Old 05-03-2014, 08:20 PM   #4495
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Okay. I never received an email. I hope they read this soon. I was trying to use that from Perrin. Looks like I'm stick for the moment.
Dustin is offline   Reply With Quote
Old 05-04-2014, 01:02 AM   #4496
Dustin
Twin Screw You
Dustin's Avatar
Got everything sorted with the help of Zach over at Delicious Tuning. I only ran into one issue after reflashing the ECU but so far I seem to be the only one. I'm gonna drive the car for a bit more to see if it is just the computer "learning" or if it is something else. Overall though this car is amazing with the tune from @DeliciousTuning. It pulls hard all the way to redline. Couldn't be happier with the results.
Old 05-05-2014, 05:28 PM   #4497
michael_king
Drives:
Hey guys, I have a few questions about belts:
What brand are you using?
Where are you ordering them?
How often are you swapping them?
Have you had any problems with specific brands?
michael_king is offline   Reply With Quote
Old 05-06-2014, 12:37 AM   #4498
olorin
olorin's Avatar
Drives: GBS Premium
Gates, I picked up 2 from amazon for 25 bucks each at amazon. I messed up the install on one of them and the replacement has worked fine with no issues.
olorin is offline   Reply With Quote
Old 05-06-2014, 02:31 AM   #4499
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
What was the issue if you don't mind sharing
Ryan86 is offline   Reply With Quote
Old 05-06-2014, 08:03 AM   #4500
Dustin
Twin Screw You
Dustin's Avatar
I probably jumped the gun on saying something as nothing was diagnosed yet. So far the diagnosis is not tune related but vacuum related. I'm going back and checking all my connections to make sure I have everything clamped properly. I already changed the fittings on the back from the plastic ones to brass ones and used Teflon tape for extra security so I don't think it's from there but I'll check that as well. Did some things last night so I'll do some datalogs this morning to see if it is running any better.
Old 05-06-2014, 01:14 PM   #4501
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Thought I'd drop this here for you all.
[ame]http://youtu.be/QaYt-rucF34[/ame]
Sincerely,
Zach
The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post:
86-tundra (05-07-2014), MINOCIN (05-06-2014), whataboutbob (05-07-2014)
Old 05-06-2014, 03:40 PM   #4502
Dustin
Twin Screw You
Dustin's Avatar
Now show the video where they're trying to source all the vacuum leaks, lol.
The Following User Says Thank You to Dustin For This Useful Post:
Old 05-07-2014, 12:43 AM   #4503
Ryan86
Road Warrior
Ryan86's Avatar
Over the past 8 months and 10000km of having the SC kit, I have monitored the oil in the charger and have had to top up on the 4 occasions.
I've drained the oil to check how much oil has been used.
2000km - 120ml
5000km - 40ml
7000km - 30ml
10000km - 30ml
The instruction book from Sprintex indicates change oil every 50000km 157ml.
Based on my records if I never checked the oil as the instructions on install indicate SC pre filled, I'd be ruining with no oil after every 15 to 20000km.
Sent this info to our Sprintex agent, which I'm advised new Charger is on the way..
Keep an eye on your oil levels.
The Following 2 Users Say Thank You to Ryan86 For This Useful Post:
CK_Bladesmith (05-07-2014), whataboutbob (05-07-2014)
Old 05-07-2014, 01:12 AM   #4504
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
2000km - 120ml
5000km - 40ml
7000km - 30ml
10000km - 30ml
So where exactly is this oil going? I had to add a good bit to mine after only 1500 miles on the blower.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 05-07-2014, 01:38 AM   #4505
Ryan86
Road Warrior
Ryan86's Avatar
It can only into the charger if no external visible oil leak. I have to take kit off to change so will verify if any oil on the core or inside the manifold.
I have noticed a thin black oil slick line in my coolant bottle, but can't see how SC oil would get into the coolant system, so it might just be from the Glycol in the coolant.
Post more info on exchanging units.
Must also mention since taking the Blue Gates off, I have no more crickets in the engine and the belt tensioner running a whole lot happier..
Old 05-07-2014, 02:36 AM   #4506
whataboutbob
AutoX-10/10ths every run
2000km - 120ml
5000km - 40ml
7000km - 30ml
10000km - 30ml
Check it at every oil change to be safe.
Build thread:Here
Old 05-07-2014, 02:40 AM   #4507
whataboutbob
I just passed 54K miles on my car. 20K of it with the SC on there. First 12K non-IC, 8K IC'd. Car is still running like a champ. Not burning or leaking oil in the motor, and I'm racing it in autox 1-4 weekends a month depending on the time of year. About to have Bill do a custom Delicious Tune with a Raceseng 70mm pulley and PPE EL headers and overpipe for 91oct.
Check my build thread for some pics and videos of the headers in action before the tune. Will post video and dyno plots of the tuning session at Infamous Performance after May 14th.
Build thread:Here
Old 05-07-2014, 05:30 AM   #4508
Ryan86
Road Warrior
Ryan86's Avatar
Have you got a oil cooler on, I'm going to be doing some track time and wondered if absolutely necessary
I check and change my Sc oil monthly, hence how I've found how much is missing each time.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
