Old 11-26-2014, 09:52 PM   #421
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
how am i back getting the u0155 code? i thought this was disabled since we stopped using tunerpro? romraider doesnt show a switch for it..
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 11-26-2014, 10:32 PM   #422
steve99
Drives: FT86
the oft definitions dont have all the extra cel code disable options that the romraider definitions have.
its possible to copy the xml code across or edit the romraider def calid to match your tune rom but you need to be verry carefull and understand what you are doing else you can brick your ecu.
for example oft 700/900/A00 A01C or D rom are actually B01C or D based.
Old 11-28-2014, 03:52 AM   #423
s2d4
s2d4's Avatar
That's a communication error.
Nothing tune related.
Old 11-28-2014, 07:20 PM   #424
Grip Ronin
The Mechanic
Grip Ronin's Avatar
ya i dont know much about editing the ids and codes so im better of not messing with it lol
ya i know. im not worried about it, its just annoying when it puts the car in limp mode. Rarely if i hit a bump too hard the plug shifts and the code is triggered.
IG-Joey_Soul
Old 11-28-2014, 07:24 PM   #425
steve99
Drives: FT86
that p0155 might be in oft defs just have a look with romraider if itstheir just set to off and no moreproblems
Old 11-29-2014, 06:06 PM   #426
Grip Ronin
The Mechanic
Grip Ronin's Avatar
ive checked. its a long list but there all "p" codes.
IG-Joey_Soul
Old 11-29-2014, 07:02 PM   #427
s2d4
s2d4's Avatar
It has nothing to do tuner pro so not sure what you were thinking.
As for disabling, no one in their right mind would ignore CAN bus errors.
Old 11-29-2014, 08:57 PM   #428
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Anyone seen rather low LTFTs (-7% or so) at idle with 2.06 with the 91 octane UEL tune? I'm thinking I'll need to scale the MAF after I finish this round of mods.
Old 11-29-2014, 09:13 PM   #429
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Not the same setup, but running the 2.x phantom 93oct tune with UEL and I idle at (-6.25), and it never goes above 0.
http://datazap.me/u/target70/esc-93oct?log=0&data=6
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 11-29-2014, 10:37 PM   #430
Grip Ronin
The Mechanic
Grip Ronin's Avatar
i mentioned tuner pro because it had access to disable the code.
IG-Joey_Soul
Old 11-30-2014, 12:06 AM   #431
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I'd post my log as well, but OFM 1.14 is broken and I can't click the read button... Thanks for the log though!
Old 11-30-2014, 01:43 PM   #432
nunonuna
nunonuna's Avatar
Try press "Tab" twice and "enter". It will read. Use this for now until they reslove the issue.
nunonuna is offline   Reply With Quote
Old 12-02-2014, 11:50 AM   #433
dejxx
dejxx's Avatar
Drives: FT-86
just downloaded the newests maps for OFT, but i dont know wich one to use (DOM, US, C6, EU, Gulf, KS or EH). I use 2 types of gas. Argentinian 98 RON premium gas, and premium Brazilian gas at around 91-93 oct BUT it has 27,5% ethanol in it...
So, wich maps do i use @Shiv@Openflash?
Thanks!
(i use STP Octane Booster with the Brazilian gas)
dejxx is offline   Reply With Quote
Old 12-02-2014, 01:57 PM   #434
steve99
Drives: FT86
Thanks!
Use the "Ecu Info" button on the OFT it will show you what your stock ECU Calibration ID is something like ZA1JA01G the last four letters are what you need, in this case G is your rom series and A01 is your rom revision.
Just fing the matching rom's in the OFT download and load the one you want into the OFT if your stock use stage 1 maps.
Try the 91 octane maps first log knock parameters see links below, if no knock then try the 93 maps.
see OFT TIPS link below.
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] Shiv@Openflash Forced Induction 226 03-12-2019 09:26 PM
iOS 8 beta 1 not working on BRZ USB Kids Heart Off-Topic Lounge [WARNING: NO POLITICS] 4 04-13-2015 08:17 PM
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT Shiv@Openflash Forced Induction 3 07-26-2014 12:23 PM
OFT 1.42 vs 1.5x Beta Who notices a Difference? Cross Software Tuning 11 03-21-2014 03:17 PM
Anyone want to beta-test some door speaker spacers? phenryiv1 Electronics | Audio | NAV | Infotainment 63 08-20-2012 09:02 PM
