Old 10-03-2013, 01:46 PM   #421
Rosticles
Drives: 1966 Mustang, 2013 FR-S
Does anyone know the PID settings for monitoring steering wheel angle?
Rosticles is offline   Reply With Quote
Old 10-09-2013, 04:30 PM   #422
kanundrum
Drives: 2013 Whiteout FR-S
Originally Posted by IceFyre13th View Post
I just got this, http://www.scantool.net/obdlink-mx.html
Yes it has a high price, but it works on every car I have tried it on so far.....and it really dose make the Torque app run faster, refresh rates are super fast.
The software it comes with, OBDwiz, is nice too. Still paying with this, more later, running around town with a laptop is a pain.............
Their android app, OBDlink has some cool features.....being able to change the display type without deleting it first is real nice.
Just ordered this from amazon to get started with this whole torque shennigans
Old 10-09-2013, 04:34 PM   #423
thehapaone
Wasian Ninja
thehapaone's Avatar
Drives: 2013 Crystal Black Silica BRZ-L
Originally Posted by FRSRAVEN View Post
I'm using torque Pro.
Mine definitely isn't working. Double checked PID settings, they are correct. I think I've changed another setting in torque that might be messing with the custom PID.
Would changing the default temperature scale (F instead of C), interfere with the custom oil PID which was setup for C?
I think the equation will be different for F if you put in in as C then change your default to F it seems to work in F...with that said at the track this past weekend mine randomly shot up to 230000 C and down to -40C so I wouldn't 100% believe the readings coming off of this PID
check out my build thread here
Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold)
thehapaone is offline   Reply With Quote
Old 10-09-2013, 07:09 PM   #424
FRSRAVEN
I got this working eventually. Changed the last entry of the PID from 7E0 to Auto, and it works now. Now I just need to figure out how I'm going to mount my Nexus 7.
FRSRAVEN is offline   Reply With Quote
Old 10-09-2013, 07:29 PM   #425
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
I entered mine in as Celsius in custom pid area and then changed my preferences to Fahrenheit.
Sent from my Nexus 7 using Tapatalk 2
pixel67 is offline   Reply With Quote
Old 10-17-2013, 12:07 PM   #426
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Great info in this thread.
I've been using Torque along with the Knock Detector plugin. Quite interesting to see the knock corrections through the rev range. Mostly within the torque dip area and then above 6K.
Slick is offline   Reply With Quote
Old 10-21-2013, 12:38 PM   #427
stugray
Drives: 2013 GBS BRZ Limited
Has anyone found the PIDs to see the tire pressures?
Now that it is getting cold, my TPMS is going off all the time, and I want to be able to see my tire pressures.
Old 10-22-2013, 12:32 AM   #428
ZionsWrath
Thanks
ZionsWrath's Avatar
How can I take this PID for oil temp and have it display in F not C? Is it possible?
Alsso, when I put the custom PID it doesn't let me set -40 as minimum, it only allows 0.
OBD2 Mode and PID: 2101
Minimum Value: -40
Maximum Value: 215 (this is just the maximum that this location can support, which does not mean the sensor can read that high)
Scale factor: x1
Unit type: C
Equation: AC-40 (no space between A and C; "AC" is the location within the response)
OBD Header: 7E0 (Auto also works, but seems to take longer)
Old 10-22-2013, 01:09 AM   #429
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
I believe you can set that in settings.
Minimum Value: -40
Scale factor: x1
Unit type: C
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 10-22-2013, 01:24 AM   #430
ZionsWrath
Thanks
ZionsWrath's Avatar
I changed the settings to show F. The coolant shows in F but the oil shows C. I think because it is custom the equation is calculating C. Anyone know the equation to calculate F?
Old 10-22-2013, 01:53 AM   #431
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
It's possible to put the display on the stock headunit. It is convoluted...but I did it: http://www.ft86club.com/forums/showthread.php?t=49633
I'll post up a better video soon.
robot is offline   Reply With Quote
Old 10-22-2013, 04:49 PM   #432
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Does anyone know if Torque works with a Tactrix Openport 2.0?
- AdrianG
AdrianG is offline   Reply With Quote
Old 10-23-2013, 07:57 PM   #433
topazsparrow
Drives: slow
I'm finding the Knock detector plugin to be a bit lacking. No logging for instance.
Has anyone been able to determine a PID for measuring knock correction?
topazsparrow is offline   Reply With Quote
Old 11-05-2013, 12:46 PM   #434
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
I would really like a way to monitor knock real time. Has anyone found the PID for knock correction yet? I am willing to do any leg work necessary. I have EcuTek and all sorts of testing equipment I just don't have the experience with PID's.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
