Old 10-22-2013, 02:16 PM   #421
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Originally Posted by JPxM0Dz View Post
For those asking about snorkel removal...
Just confirming that removing the fresh air snorkel will make a difference, yes?
.ck
Sent from my HTC One using Tapatalk
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 10-22-2013, 03:36 PM   #422
topazsparrow
Drives: slow
.ck
Not likely any perceivable amount. The filter is more restrictive than the tubing.
topazsparrow is offline   Reply With Quote
Old 10-22-2013, 04:16 PM   #423
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
.ck
Correct. From our dyno testing, we saw no appreciable gains with replacing a clean stock filter with a clean new foam filter from Perrin. But repeatable gains when removing the snorkel completely. The advantage of going with a drop in panel is more of a long term thing I think. The aftermarket ones will see less less restriction as they accumulate dirt.
Shiv
Old 10-22-2013, 04:26 PM   #424
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
time to take the snorkel off of my TRD intake and see what I can get!
CamryDS is offline   Reply With Quote
Old 10-22-2013, 04:47 PM   #425
xDanger_208x
xDanger_208x's Avatar
Drives:
Shiv
So just remove it completely? What kind of gains?
xDanger_208x is offline   Reply With Quote
Old 10-22-2013, 04:59 PM   #426
Shiv@Openflash
Drives: 2013 FRS
Yes, we removed it completely and saw a repeatable 2-3hp gain above 6000rpm.
Old 10-22-2013, 05:01 PM   #427
mid_life_crisis
Drives: FR-S 10 #103 AT
In other words, nothing anyone can actually feel NA but an indication that it might benefit a FI installation.
Old 10-22-2013, 05:03 PM   #428
Shiv@Openflash
Drives: 2013 FRS
All these little 2-3hp gains do add up into something you can feel. For FI application, I'd probably nix the hold stock airbox completely since it will probably be a restriction at those much higher airflow levels. But that remains to be tested.
Old 10-22-2013, 08:22 PM   #429
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
shiv, i edited my snorkal months ago by cutting it back to a 2.5 in opening and putting in a v stack, wouldnt i see the same gains but have the air accelerated in by a smooth entrance like this??
IG-Joey_Soul
Old 10-22-2013, 08:40 PM   #430
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Shiv,
Just curious, were these dynos done with the hood open or closed?
Decay107 is offline   Reply With Quote
Old 10-22-2013, 08:52 PM   #431
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Hmm...personally I don't think it would be worth the time and effort to remove the bumper just to get to the snorkel...and only end up with 2-3hp at above 6000rpm. But the good thing is that it doesn't cost any money
Fizz is offline   Reply With Quote
Old 10-22-2013, 09:12 PM   #432
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
You don't need to remove the front bumper to get at the snorkel
This is how I removed mine... The only difference is I found it easier to pull mine out from the drivers side verses the passengers side as done in the DIY
http://www.ft86club.com/forums/showthread.php?t=15376
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 10-22-2013, 09:50 PM   #433
fstlane
fstlane's Avatar
Drives: BRZ Limited
I just walked in from the garage after removing the snorkel and it's literally a 10 minute job if you follow those directions. The bumper cover is quite flexible and there's plenty of room to snake the snorkel out. I haven't decided if I should leave it completely off or chop it off after the first mount. I would prefer to pull slightly cooler air from outside of the engine compartment but not at the expense of any performance gains.
fstlane is offline   Reply With Quote
Old 10-22-2013, 10:13 PM   #434
Hanni_0176
Hanni_0176's Avatar
Drives: 2013 Scion FR-S 10 Series MT
Shiv
Second time I'm quoting you with an "I'm curious" bit, but anyways
When I removed the stock air filter and replaced it, I could visually see and feel (by touch) a notable difference in texture, which I assumed would make a big difference in air restriction/flow. I also do feel a difference in throttle response (not necessarily hp or tq) in the 3k-5k power band, particularly between going from light/partial throttle to full throttle, and my butt dyno can feel a decent increase in pull above 5k rpm.
I can definitely see how removing the snorkel would increase the air flow, but the question I have is... wouldn't this increase the ambient temps some? It looks like the snorkel bends around to try and pull in air from further away from the engine bay, whereas without it, the entrance is much closer to the engine bay. Again, I'm just curious. Removing the snorkel seems pretty simple, and I may end up doing that in the next couple of days, for science...
Hanni_0176 is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
