Old 07-06-2017, 10:08 AM   #4495
Azzudien
Drives: 2017 Series Yellow BRZ
Originally Posted by DocWalt View Post
I went from the stock 215 Primacies to 245 RE-71Rs and exited the final corner of a local track 10mph faster. I got to the other end of the straight and was only 1-2 mph faster than the 215s. That's a huge amount of speed to give up on every straight.
But you gained a lot of speed in the corner. These cars are definitely momentum cars, so the more speed you can carry out of the turns the better.
Did your lap times on that track decrease with the tire upgrade?
Azzudien is offline   Reply With Quote
Old 07-06-2017, 02:56 PM   #4496
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Originally Posted by Icecreamtruk View Post
Do you recall how long was that straight?
I was full throttle for ~2000 ft.
They sure did (I also did coilovers, so who knows how much the tires gained), but that wasn't really my point. I was just saying that wider tires definitely make a measurable difference on straight line speed. There's a balance for every track of what works best at some given power level, I'm sure. If you're stock power and on a big wide open track like Spa I guarantee the wide 245s would be slower.
FWIW I likely could have set faster lap times with a bit narrower, but stickier tires. RE-71Rs are 200 treadwear street tires... not R comps.
Old 07-06-2017, 03:13 PM   #4497
Icecreamtruk
Drives: Track preped NA FRS
Thanks for the info.
They might not be, but they stick just as much, they just dont handle prolonged heat. Besides the point I know, just saying.
Old 07-06-2017, 03:16 PM   #4498
You might be shocked if you go from "200TW" 71R to a "100TW" R-comp...
Old 07-06-2017, 03:34 PM   #4499
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I know guys, I know. Sorry, it was kind of a joke
I have never driven a "proper" R comp, but everyone that's ridden with me assumed I had R comps until we got out and looked at them.
Also, yes, the RE-71Rs get greasy towards the end of sessions. Meh. The BRZ is light and even at 10/10ths in ~80 F heat they were fine for ~20 minutes of a 30 minute session. Granted, narrower tires wouldn't handle the heat as well
Old 09-07-2017, 06:12 PM   #4500
redlined600
redlined600's Avatar
Drives: Fr-s
Is there any consensus on adding a wing and splitter to a n/a car(180-200hp range)? Is the increased cornering worth the straight line hit? I understand it will be track dependent but in general?
Old 09-07-2017, 06:35 PM   #4501
lutfy
lutfy's Avatar
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
I put the Apr 200 wing and front splitter. Luckily I gathered data at Summit Point. The car felt planted and pinned post spolier but I was stunned I gained 1/10 of a sec. the speeds at the straight was compromised.
At VIR was able to stay floored at places it was not possible before.
In retrospect I find the car to be more fun and confidence inspiring and would do it again.
Hard to say if it's a win win but certainly track dependent.
Lutfy
2015 FRS NASA ST/TT5
2022 LR Defender
2023 BMW M2
lutfy is offline   Reply With Quote
Old 09-16-2017, 03:16 PM   #4502
redlined600
Drives: Fr-s
Any other experience with wings on an/a car?
Old 09-26-2017, 01:03 AM   #4503
Tofurky
Tofurky's Avatar
Drives: 2013 FRS
Would there be any noticeable difference in handling feel in a 245/45/17 and a 245/40/17. If yes, how would you describe it?
Check out my racing adventures on
@omi_racing on Instagram!!
2013 Scion FR-S//2015 Aluminos CRF 250R Kart//2009 CRG Briggs and Stratton Kart
http://www.ft86club.com/forums/showthread.php?t=119147
Tofurky is offline   Reply With Quote
Old 09-26-2017, 03:50 AM   #4504
FirstWinter
Drives: Car
Softer sidewall with the 245/45 so a little more flex. Your gearing would be affected as well slightly.
FirstWinter is offline   Reply With Quote
Old 09-26-2017, 03:21 PM   #4505
You want the 40 profile.
45 will have a taller sidewall, but more importantly, have a SOFTER sidewall with a lower load rating.
It'll feel squishy and less responsive.
Old 09-26-2017, 04:22 PM   #4506
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I had a cheap cosmetic wing break in half going into turn 8 at Willow Springs at !20 MPH. Boy was I surprised how well it was actually working!
Lunatic is offline   Reply With Quote
Old 10-02-2017, 11:34 PM   #4507
Jamestl
Drives: None
Spent the weekend at Gingerman and had a great time. The group of twins didn't fair so well... One grenaded the block (engine internals was visible and a decent chunk of metal was found...), one wore brake pads down to the backplate (Ferodo 2500 -- apparently only lasted 4ish track days), one corded the tires and had to get crappier tires for the second day, and I had an ignition coil CEL. Thankfully I brought an extra coil just in case, and since it was #2 I was able to replace during lunch without losing a session...
Onto the question - there were a lot of hard right handers at Gingerman and the right left is worn pretty good. Looking at the pictures you can see that the first one is driver rear and driver front (L to R). The second picture shows the passenger side front and read. The last picture shows all together. You can see the edges of the driver front is worn so my question is what i should do with the tire. It looks like I should still be able to get a few days out of the tire, so should I have them remounted and just go swap left with right? Will that pose any safety risk? Thanks!!
Jamestl is offline   Reply With Quote
Old 10-15-2017, 09:27 PM   #4508
86Craze
Drives: 2016 FR-S
Someone please recommend some video or reading material on autocross driving. Theory, technique, selecting proper driving line for any track, etc etc. Thanks.
86Craze is offline   Reply With Quote
