#421 | |
Drives: BRZ 2018
As I use my car mainly on highways at 135-150km/h and cruise control I am in the area of 3200-3800rpm and load >0,7 where there is big difference from Stock / OFT V4 Stg2+ / Wayne CL fueling tables! I haven't access to EUDM OFT V4 maps but I guess fueling will be more or less the same so OFT as a base may be suit better my needs if I find the appropriate maps for European cars. |
#422 |
Drives: brz 2017 hksv2
since there arent v4 maps for eudm but v4 maps are actually euro maps, you can hack the by yourself and modify the avcs and closed loop map to keep them more similar to stock values untill say 3800 or 4000 rpm... or even do a blend that at low load columns they are like stock and at higher load you change them for higher performance
easiest way without hacking roms would be for your my17 Eudm to modify a k00g rom and copy all the modified tables you take from a v4 b01c rom to your k00g with romraider i dont suggest you to look at v4 k00c maps since i think they are better for usa cat with red manifold |
#423 | |
Drives: BRZ 2018
So are you sure B01C mate better with our K00G maps, K00C are for catted headers and red manifold? |
#424 |
our my17 cars are same as old models
b01c is a a01g map actually i like it more.. you can try do different maps and see what you like more |
#425 |
Drives: BRZ 2018
I am not going to try many different maps as I'll do my own remap on the dyno, just want to know from you that have already experienced what is the best base map I could use from the available V4 maps as it seems they are a good compromise between power gains, smoothness and fuel consumption in daily basis.
What is your opinion Steve99? |
#426 |
Drives: frs
Anyone use the v4 tune with 93oct (10% ethanol)
#428 |
Drives: 2013 Raven FR-S
Can someone tell me how to lower the launch control RPM's? I've tried lowering the Rev indicator thing down, but the launch control always stays at 5,500 RPM's no matter what I do. Feel like I'm missing something here.
#429 |
Write 3600 on launch control delta to have it around 4000 rpm
#430 |
Drives: frs
#431 |
Drives: 17 Series Yellow BRZ
From everything I've read, even the stock tune knocks quite a bit. And I've also read that the engine should protect itself just fine. That's what IAM and flkc are for. To me it seems totally random as to when and where it knocks. I'll go weeks where my IAM will not drop at all, then all of a sudden it'll show a lil bit of knock, then in the same exact load range with the same type of driving the IAM will quickly rise right back to 1.
| The Following User Says Thank You to Jasonb For This Useful Post: | Teseo (05-24-2018) |
#432 |
Drives: Taco
Do most people run Openflash on the stock/factory ECU? is a stand-alone ECU necessary if I wanted to save more than one tune to change on the fly?
#433 | |
Drives: Toyota GT86
![]() ex: A01G
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
| The Following User Says Thank You to elBarto For This Useful Post: | JIM THEO (05-25-2018) |
#434 |
If there is only a01g he would still need to modify a real k00g map to include those v4 tables in it
| Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Software Tuning | 130 | 08-25-2020 08:29 AM |
| The latest EU/AU OFT tunes (D00G) don't come with launch control | jamesev93 | Software Tuning | 4 | 03-12-2018 05:14 PM |
| Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Engine, Exhaust, Transmission | 3 | 08-27-2016 03:04 PM |
| ***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes | Garrett@Openflash | Engine, Exhaust, Bolt-Ons | 54 | 06-11-2014 07:29 PM |
| OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) | Rombinhood@OpenFlash | Software Tuning | 237 | 02-10-2014 04:35 PM |
