Old 04-05-2021, 10:18 AM   #4369
Vital
Drives: 2015 BRZ
Originally Posted by saltywetman View Post
My main concern is the rim lip poking out too much and I miss dodging one of the multiple potholes in our pothole riddled roads and messing up a good wheel. Would like to not spend money on new tires with barely used stockers. but I'm also afraid cheaping out on rubber will cost me even more by permanently damaging some expensive wheels
Oh its not gonna be a crazy stretch, but enough to notice. I think you should be alright with an 8.5" wheel. As mentioned most tire manufacturers have a rim width range the lowest being a 7" and the highest being 8.5" so you should be fine. But yea i understand if you have a lot of potholes its probably better to be on the safe side. You could get new tires and sell your stock tires, those are nice tires you might not have trouble selling them.
Vital is offline   Reply With Quote
Old 04-05-2021, 06:54 PM   #4370
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Would Michelin Pilot Sport 4 245/40-17 tires fit on the stock PP wheels?
2017+ BRZ PP wheels 17x7.5 +48
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 04-05-2021, 07:01 PM   #4371
DarkSideFRS
Drives: 2013 pearl white FR-S
is this a serious question?
245 width tires are meant for rims 8.5" to 9.5" wide, so u can guess what the answer is
DarkSideFRS is offline   Reply With Quote
Old 04-05-2021, 07:04 PM   #4372
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Thanks for not being a **** about it
Old 04-05-2021, 07:27 PM   #4373
DarkSideFRS
you're welcome
Old 04-16-2021, 01:29 AM   #4374
Escher
Escher's Avatar
Drives: 2015 FR-S
Spent hours upon hours, learning the differences between wider and narrower and staggered and offset etc etc etc tires and wheels.
I run a 2015 FR-S with stock tires and wheels and a Jackson Racing Supercharger. It's my daily driver, but I like to pull it and I definitely take it onto backroads for the closest thing to racing I can manage.
Based on all of that research, I finally determined that, well, I guess the stock tire size is pretty damn ideal for someone who wants to maintain the characteristic handling but wants to add more grip with better compound.
Based on that, I've settled on the PS4S as my next purchase.
Yes we are.
That being said however, I am having a hell of a time finding wheels.
My FR-S is Ultramarine blue. I want white rims. Fight me.
Someone, anyone, please save me from my endless googling and rabbit-holeing.
I'm looking for reasonably lightweight wheels, 5-spoke or otherwise, that are $250 each or less and will fit the 215/45ZR17 PS4Ss I'm aiming for.
Someone lend a hand?
Escher is offline   Reply With Quote
Old 04-16-2021, 04:17 AM   #4375
churchx
churchx's Avatar
Drives: 2014 GT86
If you want to use stock tire size .. nothing wrong with using stock wheels
But if you still in future will think that wider tires are needed .. i'd think of slightly wider wheels, for example x8. Maybe even of slightly less offset to space slightly wider, eg. +38?
Stock sized tires will fit on wider wheel aswell, but wider tires won't feel sloppy due being too wide for a wheel.
Old 04-19-2021, 06:21 PM   #4376
tankslapper
Drives: None
AP Sprint BBK: Minimum spacer width for 2020 base 86 wheels?
I recently had an AP Sprint brake kit installed. 10mm spacers were recommended for the stock wheels on my 2020 base Toyota 86, but the wheel spokes do not clear the brakes. It has -3 degrees of camber on the front. Is it a matter of a wider spacer, and if so, how wide?
tankslapper is offline   Reply With Quote
Old 04-20-2021, 10:11 AM   #4377
Vital
Drives: 2015 BRZ
Big brake kits generally do require lower offsets for clearance. So either you can run wheels with low offset or get a spacer. Just know that if you are going to be using a 10mm spacer you will need to run longer studs as well...
Old 04-20-2021, 10:24 AM   #4378
tankslapper
Drives: None
I had longer studs installed. Anyone have an idea what size spacer I might need to clear the spokes?
Old 04-20-2021, 10:41 AM   #4379
Vital
Drives: 2015 BRZ
I believe the stock offset on your wheels is +48 adding a 10mm spacer would make it +38. I would think that is enough room to clear the brakes but cannot say definitely. Maybe someone else can confirm if 10mm would be enough.
Old 04-20-2021, 12:46 PM   #4380
tankslapper
Drives: None
10mm is not enough, as evidenced in my first post. It's making contact with the spokes with the 10mm spacers.
The question is what size spacers are needed to clear the stock 2020 base 86 wheels with the AP Sprint kit installed.
Old 04-29-2021, 03:50 PM   #4381
AiMaCh
Drives: 2017 Toyota 86
Hey yall, I am new to this so might be a stupid question but any help is appreciated. I just found a good deal for a specific set of wheels I want to know if a 18x9.5 +22 offset will fit (no rubbing etc) on my 2017 Toyota 86 all stock. I dont want to change anything in the near future. just wanted to upgrade the wheels and this option is for a lot cheaper than other I found so far. Also any recommendation on tires would be good. thanks
AiMaCh is offline   Reply With Quote
Old 05-03-2021, 09:16 AM   #4382
Vital
Drives: 2015 BRZ
Those are pretty aggressive wheels for stock suspension. Its definitely going to rub the fenders so you'll have to roll fenders and possibly add camber for it to fit properly. Also its going to poke out a lot on stock suspension and its going to look really bad if you're not lowered. Honestly you dont need wheels that wide stick to a wheel that is 17x8 with 225/45/17 tires if you plan to keep your car stock and just using it for daily driving.
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
