#421 | |
Drives: Firestorm '13
'13 Firestorm
#422 | |
Drives: 2016 Scion FR-S
Thanks. |
#423 | |
if your jist cruising on highway then your usually in closed loop fueling mode and stft should be varing and commanded afr and afr should be very similar. sounds like something weird is happening and ecu is going into full time open loop, it might be because of the rear 02 sensor or exhaust leak or something else not sure if the logging is set up for your rom the oft can monitor the rear o2 sensor its labeled in oft log as "wideband AFR", its actually calibrated for use with an aem wideband sensor but it should give you some idea if the rear o2 is actually working. if you had to use excessive force on sensors to install then in header it can damage them, if they are not screwed in all they way they can leak causing weird issues as can exhaust gasket leaks |
#424 | |
Drives: 2014 BRZ Limited SWP 6MT
I don't see them posted on the site anymore since they switched to the new site interface, but I think someone uploaded it the latest 7.2 template in this thread or the other OFT one. Try to find it, if not I can post it up tonite when I get home. |
#425 |
Drives: 2013 "Hot Lava"
Wouldn't the best way to get them be install the latest OFM which auto-updates itself, install the latest batch of flashes from last month and be golden, at least for knowing you've got the correct baseline stuff???
2013 Hot Lava FRS :: OFT Stage 2+ :: JDL UEL Catless :: JDL Over-Frontpipe :: GReddy Evolution RS Catback :: Enkei "Tarmac Black" RPF1 :: Tein Flex-Z Coilovers :: 245/35r18 Conti DW :: RS*R R-LCA :: Racer-X Fab R-Toe Arms :: Mishimoto Intake Tube :: Mishimoto Oil Catch Can :: JDL FSTB :: Raceseng "Slammer" + RLO :: Diode Dynamics HID + Tail-as-Turn + DRL :: 5:AD Spoiler ::
#426 | |
Ah I was wondering about that wideband O2 in OFT. I'll make sure I log it on my next trip. As of now I can't get it to go stuck on open loop. I'll have to make a 1 hr trip somewhere to monitor it in the near future. In town it seems to have stayed ok for now. When I first installed the OFH the O2 sensors came out and went back in well. So I'm not sure if I damaged them.
'13 Firestorm
#427 |
Drives: AT 2013 BRZ Limited
Hey can someone help me out please.
CAL: A00D OFT currently states: B01D I installed the stg2 OFH tune for A00D yesterday. Drove around at night and this morning. Just now, on the way home from work, my car went into limp mode while I was exiting the highway. I now have a permanent CEL that the OFT cannot detect and clear. ![]() OFT was plugged in at the time, logging. Of course the log did not save. Would knocking the connector slightly loose causing it to go limp possible? Any idea as to how to clear it without unplugging the battery. Will going back to original tune work? Do you think the tune caused some misfire or something that was responsible for sending it into limp mode? I had a log from when I installed the new tune last night. No WOT or anything, was just staying in closed loop. Seems okay IMO. But there really wasn't any ECU learning yet since it was literally just a few minute after uploading tune. http://www.datazap.me/u/ray7792/stg2...11-14&mark=NaN I understand the risks that were present using this tune as I have revworks' UEL headers not the OFH. Thanks for the help and your time~
'13 BRZ (sold)
'17 STI |
#428 | |
OFT only reads engine fault codes I suspect its a code related to can buss error, possibly due to oft comms interrupting can buss at some time can happen if you plug in or remove oft when engine running. its likely P0700 or P0155 from memory. If you have torque app and a Bluetooth adapter torque will clear all codes. or just disconnect a battery terminal and press brake pedal then reconnect battery should clear it. But you will reset your fuel trims and likely get the dead throttle pedal for a couple of drive cycles |
#429 | |
I'll try the torque app and bluetooth obd2 thing when my brother comes back with the adapter =( Thanks! Edit: yep it worked, you're right. Thanks again!
'13 BRZ (sold)
'17 STI Last edited by ray7792; 04-21-2016 at 12:04 AM. |
#430 |
Maximum puntential
Drives: 2013 DGM BRZ 6MT LTD
I'm running the OFH tune on Tomei UEL headers (rest of exhaust is stock) and a Perrin 2.75" intake. I applied the MAF scale for the Perrin intake to the tune as well. For fuel I'm using Sunoco 93.
I'm a little concerned about the amount of knock correction I'm seeing in the logs. One of them even shows some negative flkc. And two of them don't show any change in the MAF voltage, which shouldn't be possible so I just wonder if something happened during the datalogging process. http://datazap.me/u/ymaa/log-6?log=0&data=1-3-5-12 http://datazap.me/u/ymaa/log-5?log=0&data=1-3-5-12 http://datazap.me/u/ymaa/log-4?log=0&data=1-3-5-12 http://datazap.me/u/ymaa/log-3?log=0&data=1-3-5-12 http://datazap.me/u/ymaa/log-2?log=0&data=1-3-5-12 http://datazap.me/u/ymaa/log-1?log=0&data=1-3-5-12 Think these tunes might be too aggressive for my setup/fuel? |
#431 | |
I don't think fuel is the issue your IAM is at 1
#432 | |
ltft look ok knock is lss than -1 correction and iam is 1 looks ok |
| The Following User Says Thank You to steve99 For This Useful Post: | YMAA (04-24-2016) |
#433 |
did you manage to tone down the OFH tune a bit?
#434 |
Drives: '15 Scion FR-S - Ashphalt (MT)
Hey guys, Im new to the whole logging thing. Correct me if im wrong. Knock happens or should be worried about if the Knock correction drops below -1 or the IAM goes above 1?
Will I need to correct anything or is this fine? I have attached a few logs, i have noticed Knock Correction goes from 0 to -0.4 to -0.8 randomly. I am running 91Oct (from ESSO) with the new Stage 2 tune with my OFH and Invidia Q300 Catback http://www.datazap.me/u/noxcyn/log-1...log=0&data=2-8 http://www.datazap.me/u/noxcyn/log-1...log=1&data=2-8 http://www.datazap.me/u/noxcyn/log-1...log=2&data=2-8 |
| Just how noticeable is OFT+OFH and stage 2 tune? | BBYZILA | Software Tuning | 58 | 03-20-2018 11:56 AM |
| OFT 2.0 Stage 1 93 Tune | MurderRider | Software Tuning | 57 | 03-21-2016 12:30 AM |
| Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 08:15 PM |
| FA20club.com Turnaround Times On Modified Tune Files | FR-S Matt | Software Tuning | 103 | 11-13-2013 01:48 PM |
| So whate does stage 3 tune do? I already have 2 | Frsexxxy | Engine, Exhaust, Transmission | 17 | 05-14-2013 06:30 AM |
