Old 05-13-2014, 12:26 AM   #4551
dabocx
dabocx's Avatar
Drives: Scion FRS
So with a solid header/exhaust and the 70mm pulley+intercooler whats the best anyones making on 93 or e85?
dabocx is offline   Reply With Quote
Old 05-13-2014, 12:28 AM   #4552
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
So I was having an issue with my car that I thought was tune related. Even after the newest delicious tune (8.58) it still had a nasty jerkiness around 3-4k while rolling onto the gas a bit.
Turns out, it wasn't the tune, but was the bypass valve on the back of the supercharger. When installing I had accidentally put a small hole in the L shaped rubber connector that connects the clear plastic tube from the bypass valve to charger.
I sealed the hole I created at the time with superglue and didn't think anything else about it, but obviously that didn't work. Put some RTV sealant on the other day and now the car is running like it should have been in the first place!
My apologies to @DeliciousTuning for thinking it was tune related. By the way, the new tune is amazing. Thanks again Bill for putting up with my impatient ass
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
The Following 2 Users Say Thank You to CK_Bladesmith For This Useful Post:
DeliciousTuning (05-13-2014)
Old 05-13-2014, 12:33 AM   #4553
CK_Bladesmith
Drives: Raven FR-S
I don't have a "premium" header, but I'm making 254whp (around 292 crank hp) with the 70mm, intercooler, 93 octane, Rev Works header, perrin OP FP and 3"CB. Also running the airaid intake with a nameless ceramic coated intake pipe.
Old 05-13-2014, 07:27 AM   #4554
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by DeliciousTuning View Post
Sent out late tonight. Let me know how it works with the larger intake.
Cheers,
William Knose
You're the man. I was already in bed at that point so I'm going to wait for my lunch break in a few hours to flash it. Can't wait. Thanks again!
Old 05-13-2014, 07:54 AM   #4555
Calum
That Guy
Drives: 2013 asphalt FRS MT
Same thing happened to me. Zach told me I'd have it by a certain day, I emailed when I realized how late it would be there and told him not to bother, it could wait and wasn't worth them staying back late for. Zach replied saying they had promised a certain day and that day it shall be. Sure enough, late that night the tune was emailed to me. That kind of dedication and loyalty to both his word and his customers is invaluable in a business like Bill's. I'm sure there's other great tuners out there, maybe even ones that can match Bill's skills, but why on earth would anyone try to find out?
The Following User Says Thank You to Calum For This Useful Post:
xjohnx (05-13-2014)
Old 05-13-2014, 08:36 AM   #4556
swift996
swift996's Avatar
Originally Posted by Dustin View Post
How "close to empty" do you run it? 8th tank? Light comes on? Oh shit I hope I make it? Lol.
I wait until the light comes on and drive it 5 miles or so then the 20 miles to the station.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
Dustin (05-13-2014)
Old 05-13-2014, 12:15 PM   #4557
xjohnx
Grip>Slip
xjohnx's Avatar
Cheers,
William Knose
Will do.
Edit: wow, this guy is FAST, ran into an issue and had a phone call within 10 minutes. Very impressed.
Old 05-13-2014, 01:54 PM   #4558
CK_Bladesmith
Drives: Raven FR-S
Looks like you've got some nice blow by issues. You should invest in a catch can setup.
Old 05-13-2014, 01:59 PM   #4559
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
I've been having an issue similar to what @CK_Bladesmith claims he had. Sputtering around the 4k rpm range. I think I found the culprit. Using a can of starter fluid I noticed rpm fluctuations when I sprayed the intake "plenum" portion of the supercharger where it bolts to the blower (the part that the vacuum ports screw into - use pic for reference). Anyway, that aside, I have 2 questions, one is does anyone know the torque specs for the 6 bolts that hold it onto the blower? Also when I pulled the bolts out to inspect the o-ring, I noticed quite a bit of oil buildup. I do not have a catch can yet, but the amount of oil buildup in there seems a bit much after just a couple hundred miles of driving. I don't think I've even hit 500 yet, maybe just. I guess my question is, based on the picture, does that seem an acceptable amount of oil for such little driving?
Dustin is offline   Reply With Quote
Old 05-13-2014, 02:02 PM   #4560
CK_Bladesmith
Drives: Raven FR-S
Thankfully our engines are port and direct injected, so the port injectors should keep your valves clean of any oil buildup that could cause coking on the valves. You definitely need to invest in a catch can setup of some kind.
Old 05-13-2014, 05:08 PM   #4561
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
If you are looking for an afordable good catch can check this out.
Originally Posted by calispec View Post
It may have not been clear in my earlier post but the catch can I found is really similar to the radium catch can at less than half the cost. The little basket threads into the top. Air coming through the can passes through the basket, into the can and out the fitting at the top. I added part of a copper scrubber that you can get at a grocery store to help collect the suspended oil. Radium uses similar stuff on the S2000 can. All the oil falls into the cup and can be checked with the dip stick. I am not saying radium doesn't make an awesome product but I would rather spend $200 bucks on a track day and some fuel. You could even mount two side by side similar to how the post quoted did. I would buy two sealing washers and an o ring for the dipstick.
[IMG][/IMG]
If you want an easy install and are willing to pay for it by all means radium is the way to go.
I'll leave this here.. after 800 miles in the winter.. driving nice..
I left the cheap clear tube on the outlet so I could see if any oil was getting past the can.. It's actually really clean.. Cleaner than I thought it would be..
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
The Following User Says Thank You to calispec For This Useful Post:
Dustin (05-13-2014)
Old 05-13-2014, 05:12 PM   #4562
calispec
calispec's Avatar
See below
[IMG][/IMG]
ADD W1 from eBay. I think it was $80 shipped. Us seller. Built VERY well. I would say it is VERY comparable to the radium catch can. One issue. They don't provide sealing washers for the nipples. They do give you 2-9mm and 2-15mm so it is perfect for our application. Buy a couple sealing washers from McMaster and you are golden. I opted to put the provided O ring on the OD of the canister threads because I believe it will seal better. I also put a small O ring on the dip stick.
[IMG][IMG]http://i332.photobucket.com/albums/m340/sickcis/BR-Zed/61672266-B795-4876-A59B-437***C60FD7_1.jpg[/IMG][/IMG]
I added a little extra baffling as well. I think radium uses a screen but this will do the same thing. Don't add too much because you don't want to restrict flow. Just something extra for the oil to stick to.
[IMG][/IMG]
[IMG][/IMG]
www.GT86Mounts.com
Dustin (05-13-2014)
Old 05-13-2014, 05:12 PM   #4563
CK_Bladesmith
Drives: Raven FR-S
^^ Thats the can I run as well. It's awesome, especially for $80-$90.
Old 05-14-2014, 01:26 PM   #4564
xxscaxx
Drives: 2013 SWP BRZ
Funny because I was worried about oil buildup as well after pulling the back of my charger elbow off. I purchased a radium can, and even when pulling the lines off to install it they had oil in them. I've checked the can twice now and not a drop of oil is in it.
I don't really get into the throttle that much, but I would have thought something was built up in there Guess thats a good thing.
Finally got the airaid box in, just figured i'd share. I may just paint the cover black, the other cover they provide thats dark is not black and looks weird so I polished it up quick to match the pipe. Still needs to be polished a bit more.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
MINOCIN (05-15-2014)
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
