#4523 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
There is a :silver screw near the brake boost connector, which you fit a nipple screw and connect the boost pipe too. I could not find a 3mm so I drilled hole bigger to take a 5mm. Fairly simple, not sure you can do it with kit on though. |
| The Following User Says Thank You to Ryan86 For This Useful Post: | Khorne (05-11-2014) |
#4524 | |
Grip>Slip
Another alternative is to drill and tap a hole on the MAP sensor plate and attach a fitting there. |
#4525 |
Drives: 2013 SWP BRZ
That's where my tuner plumbed his sensor connection (but now plugged as I'm not using it).
#4526 |
Road Warrior
After 3 weeks running stock ROM on 80mm, car ran 100%. Was good to have Toyota do full diagnostics to confirm car is still running healthy. No CEL came on even with SC and header, did over 1300km.
Received the latest tune in our G ROM format, flashed and tested no CEL have come on, so I can only assume our ECU cannot use another ROM format. Eg ZA1JA01C cannot be used in a ZA1J01G rom. PO016 CEL comes up, which is now not. Back to the tune, must say after running stock ROM for 3 weeks and flashing new tune, I could not feel as though there was any change under normal driving exceptionally smooth. I gave a few pulls and did logs, AM at 1 the entire time and maf and engine load indicating more power. I'm on the 75mm 95Ron, feels great. Nice also this tune can take 80mm to 69mm, so will do some dyno runs to verify what this tune delivers between the pulleys. Great work @DeliciousTuning. |
| The Following 2 Users Say Thank You to Ryan86 For This Useful Post: | DeliciousTuning (05-13-2014), sato (05-12-2014) |
#4527 | |
Grip>Slip
#4528 | |
Road Warrior
For now I don't want to change until I have run the car for about a month to make sure all good. New Charger arrived from Sprintex so I got to take kit off, this would be my 4th time
#4529 | |
Drives: Raven FR-S
Why did you have to get another blower unit??
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#4530 |
Road Warrior
#4531 |
Drives: Raven FR-S
Mine uses some oil as well.....maybe I should call innovate about it?
#4532 |
Thanks for the reminder...I haven't checked my level in some time.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#4533 |
Drives: 13 BRZ Limited, 2000 Impreza Sport
Sorry if this is something that's been beat to death already but wondering if anybody is running a 70mm pulley non i/c'd? Horrible idea?
#4534 |
Grip>Slip
| The Following 2 Users Say Thank You to xjohnx For This Useful Post: | DeliciousTuning (05-13-2014), poorsche (05-12-2014) |
#4535 |
because of temp issues alone? im on pump for now but am looking at going to e85. e85 is abundant here in south dakota, so i might not bother with flex fuel. im told i can basically flash an e85 tune on stuck pump and injectors and be off to the races. worried about oem driveability though...especially in cold temps. any thoughts?
#4536 |
Drives: Frs
..I had bill in my car for an hour logging with the 70mm on 91 n he said to not use it unless with e85...I'm running e85 on 75mm non intercool ...lots of torque down low
| The Following User Says Thank You to Powersfrs For This Useful Post: | poorsche (05-12-2014) |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
