Old 05-11-2014, 01:05 AM   #4523
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Originally Posted by Khorne View Post
So a bit bored and feel like putting in a boost guage.
Now im 99% sure i've seen something before about a bit on the back of the charger body that a boost guage can be plumbed into.
Anyone else know what im talking about or can point me in the right direction?
I posted where and how to tap into the back of the charger to run a mechanical boost gauge.
There is a :silver screw near the brake boost connector, which you fit a nipple screw and connect the boost pipe too. I could not find a 3mm so I drilled hole bigger to take a 5mm.
Fairly simple, not sure you can do it with kit on though.
Ryan86 is offline   Reply With Quote
Old 05-11-2014, 09:25 AM   #4524
xjohnx
Grip>Slip
xjohnx's Avatar
it's not the easiest to access and will require you to pull the elbow/throttle body at least.
Another alternative is to drill and tap a hole on the MAP sensor plate and attach a fitting there.
Old 05-11-2014, 11:33 AM   #4525
Assunta
Assunta's Avatar
Drives: 2013 SWP BRZ
That's where my tuner plumbed his sensor connection (but now plugged as I'm not using it).
Assunta is offline   Reply With Quote
Old 05-12-2014, 05:42 AM   #4526
Ryan86
Road Warrior
Ryan86's Avatar
After 3 weeks running stock ROM on 80mm, car ran 100%. Was good to have Toyota do full diagnostics to confirm car is still running healthy. No CEL came on even with SC and header, did over 1300km.
Received the latest tune in our G ROM format, flashed and tested no CEL have come on, so I can only assume our ECU cannot use another ROM format.
Eg ZA1JA01C cannot be used in a ZA1J01G rom. PO016 CEL comes up, which is now not.
Back to the tune, must say after running stock ROM for 3 weeks and flashing new tune, I could not feel as though there was any change under normal driving exceptionally smooth. I gave a few pulls and did logs, AM at 1 the entire time and maf and engine load indicating more power. I'm on the 75mm 95Ron, feels great. Nice also this tune can take 80mm to 69mm, so will do some dyno runs to verify what this tune delivers between the pulleys.
Great work @DeliciousTuning.
Old 05-12-2014, 07:36 AM   #4527
xjohnx
Grip>Slip
xjohnx's Avatar
Glad to hear you got it worked out. I should finally be getting my update today. Haven't run the Delicious tune in a while, but am excited to see how it's improved since I last ran it (which was pre- Nameless Header and Perrin 3" CAI). Are you running the stock MAP sensor, or the DeliciousTuning 11psi one?
Old 05-12-2014, 08:03 AM   #4528
Ryan86
Road Warrior
Ryan86's Avatar
I'm on the stock map, I've asked Bill a few times to upgrade the Map sensor, so I wait.
For now I don't want to change until I have run the car for about a month to make sure all good. New Charger arrived from Sprintex so I got to take kit off, this would be my 4th time
Old 05-12-2014, 11:36 AM   #4529
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Why did you have to get another blower unit??
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 05-12-2014, 11:38 AM   #4530
Ryan86
Road Warrior
Ryan86's Avatar
Blower is using oil,
Old 05-12-2014, 11:40 AM   #4531
CK_Bladesmith
Drives: Raven FR-S
Mine uses some oil as well.....maybe I should call innovate about it?
Old 05-12-2014, 11:55 AM   #4532
swift996
swift996's Avatar
Thanks for the reminder...I haven't checked my level in some time.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 05-12-2014, 01:14 PM   #4533
poorsche
poorsche's Avatar
Drives: 13 BRZ Limited, 2000 Impreza Sport
Sorry if this is something that's been beat to death already but wondering if anybody is running a 70mm pulley non i/c'd? Horrible idea?
poorsche is offline   Reply With Quote
Old 05-12-2014, 01:22 PM   #4534
xjohnx
Grip>Slip
xjohnx's Avatar
not a terrible idea if you're running E85.
If you're running pump though, don't bother.
Old 05-12-2014, 01:48 PM   #4535
poorsche
poorsche's Avatar
because of temp issues alone? im on pump for now but am looking at going to e85. e85 is abundant here in south dakota, so i might not bother with flex fuel. im told i can basically flash an e85 tune on stuck pump and injectors and be off to the races. worried about oem driveability though...especially in cold temps. any thoughts?
Old 05-12-2014, 01:49 PM   #4536
Powersfrs
Drives: Frs
..I had bill in my car for an hour logging with the 70mm on 91 n he said to not use it unless with e85...I'm running e85 on 75mm non intercool ...lots of torque down low
Powersfrs is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
