #4593
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Originally Posted by fenton View Post
It accounts for atmospheric. The OFT currently does not.
Sent from my HTC One using Tapatalk
I absolutely didn't read torque and instantly thought OFT.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 04-25-2014, 12:58 PM   #4594
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by Jac View Post
It allows you to turn off the throttle switch. Basically lets you run in a non-boosted mode (although it'll still pulse the compressor if it detects negative pressure, aka it becomes a restriction at high RPMs)
Is that mode included in the ESC kit, or did you wire an extra switch?
TM is offline   Reply With Quote
Old 04-25-2014, 01:06 PM   #4595
Jac
Drives: Fiat Abarth
I asked Rob for it when i ordered, he wired it in for me. I dont think he throws it in with every kit by default.
Jac is offline   Reply With Quote
Old 04-25-2014, 01:15 PM   #4596
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Originally Posted by yohan04 View Post
I've been following this thread from beta stages, but I have question...this might already be covered, but to my understanding, the ESC activates when at 70% throttle load, correct?
Given the scenario, if I'm at mid-corner on a long sweeper @ 5000rpm and I'm slowly squeezing the throttle to WOT, does the ESC activate like a fully-on/off switch? Would it yield peaky, turbo-like (eg.single turbo supra power curve)??
I know ESC is designed primarily for street application, but I'm just concerned it might change the linear, predictable on-limit nature of the twins.
I take my on-ramps full beast mode lol.
At 5000 rpm you'll get about 2.5 psi of boost. It's enough that you'll know it's there and help you drive out of the corner, but not enough to upset your line...unless you want it too (just a bit of opposite lock and you'll be drifting).
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 04-25-2014, 01:19 PM   #4597
Gary in NJ
Gary in NJ's Avatar
Where are you guys reading your boost from. I take Intake Manifold Absolute Pressure and subtract Barometric Pressure (as supplied from the ECU). I never see 4.0 psi and I think it has to do with the lag in the reporting rate. I'm reading/reporting at a very slow 1Hz rate, making it hard to get detailed info.
Old 04-25-2014, 01:20 PM   #4598
HSayaovong
HSayaovong's Avatar
Drives: blk;2dr;rwd;fun
Just for shitz and grinds,have anyone tried their luck at the 1/4 mile drag strip?
What kind of times are you posting
Life is like taking a dump, sometimes it's easy and other times its hard. But it always stinks
HSayaovong is offline   Reply With Quote
Old 04-25-2014, 01:22 PM   #4599
fenton
Nobody has tried 1/4 yet.
fenton is offline   Reply With Quote
Old 04-25-2014, 01:24 PM   #4600
HSayaovong
HSayaovong's Avatar
You would think that it should get low 14s easily seeing as how the frs was pulling on the ap1 in your videos
Old 04-25-2014, 01:27 PM   #4601
Robftss
Drives: VW
You would think that it should get low 14s early seeing as how the frs was pulling on the ap1 in your videos
Low 14 will definitely be possible with a good driver.
Shiv's car (TQ250 dual dump + e85) would be in the 13's i believe....We are expecting to be in the high 230hp with e85 and dual dump
Robftss is offline   Reply With Quote
The Following User Says Thank You to Robftss For This Useful Post:
raven1231 (04-25-2014)
Old 04-25-2014, 02:03 PM   #4602
s2d4
s2d4's Avatar
Update your oft and look for the Act Boost channel instead of MAP channel.
The Following 2 Users Say Thank You to s2d4 For This Useful Post:
fenton (04-25-2014), Sojhinn (04-25-2014)
Old 04-25-2014, 02:07 PM   #4603
yohan04
yohan04's Avatar
Drives: Your sister
It is on off but nothing like a single turbo supra Haha.
Worst case scenario you would go from 100 percent na power to like 130 percent power with boost depending on rpm. It has never been enough to upset the car in 3rd or higher gear. In first or 2nd you can get the back to step out mid corner if you time the boost right....its a lot of fun
Supra would be like 100 percent power off boost and 250 percent on boost lol.
Right on. Pairing up with header/reflash presumably help the partial power delivery when ESC isn't activated...brilliant
yohan04 is offline   Reply With Quote
Old 04-25-2014, 02:59 PM   #4604
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
I'm interested in being able to run in non-boosted mode. I'm not entirely sure why, but I am. LOL.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 04-25-2014, 03:24 PM   #4605
robwbright
Ordered all of my batteries today! Total of $182.21 for the 5 batteries required for the 1.5 dump pack.
2006 Saab 9-3 2.0t
The Following User Says Thank You to robwbright For This Useful Post:
Boofneenee (04-26-2014)
Old 04-25-2014, 03:26 PM   #4606
fenton
You do everytime you create a negetive pressure between the charger and the throttle body.
His mode just lets him go WOT without the boost. In standard mode drag reduction will kick in and give you the NA feel.
I LOVE drag reduction....any time you tip into the throttle the charger adds just a bit of boost to get you going.....im tempted to call it 'torque fill' but then mclearen might sue me
Drag reduction really is the crown jewel of this whole system.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
