#4495 |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
Okay. I never received an email. I hope they read this soon. I was trying to use that from Perrin. Looks like I'm stick for the moment.
#4496 |
Twin Screw You
Got everything sorted with the help of Zach over at Delicious Tuning. I only ran into one issue after reflashing the ECU but so far I seem to be the only one. I'm gonna drive the car for a bit more to see if it is just the computer "learning" or if it is something else. Overall though this car is amazing with the tune from @DeliciousTuning. It pulls hard all the way to redline. Couldn't be happier with the results.
#4497 |
Drives:
Hey guys, I have a few questions about belts:
What brand are you using? Where are you ordering them? How often are you swapping them? Have you had any problems with specific brands? Sent from my iPhone using Tapatalk |
#4498 | |
Drives: GBS Premium
Gates, I picked up 2 from amazon for 25 bucks each at amazon. I messed up the install on one of them and the replacement has worked fine with no issues.
#4499 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
#4500 |
Twin Screw You
I probably jumped the gun on saying something as nothing was diagnosed yet. So far the diagnosis is not tune related but vacuum related. I'm going back and checking all my connections to make sure I have everything clamped properly. I already changed the fittings on the back from the plastic ones to brass ones and used Teflon tape for extra security so I don't think it's from there but I'll check that as well. Did some things last night so I'll do some datalogs this morning to see if it is running any better.
#4501 |
PhoneFlash by EcuTeK
Thought I'd drop this here for you all.
![]() [ame]http://youtu.be/QaYt-rucF34[/ame] Sincerely, Zach Delicious Tuning |
| The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post: |
#4502 |
Twin Screw You
Now show the video where they're trying to source all the vacuum leaks, lol.
| The Following User Says Thank You to Dustin For This Useful Post: |
#4503 |
Road Warrior
Over the past 8 months and 10000km of having the SC kit, I have monitored the oil in the charger and have had to top up on the 4 occasions.
I've drained the oil to check how much oil has been used. 2000km - 120ml 5000km - 40ml 7000km - 30ml 10000km - 30ml The instruction book from Sprintex indicates change oil every 50000km 157ml. Based on my records if I never checked the oil as the instructions on install indicate SC pre filled, I'd be ruining with no oil after every 15 to 20000km. Sent this info to our Sprintex agent, which I'm advised new Charger is on the way.. Keep an eye on your oil levels. |
| The Following 2 Users Say Thank You to Ryan86 For This Useful Post: | CK_Bladesmith (05-07-2014), whataboutbob (05-07-2014) |
#4504 | |
Drives: Raven FR-S
So where exactly is this oil going? I had to add a good bit to mine after only 1500 miles on the blower.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#4505 | |
Road Warrior
I have noticed a thin black oil slick line in my coolant bottle, but can't see how SC oil would get into the coolant system, so it might just be from the Glycol in the coolant. Post more info on exchanging units. Must also mention since taking the Blue Gates off, I have no more crickets in the engine and the belt tensioner running a whole lot happier.. |
#4506 | |
AutoX-10/10ths every run
#4507 |
I just passed 54K miles on my car. 20K of it with the SC on there. First 12K non-IC, 8K IC'd. Car is still running like a champ. Not burning or leaking oil in the motor, and I'm racing it in autox 1-4 weekends a month depending on the time of year. About to have Bill do a custom Delicious Tune with a Raceseng 70mm pulley and PPE EL headers and overpipe for 91oct.
Check my build thread for some pics and videos of the headers in action before the tune. Will post video and dyno plots of the tuning session at Infamous Performance after May 14th.
#4508 | |
Road Warrior
I check and change my Sc oil monthly, hence how I've found how much is missing each time. |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
