#421 | |
Drives: '23 BRZ Limited
If you aren't cutting or at least flaring the stock fenders underneath, you're not really going to gain any extra clearance by adding flares. So you'll have sunken in wheels with flares on stock suspension? I know looks are subjective, but that's going to look pretty bad IMHO.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | timurrrr (05-16-2022) |
#422 | |
Drives: 2022 Subaru BRZ Limited MT
Agree that sunken wheels are going to make the flares look pretty bad. I don't have any experience with fitment, but here's my thought process on trying to get the wheels flush with the flares:
#423 |
Drives: 2022 GR86
Tried Falken RT660 245/40R17 on Enkei RPF1 17x9 +45.
I have Verus RLCA and temporarily have coilovers from a gen1 car. ~1" drop vs stock, and -2.5º camber at ride height (so ~0.5º additional camber compared to stock arms?). To check for clearance issues, I put the car on a fork lift, disconnected the rear end links, and fully loosened the spring seats (ideally I should have removed the spring altogether, but I didn't have time to do that). Then I used a hydraulic jack to raise one of the rear wheels at a time, until the rear jacking points started to rise off the hockey pucks on the arms of the lift. Remember that this may or may not represent what happens to your suspension in the real world. If you only ever drive on mostly flat surfaces, and your spring rates are super high (autox'ers?), then the wheel may never go that deep into the wheel well. However, if you have softer spring rates and for example you go down The Corkscrew at Laguna Seca, chances are your wheel will go into the wheel well as deep as the suspension geometry allows. The other factor that you may or may not want to consider is sidewall flex of the loaded outside tire. I don't have enough data to say how much the top of a laterally loaded rotating tire moves compared to only vertically loaded static tire, or even in which direction. Anyhow, here are the photos. Use your own judgement to draw conclusions. 1) First test, no adjustments vs gen1 setup. The rear coilovers were already set up to have ~7 mm less compression travel than recommended by the installation instructions that came with them. Notice that some of the rubber "antennas" turned into J's. Honestly I don't even remember if I jacked the wheel all the way at that point or stopped early. It's THAT close. ![]() 2) Adjusted the coilover to have 18 mm (!!!) less compression travel than recommended. Now I can squeeze a caliper in between the tire and the fender liner. Not ideal suspension travel, but now I'm pretty confident they won't make much contact if at all. (Note: I adjusted the coilovers differently after that for different wheels and tires) ![]() 3) Photo of the fitment on the ground. Basically flush, but IMO a bit too aggressive. ![]() Note that RT660's are very wide. It's possible that other 245/40R17 tires on 17x9 +45 will fit perfectly fine. Also worth mentioning that I didn't have time toe check inner clearance, which might also be a concern as we get into the higher numerical offsets.
Follow the build thread for my GR86!
| The Following 4 Users Say Thank You to timurrrr For This Useful Post: |
#424 | |
Drives: 2022 BRZ sport-tech
Thanks.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
#425 | |
Drives: 2022 GR86
Gen2 has different rear arms, and stiffer body. Even with gen1 rear arms, the stiffer body means you may want to soften some things up a bit (e.g. "fast bump damping") and/or add increase anti-NVH measures. It took me 5 minutes after installing gen1 coilovers and wheels/tires to notice higher NVH than it was on the gen1 car with the same coilovers and wheels/tires.
#426 |
Drives: '22 BRZ
I think many Gen 1 coilovers were done poorly even for first gens, so no surprise they're updating
![]() I have *zero* clearance issues with 245/40R17 Yokohama A052s on 17x9 ET45, even compressed further than what timurrrr showed and -2.2 rear camber (even more clearance now with -2.6 rear camber. YMMV with tires, the RT660s run stupid wide
| The Following User Says Thank You to DocWalt For This Useful Post: | timurrrr (06-10-2022) |
#427 | |
Drives: Blue BRZ
I think about trying same tire on 17x9 et45 with stock shocks/springs. In front: peddlers top hat, combination of camber bolts, Apr studs, 10 mm spacer. Rear: upper control arms. Am I being realistic? Would it be better to use different offset or different spacer? |
#428 | |
Drives: '22 BRZ
Yes, with coilovers. Those mods should make them fit with stock shocks/springs, the biggest issue will be front spring perch clearance.
#429 | |
I'm curious because I have a custom set of 8th gen FA500s being made now and when we asked if there were going to be any updates to their offerings for the 2nd gen their verbatim response was: "We did testing on the new BRZ and found that our original setup still worked best. So there were no changes made on the new GR86/BRZ compared to the old FRS/BRZ."
#430 | |
Drives: Blue BRZ
So 10mm spacer is less than 1/2” that 9in wheel will grow inboard relatively to 8in wheel. Probably will have to dial back some of precious knuckle camber or to try even thicker spacer. |
#431 | |
Drives: ‘13 AT FRS
| The Following User Says Thank You to Ogt For This Useful Post: | Krokodil (07-05-2022) |
#432 |
Drives: '22 brz Sport-Tech
18x8.5 +40 Superspeed Rf06RR with Advan Apex 245/35. Stock suspension. 5mm spacer up front allows my -3.2 camber up front ( pedders+camber bolts) without any issues.
| The Following 2 Users Say Thank You to Xed32 For This Useful Post: | Krokodil (07-05-2022), OkieSnuffBox (07-05-2022) |
#433 |
Apex ARC-8 wheels from my 1st gen. 17x9 +42. Tires are 235/40/17 gtradial sx2. Stock suspension/alignment. I think this might be a good 2nd gen tire/wheel combo with coilovers and typical track camber. Right now there’s a little bit of poke, but not bad. Looks better than I was expecting actually. I was going to sell these but now I’m not sure…
2022 BRZ Build 2013 FR-S Build |
#434 |
Drives: 22 BRZ
Love a bright silver wheel on a bright red car. Looks rad.
| The Following User Says Thank You to AK2112 For This Useful Post: | DarkSunrise (07-18-2022) |
| Rear wheel alignment issues... HELP! | Rambo305kid | Issues | Warranty | Recalls / TSB | 10 | 07-05-2020 11:05 PM |
| Wheel Fitment Issues. Need help. | hay_frs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 04-06-2020 07:09 PM |
| Fitment issues | Neal86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-07-2019 08:08 PM |
| Tire/Wheel fitment (rear) | rikixass | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 01-17-2018 05:09 PM |
| Fitment Issues | Silp3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-02-2013 04:34 PM |
