Old 10-22-2015, 12:10 AM   #421
tzbang
Drives: 2013 GT86
Ok sorry for the questions - so to recap:
1. I'll need to factor in having to make my own cables to suit RHD
2. There is no ideal/perfect tune as yet available for AUS/NZ but it's in development using OFT.
What about a tune using Ecutek or something for AUS/NZ
tzbang is offline   Reply With Quote
Old 10-22-2015, 12:25 AM   #422
KoolBRZ
KoolBRZ's Avatar
alternatives to OFT tunes for ESC
Ecutek, or BRZedit are copyright protected software. RomRaider is Open Source. With Open Source you have a supportive network who can openly share what they've learned. With Ecutek or BRZedit you are at the mercy of the tuner. If you don't like it, you can always put yourself into the hands of another tuner, hopefully more knowledgable. With a remote tune your support is even farther away, but your tune might be even better. If you get a really good tune, you can't share it with anyone.
If I say yes, will that make you think I understand?
Old 10-22-2015, 03:06 AM   #423
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Getting new tires finally so I might be able to log some 0-60s with my shitty launches.
Also looking forward to trying the new tunes for OFT and Procede.
BTW what were the changes in rev 3?
l0aded is offline   Reply With Quote
Old 10-22-2015, 03:47 AM   #424
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by fenton View Post
Rev 3 kit has had some updates, mostly with ease of installation and compatibility additions for Procede
Seems like mostly wiring updates.
TM is offline   Reply With Quote
The Following User Says Thank You to TM For This Useful Post:
l0aded (11-10-2015)
Old 10-22-2015, 12:12 PM   #425
KoolBRZ
KoolBRZ's Avatar
@tzbang, what is your CAL ID?
Old 10-22-2015, 05:36 PM   #426
keen as
keen as's Avatar
Drives: 86 GT MT
tzbang doesn't have a unit yet. However, I wonder what the ROM is for NZ. I expect the same ROMs as AUS.
Also, can you make an A00G ROM for Gums, in AUS?
I will update you with MAF scaling after it's done.
keen as is offline   Reply With Quote
Old 10-22-2015, 08:52 PM   #427
KoolBRZ
KoolBRZ's Avatar
Just sent it in a PM. I'll post it with the others once it passes inspection.
P.S. Bear in mind these are ESC tunes, so they won't perform as well NA because the timing is reduced to prevent detonation under boost.
The Following 2 Users Say Thank You to KoolBRZ For This Useful Post:
Gums (10-23-2015), keen as (10-22-2015)
Old 10-22-2015, 10:35 PM   #428
tzbang
Drives: 2013 GT86
Do you mean the car will be slower when it's not WOT (on boost) with a ESC tune?
Old 10-22-2015, 10:42 PM   #429
KoolBRZ
KoolBRZ's Avatar
I have the PROcede and I'm always on boost.
Gums (10-23-2015), Shiv@Openflash (10-23-2015)
Old 10-23-2015, 12:12 AM   #430
keen as
keen as's Avatar
Drives: 86 GT MT
With the current 2 stage throttle switch or Procede controller, the car never feels slower. Always feels like plenty of power, like bigger motor.
How it works is if you need bit extra acceleration, use the throttle pedal a bit more and it will activate either stage 1 of the throttle switch, approx. 1psi boost or the Procede, has variable boost (as KoolBRZ has). If you need full acceleration, then full throttle for full boost.
IF you were to have the unit switched off and have no boost, then at higher rev ranges, the compressor is a restriction in the air intake and will reduce power.
Old 10-23-2015, 12:31 PM   #431
KoolBRZ
KoolBRZ's Avatar
If you have an OFT, you can try it yourself
If you have an OFT you can try some tunes yourself and tell us what you think. The only difference is the timing and pressure related tables. I'll make 2 tunes. One with all of Wayno's changes and my changes for NA , and one with Wayno's changes, my changes, and the ESC changes for pressure and timing. You can try them both out and tell us what you think. You'll need to tell me your CAL ID first, so I know which ROM to use.
Old 10-24-2015, 06:36 AM   #432
tzbang
Drives: 2013 GT86
Cheers, but I don't have a OFT yet. I've only just got the car and I'm just starting to do some research about what I want to do with it. Pretty keen on the Phantom but unsure about how to tune yet since I'm in NZ.
How do I find out my CAL ID btw? Actually.. where do I even find the ECU? LOL (newb alert)
Old 10-28-2015, 12:48 PM   #433
KoolBRZ
KoolBRZ's Avatar
Fixed Load limits
I found out load limits are important, so I checked the Load Limit tables on all the tunes and found three that were wrong. If you have a CAL ID of A01D, A01G, or B01D, and you used one of my tunes, your load limit tables are wrong. I fixed them and replaced the zipped folders with new ones. Here they are.
keen as (10-28-2015), Sojhinn (10-28-2015)
Old 11-01-2015, 02:57 PM   #434
TM
TM's Avatar
Drives: DGM BRZ 6MT
For those with the odyssey battery, what are these screws for? Are they for the top of the SAE posts? If so, what's the purpose of them?
Also, when it says to torque down the top caps, does it mean the hex screws that are part of the SAE posts or the ones I circled in the picture?
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
