#421 |
The Mechanic
Drives: Civic Turbo,FR-S
how am i back getting the u0155 code? i thought this was disabled since we stopped using tunerpro? romraider doesnt show a switch for it..
#422 | |
its possible to copy the xml code across or edit the romraider def calid to match your tune rom but you need to be verry carefull and understand what you are doing else you can brick your ecu. for example oft 700/900/A00 A01C or D rom are actually B01C or D based. |
#423 | |
Nothing tune related.
#424 | |
The Mechanic
ya i know. im not worried about it, its just annoying when it puts the car in limp mode. Rarely if i hit a bump too hard the plug shifts and the code is triggered.
#425 |
that p0155 might be in oft defs just have a look with romraider if itstheir just set to off and no moreproblems
#426 |
The Mechanic
ive checked. its a long list but there all "p" codes.
#427 | |
As for disabling, no one in their right mind would ignore CAN bus errors.
#428 |
Drives: '22 BRZ
Anyone seen rather low LTFTs (-7% or so) at idle with 2.06 with the 91 octane UEL tune? I'm thinking I'll need to scale the MAF after I finish this round of mods.
#429 | |
Drives: 2013 Asphalt 6spd
http://datazap.me/u/target70/esc-93oct?log=0&data=6
#430 |
The Mechanic
i mentioned tuner pro because it had access to disable the code.
#431 | |
Drives: '22 BRZ
#432 |
#433 |
Drives: FT-86
just downloaded the newests maps for OFT, but i dont know wich one to use (DOM, US, C6, EU, Gulf, KS or EH). I use 2 types of gas. Argentinian 98 RON premium gas, and premium Brazilian gas at around 91-93 oct BUT it has 27,5% ethanol in it...
So, wich maps do i use @Shiv@Openflash? Thanks! (i use STP Octane Booster with the Brazilian gas) |
#434 | |
Just fing the matching rom's in the OFT download and load the one you want into the OFT if your stock use stage 1 maps. Try the 91 octane maps first log knock parameters see links below, if no knock then try the 93 maps. see OFT TIPS link below. |
| OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] | Shiv@Openflash | Forced Induction | 226 | 03-12-2019 09:26 PM |
| iOS 8 beta 1 not working on BRZ USB | Kids Heart | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 04-13-2015 08:17 PM |
| v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT | Shiv@Openflash | Forced Induction | 3 | 07-26-2014 12:23 PM |
| OFT 1.42 vs 1.5x Beta Who notices a Difference? | Cross | Software Tuning | 11 | 03-21-2014 03:17 PM |
| Anyone want to beta-test some door speaker spacers? | phenryiv1 | Electronics | Audio | NAV | Infotainment | 63 | 08-20-2012 09:02 PM |
